2 Replies Latest reply on Dec 9, 2011 7:51 AM by Hoang_Huynh
    How to save/retrive custom properties to a PageItem
    Hoang_Huynh Level 1
      Hello community, have any of you succeeded in saving custom properties/data to a PageItem? I try to save my own properties to a PageItem using its property named properties. Setting properties seems to work but getting doesn't. This is my code (ActionScript 3.0):
      var app:Application = InDesign.app;
      var page:Page = app.activeDocument.pages.item(0);
      var items:Array = page.allPageItems as Array;
      // my properties
      var myPropertyArray:Object = {fname:"John", lname:"Lennon"};
      // set properties to first item of page
      items[0].properties = myPropertyArray; // this works
      // now get
      var props:Object = items[0].properties; // Error: In wrapReturnedHostObject(), attempted invalid wrap: com.adobe.indesign::Enumerator returned as Object
      I read on this forum that this is a bug of CSAWLib. If so, is there any other way to save my custom properties to an InDesign document?
        • 1. Re: How to save/retrive custom properties to a PageItem
          Marc Autret Level 5
          Hi Hoang,
          I'm afraid your code:
          items[0].properties = customObject;
          only *seems* to work, but actually does not. The properties property is a special command that only deals with native, valid, properties of a DOM object. Used as a setter, it simply ignores non-native keys. Used as a getter, it simply returns available properties. More generally, given a page item—say myRectangle— any statement such as myRectangle.myCustomProperty = "foobar" will cause an error ("Invalid property or method", or whatever) because you cannot extend DOM object instances. They all are command wrappers (=specifiers) and don't work as regular JS objects.
          Anyway, you can extend the methods of DOM object prototypes, e.g.:
          Rectangle.prototype.myCustomMethod = function(){ return this.label;};
          When you do that, keep in mind that a Rectangle object instance can reflect several actual InDesign rectangles. For example, myDoc.rectangles.everyItem() is seen as a Rectangle (in terms of cast).
          IMHO, the right way to attach custom properties to DOM components is to use insertLabel() / extractLabel() with serialized objects.
          EDIT: The CSAWLib bug you mention is not connected to the problem of setting custom properties.
          • 2. Re: How to save/retrive custom properties to a PageItem
            Hoang_Huynh Level 1
            Thank you so much Marc!
            Your answer explains clearly what I just need. Using insertLabel() / extractLabel() with serialized objects is a good way to store custom data in a PageItem.
