When generating WebHelp, "Adobe RoboHelp 8 has encountered a problem and needs to close" appears.
Nov 21, 2011 Nov 21, 2011
I'm using RH 8.0.2.208 (both patches applied). This project is a child project in a merged project structure and it is the only one that I am having problems publishing. I've tried deleting the CPD file and creating a new layout, but the error still occurs whenever I try to publish. (FYI, I have no problem opening this project). Are there any other actions I could try? Thanks in advance.
553
Community Expert , Nov 22, 2011 Nov 22, 2011
Welcome to the forum.
Does this problem also occur if you publish to an entirely different location? If it does then can you link the problem to any recent changes. If not, it seems to be time for the old divide and conquer approach.
Zip up the project so you have a copy that cannot accidentally be opened and worked on. That gives you a copy that you can safely revert to later if needed. Save the zip file somewhere safe.
Then create another copy of the project so that you have two copies that can b
Then create another copy of the project so that you have two copies that can be worked on.
Open Copy 1 and delete half the topics. Ignore any broken links reported. Generate the help from that copy.
Open Copy 2 and delete the other half of the topics. Generate the help from that copy.
It should be the case that one copy is now OK and one still has the problem.
Trash the good copy and then create a second copy of the copy with the problem.
Repeat the process until you have located the topic that is causing the problem.
The process takes less time than you might think.
Let us know how you get on.
@petergrainge
Nov 28, 2011 Nov 28, 2011
Peter,
I took a look at the last new topic I had created and noticed that some of the table formatting had gotten corrupted. Once I fixed the table, the error no longer occurred when I generated it.
Thanks for your suggestion!
RoboHelp Documentation
Download Adobe RoboHelp
