1. Re: Delete results from analyzer
shibharg Nov 22, 2011 11:04 AM (in response to FightRice)Hi,
In order to delete results from the Quiz Results Analyzer (Assusming , you are working on Captivate 5/5.5) and you want to delete the complete course, please follow the steps:-
1.) Select the course that you want to delete that you want to delete under Quiz Results analyzer
2.) At the Top right corner, you may find the Tab " Delete from Acrobat.com "if you are signed into Acrobat.com.
3.)Click on that and it may delete the course.
Note:- In Captivate 5.0/5.5 Quiz Results Analyzer, only courses can be deleted but Organization and Department name can not be deleted
I hope that answers your query.
2. Re: Delete results from analyzer
FightRice Nov 22, 2011 12:47 PM (in response to shibharg)Thanks, but I'm using the report to local server option, and am reading the results from the server and not acrobat.com
Is there any way to delete those results from the analyzer? I've deleted them from the server, but the analyzer seems to be holding on to the information as well.
3. Re: Delete results from analyzer
FightRice Nov 22, 2011 1:20 PM (in response to FightRice)Hey I figured this out on my own
Windows 7: Navigate to c:\Users\USERNAME\AppData\Roaming\
Delete the QuizResultsAnalyzer1.5BUNCHOFRANDOMSTUFF folder
Mac: \Users\USERNAME\Library\Preferences\
4. Re: Delete results from analyzer
slopez909 May 31, 2012 5:51 AM (in response to FightRice)What's a "BUNCHOFRANDOMSTUFF"? A joke? Was that a real answer?
5. Re: Delete results from analyzer
slopez909 May 31, 2012 6:00 AM (in response to FightRice)Hello FightRice,
It appears that you ran into the same issue I did. I see your Post was submitted back in Nov 2011. I was wondering if you made any discoveries since then?
slopez909
6. Re: Delete results from analyzer
AdityaKalania May 31, 2012 6:19 AM (in response to slopez909)Hi
"BUNCHOFRANDOMSTUFF" means that there is different value here, on different computer, and so that part of the folder name is random, and is not fixed for all the machines.
For eg on my machine the folder name is "QuizResultsAnalyzer1.5.D22673E681B55698FF9C7ED1AC2C76EECFF3CF3F.1", so after QuizResultAnalyzer1.......it all some "bunch of random stuff"
7. Re: Delete results from analyzer
slopez909 Jun 1, 2012 1:32 AM (in response to AdityaKalania)Thanks for your patience AdityaKalania,
I did a file search for file starting with "QuizResultsAnalyzer*.*" and no luck. I am using Captivate Quiz Rusults Analyzer on 2 Windows Operating systems; Windows 7, and Vista. I cannot find any subdirectories in the "/user/USERNAME/" that look like "AppData".
8. Re: Delete results from analyzer
AdityaKalania Jun 1, 2012 3:42 AM (in response to slopez909)Did you tried to "show hidden files" option.
AppData folder is hidden by default.
9. Re: Delete results from analyzer
slopez909 Jun 1, 2012 5:37 AM (in response to AdityaKalania)You're a genius.
