Hi Everyone,
I'm trying to figure out how to use the new "Flash Field" inside my form.
The form we are working on required the user to interact with the "Flash Field" (i.e., click on the bar on a bar-chart) and the "Flash Field" should return some value (defined in the Flash logic) should be returned to the host (the PDF form) as the FlashField.rawValue, for example.
BTW: The SWF object that is consumed by the "Flash Field" is built by the Flash Builder latest edition (4.5). So we do have a total control on the logic inside the SWF project.
The Q here is: What is the possibility to modify my code inside my Flash project so it can expose the SWF object computed value to the rawValue property of the Flash Field?
Appreciating your collaboration....
BR,
Yasser
Have a look at the Flash object Reference Card and the Flash object examples here: http://assure.ly/rqCuEn.
Hope that helps,
Niall
