5 Replies Latest reply on Feb 1, 2019 9:48 AM by Lumigraphics
    Filename to IPTC Title, but without extension. (Currently using DAM script)
    queuenal Level 1
      Hello,
      Apologies if this isn't the correct forum to ask this question:
      I am currently using the DAM Filename to Title script with Bridge CS4 - http://www.damuseful.com/pages/PimpMyBridge.html - to get the filename into the IPTC title script. This however puts in the extension into the title field also. So a JPG file named 2000 ends up with 2000.JPG in its Title field. I wish to not have the extension appear in the Title field.
      Is this possible by modifying the DAM script / using any other freely available script.
      In case it helps, this is what the DAM script currently looks like:
      #target bridge
      if ( BridgeTalk.appName = "bridge" )
      //This script copies selected thumbnails' filenames to the title field
      //Also shows how to add menu items
      //The AdobeLibrary scripts must be loaded
      //This script was created by John Beardsworth www.beardsworth.co.uk/ and modified by Peter Krogh www.DAMuseful.com
      //This script may be freely distributed and modified
      // Let's create our menu
          var menu = MenuElement.create( "command", "Write Filename to IPTC Title Field", "at the end of Tools");
          menu.onSelect = function(m)
      var getFolderChildren = true ;
      var filesOnly = true ;
      var thumbs = getBridgeThumbnails ( TYPES.PHOTOSHOP_OPENABLE, getFolderChildren, filesOnly) ;
      for ( var i = 0; i < thumbs.length; i++ )
      { thumb = thumbs[i];
         md = thumb.synchronousMetadata;
         md.namespace ="http://ns.adobe.com/photoshop/1.0/";
         md.Title = thumb.name;
         Window.alert ("Done " + i + " records");
      There are also 3 other Adobe Library scripts that come with the download.
      I know absolutely nothing about scripting, so baby-steps would be appreciated.
      Many thanks.
