Need to cut images out of PDF documents and place into Indesign..Which program to use?
Nov 28, 2011 Nov 28, 2011
Hi guys,
I am putting together a media kit. It entails me havign to cut out images from another PDF and placing them in my booklet which i have created in Indesign.
How can i do this?
Do any of the programs in the CS5 Master collection allow me to manipulate PDF documents?
Thnaks
Don
84.7K
Two possibilities.
1. Place the PDF and adjust the frame to crop out everything but the picture.
2. If you have Acrobat Pro use the touch up object command to get the image into Photoshop. Save it and place it into InDesign.
Bob
Hi Bob, I do have Acrobat X. I assume (having read ont he net) i can use the  edit object tool????
Then apply a clipping process to the image in the PDF.
As always you are a great help
You could also try opening the PDF in Illustrator. The good thing there is if it was originally a vector file, it will still be one. You can open a pdf in Photoshop or Illustrator by just right clicking it and "Open with", on windows anyways.
I would never recommend anyone open a PDF in illustrator! Illustrator is not a PDF editing tool!
Although in this situation I am not sure what advantage opening the PDF in Illustrator would have? You'd have to delete all the surounding artwork, then Export the image to a Tiff file?
Openging the PDF in Photoshop is problematic in itself. If you don't know the resolution of the images you could be inadvertently upscaling the images by opening the PDF at a higher resolution than the images are sized to.
Acrobat already has all the correct tools for extracting the images.
Nov 29, 2011 Nov 29, 2011
Hi Eugene,
I was actually recommending using Illustrator to retreive images from a PDF, not editing the PDF. As I wrote, the advantage would be that if a vector file was used in the PDF, by opening the file in Illustrator it would stay vector.
It is true though that Acrobat already has tools that allows you to extract images, to Photoshop as well as Illustrator.
Graham
Thanks for clarifying Graham.
But even if the PDF has vector images in it they can become horrible nasty pieces to deal with once opened like this - with strange clipping masks for one, and there's just so many things that can go wrong - even if the image is vector.
I still don't recommend extracting images, vector or raster from a PDF by opening the file in Illustrator. There's just too many pitfalls.
Similarly I don't recommend opening the PDF in photoshop unless you are certain of the resolution of the images used. You could inadvertently downsample or upsample the images.
I just don't think it's good pracitce for extracting images.
Let’s just point one thing out.
If the PDF was created by saving it from Illustrator, opening it in Illustrator would not only be okay but would be the best method I can think of for this. Otherwise, use the tools in Acrobat.
Bob
Fair point.
Advocate ,
Easy to check for, too, in Acrobat document properties...
I do this kind of thing a lot. I wasn't aware that there are tools in
Acrobat for extracting images; I've extracted whole pages, but not separate
images. If someone could explain image extraction to me, I'd arppreciate
it.
I usually use SnagIt to grab the image from a PDF and then I can save it in
any graphic format. There is no loss of quality.
Susan
Advocate ,
Nov 30, 2011 Nov 30, 2011
What is there to explain that wasn't already said in my earlier post? Open
the file, use the command, select the format and destination, wait for the
export to finish.
If you have an older version of Acrobat Pro, the command is in a different
location, but is otherwise the same.
Snag it is taking a screenshot, right?
Extracting the images lets you get all images at once instead of taking a
screenshot, one at a time.
Advocate ,
With Acrobat X, you can export the images from the PDF
Click on Tools, Expand Document Processing, Click Export All Images...
You can select where they are saved and what format (JPEG, JPEG2000, PNG, TIFF).
-mt
Apr 23, 2015 Apr 23, 2015
I had this problem and you can do it on Adobe Reader.
1. Open Document in Adobe Reader (durr)
2. Go to Edit Tab
3. Then Click Take a Snapshot
4. Scroll to the image you want, you would have noticed that you poiter
icon has changed to a cross
5. Select the Area you want and it copies that area for you
Hope that helps any one interested
