in cf9 i have a bound cfgrid with an ID (numerical) column and a checkbox column. onChange calls a js function where i have a list of numbers (corresponding to some of the ID's in the ID column). i want to loop through both my list and the ID column of the grid, and, if a match, set the corresponding checkbox to "checked". i can't figure out the correct syntax. i've marked with ??? the stuff i'm having problems with
any help appreciated
var mygrid=ColdFusion.Grid.getGridObject("aGrid"); // get number of rows in grid
var mydata = mygrid.getStore();
var rowCount = mydata.totalLength;
var i = 0;
var myList = "2,4";
var myArr = myList.split( "," ); // convert list to array
while ( i < myArr.length) // loop through list array
for (var r = 0; r < rowCount; r++) // loop through grid rows
// get the id value corresponding to the r row - throws error "exception thrown and not caught"
??? var thisID = ColdFusion.getElementValue('aGrid', 'aForm', 'app_id
if (myArr == thisID)
// set the status of the corresponding checkbox to "checked" - no idea how to do this
??? ColdFusion.setElementValue('aGrid', 'myCheckboxColumn
Just glancing at your code, this line seems to have a syntax error:
First, the last parameter: 'app_id
var thisID = ColdFusion.getElementValue('aGrid', 'aForm', app_id
Secondly, is the app_id array a Javascript array or a CF array variable? I didn't see a mention of it in your sample code, so I wanted to make sure you weren't confusing client-side and server-side variables.
thanks, what i'm trying to do with that line is to get the app_id value from the grid row corresponding to my loop index (r), app_id is the grid column name. if r = 0 i should get the app_id value in the first row, r = 1 get the second row, etc
now that i think of it, the grid row loop should probably start with 1, not 0.
that line should probably be
var thisID = ColdFusion.getElementValue('aGrid', 'aForm', 'app_id');
but i still don't know how to pass the loop index to the getElementValue function so that i'll get only that particular row value
regards
You may be able to access the underlying ExtJS grid controls using ColdFusion.Grid
some of the syntax can be seen on this thread:
thanks, that thread kind of shows how to delete a record in a very convoluted way, i can't believe there is not a simpler way to "set" the value of a grid cell programatically
In my opinion, the way to go is indeed ColdFusion.getElementValue('aGrid', 'aForm', 'app_id'). I am assuming that app_id is the column representing IDs.
Remember that an event triggers the script. When the event occurs the state of the grid at that moment includes the currently selected row. That row-value is implicitly stored in app_id.
', 'checked', 'true') ???;
I am unaware of the existence of the system function ColdFusion.setElementValue(). When I googled, the initial hits confirmed my suspicion.
You could go for something like
Ext.get('myCheckboxColumn').set({value:'true'});
thanks BKBK, the script is attached to the onChange event of the grid, when user checks or unchecks a box. it's passing indeed the corresponding app_id, but what i want is to loop through all the grid rows, not just the select one. if one of the app_id value in a row matches a value in my list, i want to check or uncheck the checkbox programatically
regards
Number of records in grid
var myGrid = ColdFusion.Grid.getGridObject("aGrid");
var myDatastore = myGrid.getStore();
var numberOfRecords = myDatastore.getTotalCount();
ion wrote:
... when user checks or unchecks a box. it's passing indeed the corresponding app_id, but what i want is to loop through all the grid rows, not just the select one. if one of the app_id value in a row matches a value in my list, i want to check or uncheck the checkbox programatically
The grid's RowSelectionModel might also come in handy.
