2. Re: Add export to the print module so I can put collages etc to the cataloge
SedG1 Nov 26, 2011 11:30 AM (in response to Hal P Anderson)Good Morning
I can simply print it but there may be times I want to save in the LR
library without printing it and scanning it back into LR
when I look at the export dialog box there is a feature that would allow me
to put that image,collage or whatever back into the LR library so I could
use it in other situations
Steve
3. Re: Add export to the print module so I can put collages etc to the cataloge
Hal P Anderson Nov 26, 2011 12:52 PM (in response to SedG1)Reread what I posted. You can print to a jpeg file. You don't need to print to paper and then scan.
No box to tick to bring it back into lightroom, but it would be easy enough to import the collage that you produce.
Hal
4. Re: Add export to the print module so I can put collages etc to the cataloge
Bob_Peters Nov 26, 2011 1:09 PM (in response to Hal P Anderson)The possible problem I see is that when you print to a JPEG file the file name gets mangled.
5. Re: Add export to the print module so I can put collages etc to the cataloge
SedG1 Nov 26, 2011 1:29 PM (in response to Bob_Peters)Hi
By using Export and Export as DNG there is a checkbox to "Add to this
Catalog" in the Export Location Box.
Also thru Export function it an image can be directly uploaded to a
zenfolio or iflicker facebook istock or wherever
Steven
