Hello,
I have a flash application built in flash cs5 and action script 3.0. When i try to compile it, it returns error.
, Line 1 | 5005: Unknown error optimizing byte code. |
or
ReferenceError: Error #1065: Variable UIProperties_icon is not defined.
I have converted this to air android application. Now i am getting one of these message every time when i compile or try to make apk file.
Somebody please suggest a solution for this.
Thanks----------Amit
Thanks Dmenneoh, I am able to generate the file after following change.
D:\Program Files\Adobe\Adobe Flash CS5\Common\First Run\ActionScript 3.0\jvm.ini file I have set -Xmx128m to -Xmx1024m.
This compile the file.
Thanks --- Amit
It seems this error is mostly due to large files... which doesn't really fit in with making an Android app. Is your file really large? From what I read you can try deleting aso files (control menu > delete ASO files). Otherwise you can try turning off the optimizer also - publish settings - flash tab - uncheck compress movie.
You can find out some more on this by Googling 'as3 5005 error'
Hello Dmenneoh,
Thanks for your response.
I have tried with both the options and tried on google but did not any solution for the problem. My fla file is of 2 mb and it is using lots of components.
Thanks-----------------Amit
Thanks --- Amit
