1. Re: pressure sensitivity not working
greule Nov 21, 2011 8:50 AM (in response to rebelpapa)Thanks for reporting this. Unfortunately the HTC Jetstream behaves in some cases different as we expected when it comes to stylus support. We are inverstigating.
2. Re: pressure sensitivity not working
rebelpapa Nov 21, 2011 12:20 PM (in response to greule)Thanks. Can you explain exactly how the pressure sensitivity is supposed to work? I only know of one other tablet with n-trig that meets the requirements of PS Touch and that's the Lenovo Thinkpad Tablet.
4. Re: pressure sensitivity not working
rebelpapa Nov 22, 2011 4:39 AM (in response to greule)I just wanted to make sure I wasn't missing something. On the Jetstream it doesn't work at all (either size or opacity with pressure sensitvity).
What tablets are available that this works on?
5. Re: pressure sensitivity not working
greule Nov 22, 2011 5:58 AM (in response to rebelpapa)You are correct with the Jetstream. Should work on a Lenovo Thinkpad and on Samsung tablets with stylus support
6. Re: pressure sensitivity not working
rebelpapa Nov 22, 2011 6:25 AM (in response to greule)Thanks @greule. I don't know of any Samsung tablets with pressure sensitive stylus support. Do you have any models you can recommend?
7. Re: pressure sensitivity not working
Kajorn Bhirakit Nov 23, 2011 8:23 AM (in response to rebelpapa)@greule this meann only support for Lenovo and Samsung right?
i test with Toshiba AT100 cannot support also, but for Samsung can work fine
8. Re: pressure sensitivity not working
greule Nov 23, 2011 8:43 AM (in response to Kajorn Bhirakit)Correct
9. Re: pressure sensitivity not working
rebelpapa Nov 24, 2011 6:16 AM (in response to rebelpapa)I would like to suggest you add the HTC Jetstream support. It's a pretty awesome tablet and the pressure sensitivity works great in other apps (Sketchbook Pro).
10. Re: pressure sensitivity not working
Luanne Seymour Nov 29, 2011 10:52 AM (in response to rebelpapa)Hi rebelpapa,
This is a very good suggestion. Would you be willing to add it to our Ideas section? If you don't get back here to add it, I will do it for you in a few days.
Luanne
11. Re: pressure sensitivity not working
kingmj2008 Mar 1, 2012 11:08 PM (in response to greule)does that mean the samsung galaxy tab 10.1 will work with pressure sensitivity?
