RH 8
I had a look at Rick Stones' skinny on skins and think I followed the instructions but could not reduce the height of the toolbar, which currently is about twice the height of the buttons and so is really just wasted space.
Has anyone done this successfully for RH 8 webhelp?
Pete
There are two things you can try:
Greet,
Willam
Thanks for that - it gets us one step forward...
The first idea works: in the webhelp folder, I find in the start file (and also in the identical file whskin_homepage.htm):
var strHTML = "<frameset rows=\""77\"
and when I change the number of rows yes I can change the height of the toolbar.
All good but we can't patch our output files every time - because we do nightly builds.
In the skin file, what seems to be the appropriate frameset definition has rows=(1,*), and none of the frameset rows has a sensible number : they are all 1 or *. Clearly the height must be calculated and written by something.
I would guess something under Program Files\....RoboHelp 8\RoboHTML\WebHelp5Ext\ produces the number for the height of the toolbar, but I can't see where or what it uses used as a basis for calculation...The code is just to hard to follow (for me).
Any hints?
Peter
