1. Re: How to set settings to do 'right' thing by default, than default to 'wrong things...?
arc fixer Nov 20, 2011 6:14 PM (in response to Astara_)Hi Astara.
Your enquiry does cover a lot of ground. I'll start with a little bite.
If I had the control when creating the gradient for it to take it's rotation from the line I drew... As long as I am only drawing gradients, it can copy the formula and direction of each and apply/store them as the layer's 'gradient' forumula...?
There are 3 ways (at least) to apply a gradient. The Gradient Tool (G), as an Adjustment Layer, or as a Gradient Overlay Effect. The latter two give you a live preview. You can create a new gradient or edit an existing one. Both can be reedited later. If you use the Gradient Overlay Effect, you can record the gradient as a Layer Style and apply it to any layer with one click, and it will be fully editable with live preview.
I'm not sure about the file size connotations.
Hope this helps a little.
Peace,
Lee
2. Re: How to set settings to do 'right' thing by default, than default to 'wrong things...?
Silkrooster Nov 20, 2011 9:13 PM (in response to Astara_)"So it would be convenient if when I create a layer, it could do the right thing to begin with. Problem is -- when I hve tried to create a gradient layer, the program doesn't let me create the gradient -- I can only use a predefined gradient. Which is awkward to say the least!..."
Why won't it? The gradient tool, the gradient map, the gradient fill and the gradient layer style all work the same way when creating a new gradient. Just click on the gradient itself instead of the drop down icon to create a new gradient instead of using a preset.
4. Re: How to set settings to do 'right' thing by default, than default to 'wrong things...?
Astara_ Dec 20, 2011 12:07 AM (in response to Silkrooster)That is what I do.
But I'd want it to create the gradient layer, blank to begin with. My process wasn't aligned with the requirements...but I usually like to go delete the layer mask 1st, and then I need to make sure the newly created gradient layer is below the old layer so I can pick off the colors from the old layer. then I can go back into the gradient fill as you show above to create the gradient.
What is very NOT intuitive, is DIRECTION on the gradient. On a normal layer, it's pretty accurate, go from point a to point b.
But trying to duplicate that accuracy -- the agle from that tiny little circle, , and then trying to find the 'edge of the graident and where it lines up with the layer you see....
All those are trial and error...
What Horribly threw me off was I was used to working with the canvas rotated for the area I was in....
The rotated canvas isn't integrated into hardly any of the tools -- they all still have their x-y aligned on what is a "skewed sight line" for one looking
at a rotated canvas.
Ideally, the tool coordinates would be relative to the view (or toggleable between absolute and relative as some might prefer the other...)...
But trying to figure out the gradient directly when your canvas is rotated... isn't exactly *obvious*, nor simple. Doable, yes, but not very easily...
