This has been an on going problem for almost a month now. As
i gave up before, the more i learn about what FDS can do for me the
more i want to use it. However it is just becoming the biggest pain
to get it to talk with CF. I have read through the forums,
walkthroughs and anything else i can get my hands on and still cant
get it to work.
The primary problem im encountering is:
"Error invoking fill-method 'fill' for destination
cfcontact-default: Permission denied."
Coldfusion Config:
Flex Integration: Flash Remoting enabled, Flex Data
Management enabled, 192.168.1.150 allowed.
All CFCs are located in
wwwroot/contact_sample/samples/contact
Mapping /samples ->
C:\CFusionMX7\wwwroot\contact_sample\samples\
http://192.168.1.150:8500/contact_sample/samples/contact/testContactAssembler.cfmreturns 8 records
Flex Config:
Copied the coldfusion-dao adapter and the entire
cfcontact-default destination from
fds2\resources\config\data-management-config.xml
to
fds2\jrun4\servers\default\samples\web-inf\flex\data-management-config.xml
AND
Copied the cf-dataservice-rtmp, cf-polling-amf channel
definitions and the DataService.coldfusion pattern from
fds2\resources\config\services-config.xml
to
fds2\jrun4\servers\default\samples\web-inf\flex\services-config.xml
I did nothing else, no changing {server.name} or uncommenting
<hostname>.
My application files are installed at:
C:\fds2\jrun4\servers\default\samples\contact_sample\dataservice\contact
And i run the application from:
http://192.168.1.150:8700/samples/contact_sample/dataservice/contact/contactmgr.mxmlI did not change the directory structure or edit any of the
files within the contact_sample zip file.
NOTE: both data-management-config.xml and contactmgr.mxml
both reflect cfcontact-default
I have gone through these files over and over and over,
messed with other things, reinstalled, everything! I dont know what
else to do. Help is greatly appreciated!!!
