How do I get the x,y position of hitTestObject? Since I want to obtain the x,y position where the hit test occurs and add a movieclip on that specific point....
You can't hitTestObject only returns a boolean. The hitTest also might be a region and so you wouldn't know which x,y ofthis region to use.
You are probably going to have to detect if a hit has occured then interpolate between the 2 objects. without code its hard to help
hitTestObject() determiners if two objects intersect, therefore it's not a Point you can get from it - you can get the intersecting Rectangle.
Kenneth Kawamoto
