When I test my index in a generated Webhelp project, the topics associated with the keyword I click are not arranged in alphabetical order but randomly.
When I click the same keyword in the project in RoboHelp (in the Index, before generating), the topics are arranged correctly.
Is there some setting in RoboHelp or Internet Explorer that would straighten this out, or is it simply a RoboHelp bug?
Using RoboHelp 8 and IE 8.
John
Hi, John D. This is John D.
You can "manually reorder the HHK file" as you describe to achieve the order you want. A couple of clarifying notes are added below:
Hi John
In RoboHelp, are you able to open the Index designer, right-click a main index term and choose Sort > Current Level and below?
Cheers... Rick
No, the submenu with Current Level and Below is disabled.
Hello again
Perhaps try this. In your Single Source Layouts pod right-click Microsoft HTML Help and set it as the default layout. Then try sorting the Index. The option should be available then. Then reset the layout to what it was before and generate. See if that makes any difference in the way things display.
Assuming it does, you should be golden. If not, does it display incorrectly when you view from your PC before publishing? Or only after you publish to a server?
Cheers... Rick
OK, that has enabled the commands, but a couple of questions:
Your screenshot shows a multi-level index (keys and subkeys). My index has only one level. Is this procedure still appropriate?
And two, if it is still necessary & useful, do I need to do this on every keyword in the Index or only on one of them?
Hello again
Yes, it's appropriate for a single level index.
You only need to do one as the sort occurs on the Level, not each term.
This is no guarantee it will fix your issue. More of an educated shot in the dark.
Cheers... Rick
Hi Rick,
Would you be willing to speculate further?
Browsing through the .hhk file, I noticed that the section name elements are out of sequence in identical order that they are shown when user uses index.
Does this mean that if I manually reorder the hhk file, it would fix the problem? Or is that too dangerous to fool with? (are the section names normally out of order in hhk, or should they be ordered correctly as shown in Index Designer??)
Is there any easier way to rebuild an hhk file? Can I delete it and have it automatically rebuilt?
Noticed in the Index Designer that when I click the Create/View Index File button & then click View, nothing happens. Is this a symptom of a corrupt hhk?
Thanks for any insight,
John
Sent: Tuesday, November 15, 2011 4:33 PM
To: John Dawson
Subject: Help topics not in alpha order when user clicks keyword in Index
Re: Help topics not in alpha order when user clicks keyword in Index
created by Captiv8r<http://forums.adobe.com/people/Captiv8r> in RoboHelp - View the full discussion<http://forums.adobe.com/message/4028182#4028182
<?xml version="1.0" encoding="utf-8"?>
<index version="1.0">
<properties>
</properties>
<item name="How it works">
<section name="E First Topic" link="First_Topic.htm">
</section>
<section name="D How it works" link="How_it_works.htm">
</section>
<section name="C The Information Screen" link="The_Information_Screen.htm">
</section>
<section name="B Starting the application" link="Starting_the_application.htm">
</section>
<section name="A Welcome" link="Welcome.htm">
</section>
</item>
<item name="Starting the application">
<section name="A How it works" link="How_it_works.htm">
</section>
<section name="B First Topic" link="First_Topic.htm">
</section>
<section name="C Error Messages" link="Error_Messages.htm">
</section>
<section name="D About" link="About.htm">
</section>
</item>
</index>
Here's what the WebHelp output shows for the two Index entries:
And, the MS HTML Help CHM:
Happy alphabetizing!
John Daigle
Adobe Certified RoboHelp and Captivate Instructor
Evergreen, Colorado
Thanks John. I might try manually rearranging the hhk file on a slow day, after I feed the unicorn.
On the issue of whether this is a bug, I just looked at a server with help that I created some years ago with a previous version of RoboHelp & the topics are nicely alphabetized in it. Or, to quote the old cartoon, "I say it's spinach, and I say the h**l with it."
Anyway, it's somehow reassuring to know that there isn't some slick and easy trick I didn't know about.
That didn't work. For what it's worth, the help topics WERE arranged in correct alpha order in the Topics Found dialog when I generated HTML help, but they are still not correct when I generate Webhelp.
Just to make sure we are talking about the same thing, the keywords themselves are in alpha order. It's the topics displayed when user clicks a keyword that are random order. And they are in proper alpha order in the Topics for: pane in the Index Designer. Just random in the generated help.
So far I have only tested by generating on my computer. Won't be able to see a "published" result till tomorrow. But the fact that they are in correct order in the Index Designer itself makes me think this is surely a bug.
Don't call me Shirley.
