I have submitted the following feature request.
Does anyone know of a script or other "trick" that will produce this result?
When returning search results in published output, automatically open DHTML dropdowns containing the highlighted search term. Otherwise, users go to the listed page but cannot see the highlighted search term. There may be many dropdowns on a single page, resulting in some inconvenience for end-users of published output.
You need to make a small change in your output file. See http://www.wvanweelden.eu/robohelp/expand_dropdowns_and_expandspots_by_default
Greet,
Willam
Hi Willam
I stand to be corrected on this, but won't that cause all drop-downs to expand for all topics? I understood the issue to be that only when a term was found inside a drop-down was when the expansion was desired. So perhaps a single page has ten drop downs and a searched term is found that occurs in one of the ten, only expand that drop-down do the term would be visible.
AFAIK this isn't possible.
As an aside, it always did strike me as odd that someone would go to all the trouble of inserting drop-downs and expands, only to later want them all presented by default when the topic was opened. Isn't the idea behind them to hide information until the user wishes to see it?
Scratching head.... Rick
Oh Crap, wrong link. Thanks for pointing it out Rick.
It can be done, see this page: http://www.wvanweelden.eu/robohelp/skinning_webhelp/expand_dropdowns_and_expandspots_for_search_resu...
I had created a method, but I guess I didn't check the content of the page. Sorry again. The expand by default link was actually a request from a forum member.
Greet,
Willam
Sweet! Nice job, Willam!
Rick
Thanks – we’ll give this a try in RH9 WebHelp Pro and see how it flies.
Yes, the desired behaviour would be that only the dropdown(s) containing a highlighted search result would be open by default when choosing to view that specific page from the list of search results. An acceptable alternative would be for just the hotspot itself to be highlighted in some way, so that the user can easily see which one or ones contain the search term.
Your comment on the utility of opening them all by default is one I completely agree with.
