I have installed CF9 and CFBuilder 2 following the instructions in http://www.adobe.com/devnet/coldfusion/articles/setup_dev.htmlhttp://www.adobe.com/devnet/coldfusion.... (Multi Server setup using apache). Everything seems to be working fine except I cannot get the debugger to work. When I try to launch it I receive this error:
-1:Error connecting to JVM for debugging at localhost:5005.
Could not attach to the VM at port 5005
You must specify this debugger port in the JVM settings of your application server...
I read somewhere that I should edit my jvm.config file, but I don't know how to do this. Please help!
OK, let's go step by step. What part of editing the jvm.config file do you not know how to do?
You need to:
* find out where the file is
* what changes you need to make to the file
* make the changes
None of those seem too hard, do they? Start with the first one... find the file. Where is it?
Adam
*the file is in my C:\JRUN4\bin directory.
*I attempted to copy/paste the following code in:
-Xdebug -Xrunjdwp:transport=dt_socket,server=y,suspend=n,address=5005
this was the sample code which displays in the CF Administrator Debugger settings page.
I took a wag and added it to the *arguments to VM* on the line just below the existing arguments.
*Save the file, restarted the server, didn't work.
OMG - this AM, added the code to the end of the the arguments line instead of starting a new line with it and presto - success! Its true, everything looks better in the AM.
Thanks for your reply, Adam.
No probs. It helps to break a problem down into smaller chunks before trying to tackle it sometimes.
Adam
