Problem running contact manager app
Avatar
Level 2
I am trying to run the contact manager sample app and receive
the following client side error:
[MessagingError message='Unknown destination
'cfcontact-default' for service with id 'data-service'.']
at mx.messaging.config::ServerConfig$/getProperties()
at mx.data::Metadata$iinit()
at mx.data::ConcreteDataService$iinit()
at mx.data::ConcreteDataService$/getService()
at mx.data::DataService$iinit()
at contactmgr/::initApp()
at contactmgr/___Application1_creationComplete()
at
flash.events::EventDispatcher/flash.events:EventDispatcher::dispatchEventFunction()
at flash.events::EventDispatcher/dispatchEvent()
at mx.core::UIComponent/set initialized()
at mx.managers::LayoutManager/::doPhasedInstantiation()
at Function/
http://adobe.com/AS3/2006/builtin::apply()
at mx.core::UIComponent/::callLaterDispatcher2()
at mx.core::UIComponent/::callLaterDispatcher()
I cant seem to find any files that reference
cfcontact-default. Ideas? Thanks!!
Avatar
Level 2
u should write the context path in the server.xml and the
transaction factory.
u should import necessary jar files for the transaction to
happen.
Vasibe
Avatar
Level 2
Hmm the problem was 'cfcontact-default' should have just been
'cfcontact'.
Now to another problem when running this example. On load i'm
receiving an error:
[Flex] [ERROR] Exception when invoking service: data-service
with message: Flex Message (flex.data.messages.DataMessage)
operation = fill
id = null
clientId = 18DA1C41-745B-B4C3-06F6-1AAADC0DDB31
correlationId =
destination = cfcontact
messageId = A48465C9-0AEB-7E91-4A1F-1AAADC17AB89
timestamp = 1155793607813
timeToLive = 0
body =
hdr(DSEndpoint) = cf-dataservice-rtmp
exception: flex.data.adapters.AdapterException: Error
invoking fill-method 'fill' for destination cfcontact: Permission
denied
Here is the code which it is choking on:
private function initApp():void
contacts = new ArrayCollection();
ds = new DataService("cfcontact");
ds.addEventListener(ResultEvent.RESULT, resultHandler);
ds.addEventListener(DataServiceFaultEvent.FAULT,
faultHandler);
ds.addEventListener(DataConflictEvent.CONFLICT,
conflictHandler);
ds.autoCommit = false;
var token:AsyncToken = AsyncToken(ds.fill(contacts));
token.kind = "fill";
Would someone be kind enough to explain why i am receiving
this error? Thanks!!!
Avatar
Level 2
hi
this is because the transaction is failed it is not invoking
data service method
<Transaction
factory="org.objectweb.jotm.UserTransactionFactory"
jotm.timeout="60"/>
</Context>
u paste this code in the server.xml and restart the server.
thanks
vasibe
Avatar
Level 2
A couple questions.
1. Where is server.xml? I cant find this file anywhere
2. Why do the pre-installed samples work fine without
this?
Avatar
Level 2
If you are running on Tomcat, they you'll have server.xml and
need to add transaction support by installing the JOTM pacakge and
including the definition in server.xml.
If you're not running on Tomcat, that information is not
relevant.
If you're running on JRun or any other J2EE server,
transaction support is already included.
In terms of debugging your original issue,
'exception: flex.data.adapters.AdapterException: Error
denied'
Based on the logging statements, you can see that the fill
request got to the FDS server. The next step is to determine if the
request got to the cfcontact object. Are you able to add debug
logging statements and or debug the method you've defined for fill
on your cfcontact definition?
Avatar
Level 2
quote:
Originally posted by:
CathyM
The next step is to determine if the request got to the
cfcontact object. Are you able to add debug logging statements and
or debug the method you've defined for fill on your cfcontact
definition?
Unfortunatly i am not really sure how to go about debugging.
Although in the setup documentations for "Using Coldfusion with
Flex - Part 1" number 11 says the flex console should output:
"[Flex] [CFDataServicesAdapter] Configuring CFC adapter for
destination cfcontact"
after making the necessary changes to
data-management-config.xml. Flex doesn't output this, is it safe to
assume this is another way of telling me that Flex is unable to
communicate with my Coldfusion server?
Avatar
Level 3
Hi Dr.,
Did you follow step 6 on page 2 of Tom J's article to the
letter (editing services-config.xml's <logging> section)? Are
you seeing any debug Flex output in the console?
Best,
Seth
Avatar
Level 2
I did. However nowhere in the article did it mention to
replace {server.name} in the services-config.xml file with your
servername/host/ip. Doing this fixed the problem.
Avatar
Level 2
I have followed everything to the T. Somehow i got this
working once, but no i cant get it to work again! I don't know what
else to do.., i assume that im having problems because FDS and CF
arnt communicating as i am continuing to receive:
"error invoking fill-method 'fill' for destination
cfcontact-default: permission denied"
i also noticed when that im receiving an error requested
resource /samples/messagebroker/cfamfpolling
(%2fsamples%2fmessagebroker%2cfamfpolling) not found
not sure if this has anything to do with it, and also i keep
reading that some people get it to work by replaceing
{server.name}:{port} in services-config.xml, ive tried everything,
not sure what else to do. Thanks.
