Convert an image file to Base64 or other string value
Guest
Nov 28, 2011 Nov 28, 2011
I need to read the content of an image file (JPEG, PNG, TIFF) and convert that file to Base64 string.
Does anyone know if you can do these things on Javascript, in InDesign?
Thanks for any help
EDIT: I forgot to add that I know my image path on the filesystem, it resides inside of my filesystem. I obtain that path thanks to InDesign...
Scripting
33.3K
Guide , Nov 29, 2011 Nov 29, 2011
You need:
    var file = new File(pathFile);
then
    file.encoding = 'BINARY';
OK. Let's try this:
var base64Encode = function(/*str*/s)
    var ALPHA = 'ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/=';
    var n = s.length,
        a = [], z = 0, c = 0,
        b, b0, b1, b2;
    while( c < n )
        b0 = s.charCodeAt(c++);
        b1 = s.charCodeAt(c++);
        b2 = s.charCodeAt(c++);
        var b = (b0 << 16) + ((b1 || 0) << 8) +
Guide ,
Put the image path in a File object, set the encoding to 'BINARY', use myFile.open('r') and retrieve the binary string in a variable: var s = myFile.read();
Then, use base64.js (or similar lib) to convert the string into B64.
http://www.stringify.com/static/js/base64.js
Marc
Guest
Hi and thanks
The encoding is set with this code: var file = new File(path_of_file, "BINARY"); ?
Guide ,
You need:
then
OK. Let's try this:
    var n = s.length,
        b, b0, b1, b2;
    while( c < n )
        var b = (b0 << 16) + ((b1 || 0) << 8) + (b2 || 0);
        a[z++] = ALPHA.charAt((b & (63 << 18)) >> 18);
        a[z++] = ALPHA.charAt((b & (63 << 12)) >> 12);
        a[z++] = ALPHA.charAt(isNaN(b1) ? 64 : ((b & (63 << 6)) >> 6));
        a[z++] = ALPHA.charAt(isNaN(b2) ? 64 : (b & 63));
    s = a.join('');
    a.length = 0;
    a = null;
    return s;
var fileToBase64 = function(/*File|str*/f)
    var s = null;
    if( f && (f = new File(f)) && (f.encoding='BINARY') && f.open('r') )
        s = f.read();
        f.close();
    return s && base64Encode(s);
// Client code
var b64 = fileToBase64("my/path/to/image.jpg");
Marc
Guest
Nov 30, 2011 Nov 30, 2011
Thanks a lot
Guru ,
Feb 02, 2012 Feb 02, 2012
Hi Marc,
I have tried to run the above script so I can embed a graphic in a script but when I try to display the graphic I get the message "file or folder does not exist" (BY THE WAY IT DOES EXIST THERE)
The graphic (very small and boring) that I have tried the script on is at the link below.
https://www.sugarsync.com/pf/D6923127_8087569_696676
I copied your script exactly only changing the end bit to my file location and then placing the b64 into indesign to make it easy for me to copy.
// Client code
var b64 = fileToBase64("c:/image.jpg");
app.selection[0].insertionPoints[0].contents = b64;
I then copied it into my script and it gives the above error message.
When I try to display an image of your "sprite buttons" it works fine.
So I guess I'm missing out the file encoding stuff.  What am I supposed to do?
#targetengine "myNewSession"
w = new Window("window", undefined, undefined, {resizeable:true, borderless:false} );
// This is the 64 bit string that I got and dosen't work 😞
pic = "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"
// You should recognize the string below 😉 It works :-]
//pic = "\x89PNG\r\n\x1A\n\x00\x00\x00\rIHDR\x00\x00\x00_\x00\x00\x00Z\b\x06\x00\x00\x00\xDE\x81\x8AF\x00\x00\x00\x19tEXtSoftware\x00Adobe ImageReadyq\xC9e<\x00\x00&\xA2IDATx\xDA\xEC}\x07\x98]U\xB9\xF6\xB7O\x9Bs\xA6\xF7Lo\xE9\x99$\x932)$\x01\x12j\x80\xA0R\fRr\xF3\x03\xA2 \x8A\x8A\\DE\x05.W\xAFr\xA5\t^.z\x7F\x89\xBF%RE@BK\b\x81\xC4\xF4\x1E3\x93I&\x99\xC9L\xA6dz9}\xEF\xFB\xBD\xDF.\xE7\x9C!&g&\xF0?\x8F\x8F\xB3a?9\xE7\xCC\xDEk\xAF\xF5\x95\xF7+\xEB[k+\xB3\xBF\xF4\xDFt\x8A\xC3\xC3\xE7\x97\xF8\xBC\x9A\xCF\xE9|\xA6\xD3\xE81\xDC#\xC8gm(\xAC\xAE\xCFJ\xF5<\xB3\xE6\xA77\xEDu:\xEC1\x17\xD8\x0Bf-\x1Bz\xD3\xF9|\xFE\x96\xCF[\xF9,\xE3\xD3=J\xC7\x11\x1D\xA0t\xAEMQ\xE6\xF4\r\xFA?\xDB\xD4\xDEg\x9F\\\u009A\xB3)51!rA\xFE\xEC+\xA2oX\xCE\xE7K\x06\xD1\x95Q\xFA}\x12\x87Bv\x9B-eW]\xCB\xC5\xEFm?RvnU\xE9\x9F3R<\x9AN\xFCY\x16\xF1\xE7\xF1\xF9'\x03rF\x8FO\xEC\xD0\xE4t\xBB\x1C\xD4\xD6\xD5?\xA3\xE9d\x9F{\xE9\xDCq\xEF2C\x98\xF83/'\x03Z@\xF8\xE2Qb}Z<\xD0(\xC1e\xA7\x83\xC7\xDA\x16\x16\x8FI\x7F\x7FJY\xEE1\x9BF\xF2\xDF\xB5|\xCE0>\x8F\xFE\xF7i\xFD\xA73@Y\xB5f\xC7\xFD\x03\xBE 9\xF8\x17\x18\x86\x9B?5\x93\x1F\n\x83\xE9d\xB3)\xE4\xB0\xDB\f!\xD0\x04\x0B\x15\xE5L\xC2\xA2Q0\xAC\x8A\xE6\xDA\xF9^\xBB\xED\x1F\xDF\f%\xB0\xC7s\xF0h\xDB\x92\r\xBB\xEB\xAB\x1C<\xC0\xA9\xFC[\xF5\xA7\xF5\xB0\xB2\xBCt\xE6\xB6\x83\x06\xBCA:\xD1\xD1+\x8C\x00\x115M%\x15La\x0Eh\x7F\x87\xF0\xB8\xAF<?C\x18w\xB2{\x90\xBA\xFA\xBC\xF2\xF9\x1F\xDE\rb9zg\xEB\xA1\xCBX\xF2\xD5\xC5\xFC=\xF5\xAC%\x1C\x12\x8A\x86\x99\x98*\x13N\xE5\xAFN\xA7\x8D\x96\xCC\x1AK\xF9Y\xC9t\xA8\xB1\x83\xFE\xF0\xEE.*\xCCI\xA3\x0Bg\x8F%\x7F0D\xEFl\xAD\xA3~o\x80NE\xCF0\xB7\x97\x9A\x98H\x9FY8\x99\\\u008C\x95\xEF\xF1\xB5\x9B\xF6\xF7Q\x82\xD3~F\xEF\x02\x8C\xD3\xB5K\xF7\xD9l\x8A\xCD0|C\xFF\xA6P\xFC\xBCTt\xE8P5\xE3VEN:\xA5\xE8\x9C\xFE\xB0q[-\x9D}\xF3\x00;S\xCF\xD6\x96s \xC1\x12\x9AI\x13J\xB2)=\xD9C\xFE@\x88\x1AZ\xBBi\x7F}+\x05\x98\xC8\x01\xFE\x1E\n\x85\x98\xA0aa\x04\xAE\r\xF1\xE7\xED\x07\x9B\xA8\xA7\x9F\xA5\xD9\x80\xA3\xA1\x06Jc\x0E\xE2~<\x05\xF7\xF2\x0F|\xDA\xCE \x04a\xD6\xB6\fZTUF\nwn\xDF\xD1V\xDAQ\xDBD.\xBB]\x9E\x99\x9F\x95B\x8BY \xA0A5\xC7\xDAi\xDB\xC1\xE3\x16\x1C\x9E\t>\xAB\xC6\xE7\xD3\xB4\x8A<\xF9~\xE8\xF8I\xDAr\xA01\xAE{\x87\x1EN\x87B\xF5M\x1D\xA5\f;j\xEE\xD9J|\xF5\xA4\":\xB7\xAA\x82\x1B\xB5\x89\xD4\x83\xB39\x19I\x8Cm\xAD\x02/\xBA\xB3\xA5qG1\xE0Vrr\x87!\xF9Mm]PA\xEB\x1A\x95\x89m\xDA\x07SB\xA3\x8D\x95\\\u00C7g\xD8\x92>\x1D\xB6\xA2\x0FU\r\xB3\x00$PAv\xAA\xDC\xE3c\xA6\xEF>\xD4\xC4\xFD\xC2}a*e\x18+\xCAM\x93\xE7\xF4\x0E\xF8\xE4w-Jxu\xAD\xD5Dc\xEC\xAC1f\xF3\xAA\x16\x16\xA2\xE5s\xBB\xF8\xAD\xA1\xB5K\x9E\xA5\r\x9F\xF6\xA21\xFD^_\x120\xDF1R\xC2C\x92J\xC7\xB0\x94M/\x93\x88\xAC\xAD\xB3\x9F>\xDA[O^\x7F\x10\x81\x05\xF9\x02\x01=R\xD3D\x90\xE53$\b\xC4\xB0\f/\x9F\xD0\x1C\x18\xD4\xAC\xD4D\xB9\xAFo\xD0'p$7\xE1>\x8D\"\xCC`b\xA5'\xBB\xE5:\xDC\x87k\xA3\xE3A\\\u00E3Ip\xB0\xA6\x85\xE5\xEF\x99)\x1EBT\xD9\xCD\x1A\xE6`\xA6\x16f\xA5R\x90\x19\x0Fz\xBB\x9D\x0E&p\xA4\xED03?5\xC9MIn\x970\xB8\x9BmL\x80\x99\xE7d\xADA_\xBC\xBE\x80\xB4\x0B\xE2{\xFD\x81X\b\x1B\xA6\xDB\t\xB9qX 6\x12\xC8\xE1[+\xCB\xC7\xC8\xA00\xD0\x0Fw\x1F\xA6\x03\f5.\xC6e\xF4\t\x9A\x10E=\x86\x9F M*\xCDa;0N\x06\xFA\xC6G\x07\xE8XK\x17\xE5\t\x14\x8C\x13iM`\x82\xC0\xB0\xBE\xB4n\x0F\xB7\x19\xB2\x82\x14\x9C\xB8\x7Fri.]2o\xA2\xFC\xF4\xD6\xE6\x83\xD4\xD5;\x10\xAB\xFA\xCC\x9C\xA4\x04\xA7\x0E[|&\xF2\xE7\\\u00D6\xC2\xB6\xCE^\x1A\x93\x99B\xD9\xE9\x89bO\x14\xEE3\xFA\x89>\xFAYX\\l\xDC\xCF\x9B1\x8E\xFB\x97K\xC9\x1E\x97\x8C\xA7\xB5\xAB\x9F6\xB20\x1Dm\xEE\xD4\x89\xEF\x0FZ\xB6\x03\x8C\x00,\x926r\x07\xC0\x16\x91\xA8\xE1\x9D\x80\b\x0F\x1B\xC2\xEC\xF4$QU`\xF7qVE7\xFF\x06o\xC6\x1E\r\x1DQ\xF7\x00zRxp8a\xC2\\<\xF8K\xE6N\xA4\n\xB6\x03\x81`\x98\xF6\xD45SKG\x8F\xA55\x96T\xB2\x96\xE1\x9E\x05\xD3JE2\x0F\x1Ek\xA1Z\x860\x1D\xB6\"\xCF\xC0=I|\x1D\xFA\xD4\xD1\xDD/D+d\xA6\x8A\xBD\xC9N\x11\x83\xDDn\xFC\x9E\xC0\xCF\x86\xE0\x80\x19\x80\xCD\xF9\x95%\fE^z\x9B\x99Z\xDB\xD0&\xF7]6\x7F\x92h$\x98\x01&\xE1Z<\xC7\xCF\x82@#\xA4\x9Dy:\xC4\x88\x8D\xE0\x00!\x13\\.Jt;E\xCA\xFBY\xFD\xFD\xC1 \xBCw\x03gb\xC3k\xBEC\xA4\x12\xD2\x126N\xA8?\\I\x18A?\xAB\xF7\x07;\x0F\xD1\xCE\x9A\xE3\xE2b\xA2M\x10\x9B\f\xCC\x07\xF1\xE62q\xC6d$\xD3q\xB6\x15\x1Bv\x1E\xD6=\x15M\xB3<\x0E\f\xC8\xC9p\xA4\xDF\xAF\xD1\x91\xE6\x93\x02#\xD0(7\x13\xBD\x98=-\x10\xED(\xFF\x0E\xA1\xC1uPNh\x03G\x9CB\xF877\x1E\xA0F\x16\"00\x83!\xAB07\x9D&\xB2\xB6\x9E8\xD9-\xE3\x0B\x86B\x923\xF3\x81\xF8tv\x92\xEF m\x84\xA8#\x86Uw-\xF1\x19\x86K\xFCK\xC5\x16\xA19\xC5\xA0\x86\x85\xE1\xE6\t\xE9\xCCc(\x10\fe\x8C?v\xA2S$\x13D\r\xA9\x9Au=pvla\x163)M0~\xED\xD6\x1A\x1A\xF4\xF9Yk\xEC\x14\xDD\x7F\xC0\xA0\xC3\xA5\x072 \xC9\x89\xF6\x1E*\xCAI\x17X\x03\x03\xF0\xAC\xB6\xAE>&d\x8F\xDC\xE7\x00\xA3\xF8y\xF0\xD0\x90{9q\xB2\x97\x06\xBD~\x11\x86D\xD6.\b\x18F\x93\xC7\f\x87m\x80\xD7\x86va\xE4\x83B|\xA2\x11\xD3\x0F\xC4\xD7F(\xF9$\xAA\x17\x10\xC3\x83\x9C\x85\x87\xB1\x15^\n:\x1C\xD3'-Bmy\x16N\xC5\xF8\x8D?\xBB\xD98b@!\xF6\x1C\x82\xC1`Dk\xA4_\x9A@\x13\x9A\xCCH\xF5H\xDC\x10dh\x82\xDB*Z4D\xEA\xC0L\xA7\xDD)\x06\x17\xFD\xE8\xEE\x1B\x10\x89-\xE1@o\xEA\xD8<JeC}\xA0\xFE\x04\xF5\xB1\x97\x03\xCD`\xDAK\xBF\xA1\x01\xD0D`\xFD\x17.\x99\xA5\x8F\x85\t\f\x8C?z\xA2\x83\x19\xD6+\xD7\x06x\xBC\r-\x9D\x84\xBC<\x98\xAF\x98c\xFA\xFFM|H+\xA4\x04X\x9F\xC6\x83\x82\x07\x92\xC3\xAAlv\x0E4\x87!\x8C\xF6R\"g\x04\xF7t\xC3\xA5K!\x8C\x9F\x8F\x07\xAC\x18\x11\xB0\x85\x8D\xDC\xDE\xFE\xC3\xCDL\xC4L*\xCB\xCF\xA2sg\x8C\xA5W\xD6\xED\x12\x02G{\x9A\x804H0\x9E\x0FxA\x8C\xD0\xC8\xFD\xA9\x9E\\B\xE3\x8Ar\xA4-\xD8%\xD8\x13\xDC\xEB\xB4;\xD8 #\xFA6\x99\xA1\xD0\xBE\xBA&\xB69\xAC\x01\xDC/\x9C\x88Y\xE0\xF9`, \xF8+\xEF\xEF2\xA2TI\x15\x9F\x15\xF1m\xA4\x99\xEA=\xFC\x13nc]c\xABH\t:\xB2pz\x85`)<\x8C\xB4\xA4\x04\xF1\x83cp\xC6\x90f\xF3\x84\xE4@2\x01Y\x90\xB6\t\xC59\xDCf0\xE2\x9B\x8A\xFF\xAF\t\f\xC1\xA6l;pL\f_)\x1B\xE7\xE9\xE3\x0BtM\x89\xEA\x0F\b\xEAN\xD0\r>\xE2\b\xD8\t\x18\xEF>\xC6rxQ\xC0tH\xB1\xCA\xBF\x831@H\xD8\x84\x16\x86!0\x1D\xDE\x0F\\\u00CB\x1A6\xE6\x88Az\x11\x00*\x92\x0E\x90\xB6\x92\xD8\xBE-[TIW-\xAE\x12a\x13o\xEC,\xE8\x07\xC9\x1F1h\xC1XAR\xC63\xD1JY\"\x8B\xD9\xE7\xBF\xFE\x92ji\x1B*\xFF\xE2{;\f\xA81\xE9\xA9\xC6\xE0>\x88t\xE4x\xBB\f\xBE\x80\r\xDB9\xD3*\xA8\x94\xA5\x1B>\xFF\x1B\x1F\xEE\x95\x01+\x86\xA7\n\xAD\xA8a\xC8h\x9CT,\xD2?\xAF\xB2\x8C\x8E6\x9D\xA4Nv5\xEDf\xC2\x8E\x89\x0F\xC6\xC3\xA3\n\x85\x82r\xBF\x8Fa\xB1\x95\xDD\xCC\xAC\xB4$j\xE5\xE7\f\xB2\x94\xDB<n\xD1\f\x85\xDC\x94\xC21@Gw\x1F\xED=t\x9C\xE6O+g\x97w<\xB7\x9F\xC9\xFD\x1F\xE4\xF8\xC0C\xE9lt\xD1\x97f\xB6\x1F3&\x16r\x94[$AR\x07\xDB\x8E\xF7w\xD4\x92\xCDIg%\xF9}#\xE5\x9C\"F(Hol\xD8\xC3\xB0\xD0\xC4\x10\xE2\x17\t\x86\xBB\x19\n\xA9b\x10\xC5@\xD9H\f\x97Ix\xF9n#1b \xCE\x9B\x1F\xED\x15&\xA0\xBD\x8A\"=E\x81\x00\b\xC4\xC4u\x90PhW\x80\t\xBAy\xEF\x11\xF18\xD2\xF8\x9AE3\xC7\xE9A\x92\x1A\x91\xFCdO\x82<\x17nk \xA8\xBB\x86\xC7\x9A;\xA4\xED\xA3\xFC/\xAE\x85\xCD\xC0\t\xA9Nf\xC3\x8A\x88{\xC3\x8E\x1Az\x7F[\x8DhIEA6\xCD\x99\\&L\xC0s\x01e\nK@+\xC3QgO?\xF50c\x9A\xDA:A\xBC\x11K=\x8F\xCD\xAFL\xBE\xE6\xFE\x87\x98,\xDF?\x9Bi23-\x00)\xF1\xF0`\xE0\x9Dtq\x07\x11\xA6g\xA7'\x0BfC\xD2:{\x06(\x91\x89\x93\x96\xA4O\x0Bw\xF6\x0E\x8A\xFA\xE3~Hofj\x92\xFC\x0Bu\xF7\n\f8\xE47HZ\xDF\xA0\x97\xB19 \xF7I\x9B\x86\xB4\x9Fd\x9F\x1D\x04&\xDD\xE9\xA2\x14n\x1B\f\x00VC+p\x00N\xD0N\x07??hD\xA8\x19)I\x12X\xC1\xDD\xC5u\xB8\x17\x11{2kE2C&R\x0Bp'\xFB\x07\xFD\x92\x96@rN\x8F\x80=b\x1B\xA0\x196\x9BmD\x8958\rS*\n\xD6)\x93\xAF\xFE\xDER\xFE\xFE*\xFAx\xB6\x99\xCD\xB0\xAA\x1A\x81\x8E\"\x1D\x04\xD1\xCC\xA0D1\f\x94\xE4N\fb\xE1\xBBbXL\xCD\xC8\xA9\b\xC6\xF3\xEF\x92j6B~\xD1\x16\xBB\xCD\xCA\xE3\x80H\x16\xF4\xD9\xED\x1F\x8B?` \xC5\x0EE\xCD\x1F\x84\x8D\x14\x86\xF9<\xAB_Q\xD7Er;\xAA\x95\x83\xB1Y\xD9\xCB\xC8\x18u\x83k\x1B1\x9D`\xF0\x17V\x8D\x7F\x1C\x98\xBF\x91\xBF\xD7\xF19\xE5l\x89/A\x8F\xD5Q\xCDr\xE7\xCC\xDC\x0B0\x1F\x9F\xEC\xF6\xD8k\xAC\xFB\xADk#\xBFG&PN\xF5\x1B}\xCC\xDB\xC0\xE3\x1Dv\xE5c\x7F\xD3\x9F\x19ich\xBF\"zLC&m\x86\xF4Q9\xF5s\xE3\xC7\tv\x06\xFC!:w\xD6\x84w\x80\xF9\x98\xE1X}6V{\xF4\x8C\xFF\x84\x87\xC4\xC6\xBF\xE6\xE2\xF9\x95\xEB\xCC\bw\x15\x9F\xF7|\x12\x93*\xA3\xC7\xE9\x83#\xD8\xB3\x1B\xAE\x9D\xFFtyA\xB6\xD7a\xA8T\x03\x9F\x0F\xF0\xF9\xE8(\x85>\xB5\xF2\x1D\n\xB0\x13\xC1.\xF9\xA6\xDB\xAEY\xFCK=\xB7\x13\xB1\xD6\x8F\xF1Y\xC5\xE7\xCAQJ}\xE2\x02/\xDE\x97\xD7\x1Fh\xB8\xEF\x96+V\x14\xE6f\xF8N\x95X\xBB\x8D\xCF\x1E>\xEF\xD2Fi\xF6I\t\xBCD\xDB\x19)\xC9[\xFF\xED\xCEkV^uA\xF5a\xCBS\x0B\xB3\x010\xA7\xCE\xF8\xDF \x7F\xFC:C\xD1\xAB\xEC~\xDD\xCA\xFE\xF9\\\u00BE\xA6\x90O\xCFh\xED\xE0\x88H\xDF\xC1n\xF1~\xB7\xCB\xF9\xFC\xEF\x7F\xF2\x95_O,\xCB\x1F\x8C\xC9\x10\xA4e\x8D\x91\x9C\x05\xA2\xCAT\x0E.\x10\xCD\xB16\xAC-\xCA\xCBN/.\xC8I\xF2\xF9\x83\xE9\xC1\xB0\xEA\x81\xEF\xAC\x89\x1F>z\x9C\xB6\x9C\x80\xFF\x0F\xC3\xAB\t\xA9!\x7F(\xDC\xD0\xDA\xD1\xF3VOO\xEF\x8BC\t/\xACY\xFE\xE0\x0BT\x9E\x97N\x13Kr\xA4\xB2\x80\xA3\xC3%\xEC\x13?\x16\b\x84\xAB\xFA\xBD~\x1Ad\x9F\x14\xD1)&\xCAUu\x94\xF4\xF1Ts\xA8\x92\xC2P\xC9\x8B\b\x99\xA3\xF2\xD6\xAE\x81\xAE\xB1\xF9\xE9\x8F\xDCx\xF1\xF4\xFF\xC8\xCBL\xB6\x88\xA8\xDC\xF5\xC4\xEBT\x96\x9FA\xC59\xA9\x94\xE4IX\xCE\x01\xC6*\x0E\xC1\xDD\xBD\x1CVw\xF5\xF9d\xF2\xC2\xEB\x0FID\xA8j\xA3\x92\x7F&|\xD7\xAC\xA9O\x92H\x1B\xE9\x13\xD0\xB2\xB1\xB5\x07s\x17\xAB\x9E\xBCk\xD9-\x15\x05\x19\x12\xA19r\xD2\x12ev\x9F\x89>\x8F\xF1\xE99\xAF/\xECF\xCE\xA5\xB1\xBD\x87Z:\xFA\xA9g\xC0\xCB\xE1\xB0\x9E\xD3\xD6F\x89\x1F7\x13\x90\x1BBT\x8DT\x89^\xEA\xA2Q\xED\xD1\xD6\x95\xFF\xFE\xEB\xB7Z\x9E\xF9\xF6\xE7\xEF\xC3\x9C\x83#\xD9\xE3D\xBE\xDA\xCD\x1Cz\xC6\xEB\x0Fz@\xF8\xBA\xA6\x0E\xAAo\xEE\xA4\x0E\xFE\xEC\x83\xD4\xAB\xEA\xD9\xCC\x96\xFDS\xBA\x96RS\xC4\x84G\x86\x15I\xC0@(L\x1E\xA7Fk6l\xBF\xF7\xA5\xEA\xF27\xBFp\xE9\xBC\xF5\x98\xBCG\x8A\xF6Z5\x1C\x9E\x01|:z\xA2\x8B\xEA\x1A\xDBQK.\x13\x0BQUw\xA3G\xBC\xB8\xAF\xC9\xD4\xBAL\xDA\x84\x91\xBA6\xA6W\xC3A?9\x95\xA0\xF2\xEC\xEA\xBF\xDC\xBF\xEC\xDC\xAA\xF5\x8EP(d\xF7\xF9\xB4\x9B1Ct\xB2g\x80\x8E\xB7u\xCAD\x81\xDF\x1F\xF8\x98!\x19\xC9\x81\xA98\xD8\nd\x01\x91\xEB'\xC3 \xD1)\xAA\xCD\x86\x1E\xB8n\xD0\xE8\x07f\xA2 E\xFFH\nh\xCD\xD9\xA9\x86\x1DPC\xE4\xB4i\xB4{\xDF\xC1%\xEFm\xDCQ\xE5\xF0\xF9\x03S\x03A\xA5\x1A\xB8~\x92\x89\x8EZ\x17\xAF\xDF7\xE2Z*\x0B\x9E\x14][P(\x8BJ\x80.\x86\xB0\xED\x07\x1B\x05\xC2\x90\xA7\x87$\x04UM&2\xB4\xBFCxLx_X=N\xBEC\x1B\x8F0\x1C:\x1C\xB6a\xF5\xE3T\xFC=\xDD\xDF\xCE\xA6\xDD\xD31A/\xD7\b\x93\xC6q\x95\x12\x0E\xD8_{{\xFDe\x8EA\x9F\x7F1\x12j\x90\xD0\x9E\xBE~\x1A\x18\x1C\x94Y\x1Ee\x98\x1C\xC6D\xB8\x9E\xCE\xB5\x0B\xE1\x02\xFC\x90\x14\x8F\x9B\x1E\xBE\xFD\n\xCA\xCDH\xA1\xDD\x87\x8E\xD3\xB2\xBB\x9F\xA1\xB9SJ\xF9\xB7+\xD9\x8B\xF2\xD3}O\xFD\x89\x9A;z\xF4r\xBC!\x07\x84aJN.=\xFE\xCD\xAB\xE5\xFB\x13\xAB\xD7\xD1\xCF~\xF7\x9E\xCC`\x9D\xE9P\x8D\xFC\xBD\t\x97\x8E\xA8U\x80`\xBE\xE92\xDB\x86\xE4\xF2\x87\xD3.\xD2\xCE\xB6a\xE6\xF4\xA5(\x00\xF3\xDAZ\x88\x1A\x8F7\xCFs\f\x0E\xFA\xA6\xA29T\"\f\xA0\xF0\xC9\xEFg\xEE\xA8q\x83\xBC^\xBD\x15\xA2\x0B\xE7N\xA2\xCB\x17N\xA5\xB1E9R\xC2\xB7q\xCF\x11\xFA\xE3\xDB\xDBd&\b\xC4\xC7\xCC\x14\xDA\xAE\x9ETL\x93\xCB\xF5J\xDF\xF1E\xD9t\xB4\xB9\x9D\x1C\xEES\xCC\xE3\xB0\x8A\x86\xA5@I?\xA4Z\xD9\xEC\xFC\x19`\xEE\x829\x13\xE9\x9B7\\$\xDF_]\xBF\x9B~\xF5\xCA\x87\x94\xE8qI\xBC2kR\t\xFD\xE06}\x05\xE6[\x9B\xF6\xD3/^X\xCF.\xA03.\xF8\xBC\xF9\xCA\x05t\xF5\x053\xE5\xFB{[\x0E\xD2\x93\xAB\xD7\xC6uo\f\xF1\xC3\x80\x1E\xA2\x9A\x9A\xDAR\x87\xD7\xEF\xCF\x85 \xF0\xBF2\x9F\x1A\x96\x95$j\\ \xAFiz\xC1\xE8\x9D\xCB\x97\xD0=+.\x89\xF9\xDB\x8C\xF1\xC5\xF4\xF2\xBB\xDB\"\x13\x11(`u\xDA\xE9\x95u;\xA4\xCA\r\x95\x04\x9B\xF6\xD41\x96\xDB\x84\xA0\x90F}\x15\x8B^*\x82\xDFb&,\f\xC2\xC3\x88\x05\rG\x00R;\xB4D\x1BZ[\x9E\x9FE\x95\x15\xF9\xBA\xA4\xF3\xF5\xAB^\xFB\x88\x90F\x81\x1D[R=\xD1\xFA[\x87LAr[\xAA\xCD\x1A\x0Ff\xC9`\xFF\xA0\x15p\x07\xCD\xC5\x18h\x17e&\xE6\xBD[\xF7\x1F\x95\xEA\t\xF4?^\x07\x14s\xD28\x15-L\xBD\xBD\xDDI\x0E\xBF?(ieT`\x85d\xC29\x18w\xE5\xAD\xD7\x17\xA4\xF3fO\xB4\b\xDF\xD8\xDAI?}\xEE/2W\xEA\x92R\x8D\x81\x98\x99(\x85\xC2\xE4\xF3\xF9\xE8\xB9?\x7F(\xDFAL\x85\x89\nw\x16\x85K\x93\xCAr\xE5\xBE&n\xA7\xA5\xB3W02ZjT\xE4\xA1\xB8\x7F\xE5\x05Yr\x1D\xA0\xAE\xA9\xBD+\xD6p\xB3Jg\xA6F\xA0i\\q.\x15q\x00\x89\x12AL\xEC\xCF\xAB,\xB5\xFE\x96\x91\x9AHXk\x01C\b\x82\x83\xF9E\xB9\x19\x94\x97\x9D&\xDA\\\u00CF\xF7\xF4\xB3\x90`^Z\xE1v;z\xFA\xAC{\xBBz\xFB\xE4>M\xB5\xC7M|\xC1|5$\xE3`\x15\xB0!\xB1\xA6i\xC6\f\x8B\xD4\x9B\xABzyG<\xE4\xC7\xF5\xD7/\x9Dk\xC1\xCF\x8F\xFF\xE7uz\xFE\x9D-2\t\r|\xC4Dv\xB4a\xC0@\xAE\xBDp6}\xE7\x96e2W{\xE7\x8F\xFF\x1F}\xB0\xBD\x86fN,\xA1\x07\xEE\xB8\x8A\xE6T\x96\xCB|)&\xDA\x97\xDF\xFB\xB4hb\xB4\x9A\xF5\xF5\x0F\xF0\xFD\xB3\xE8\xC7w]+\xDAq\xF7\x7F\xFE\x81\x8E4\xB6\xC6\xA8>\xFA\x8Fjd\xF3\x80\xB1\x9F>\xBE\x90\xF6\x1Dj\xA4i\x13\x8AiRy\x81\xF57\x94\x8D\xA0zA\xCAD\x92\xDCt\xEF\x97?CW\x9E?\x93\x7F\xD7'\xF8Q\x91\xF1\xD8o\xDF\xA2w7\xEF\x97\xF1u\xF5\xF4G\x88\xCF}\xB4\xE8\x15\xA7\xF3\xAFK~\xD8\xC2~\x1B\xD4\x12\x13\xDA\xC0y\xF9W\x8D\xEF\x84\x1Af\xB2\xE4TV\x14J\xDB(\xC1\xDE\xB8\xAB\x962\xA4\xEC\xC3.\xA7\xC9H\x9D\xF6\x9A@\x06\xDC\xCD\xAC\xF4d\xCANO\x91\xB2\x0FT\x1C?~\xEF\x8D4wj\x85\xD8\x85\xD7\xD6\xEF\xA4\x9D\x07\x8FJ\xDDO\xF4T*\xF0\xBA0'\x9D\xEE\xBBy\x19\x134\x81^_\xBF\x8B^{\x7F\x87^\x8E\x1E\xD5/\xB4\x99\x9B\xA9O\xC8\x1Df\xC6\xE08g\xDAX)m\x9C;\xA5L\x9E_{\xACE~\x07\xC1QZ\x88\x12\x93\x1F~\xF9\xB3t\xC3e\xE7P+;\x00\x0F>\xF3\n\xBD\xFB\xD7}T9\xB6\x90~\xFE\xED\x9BX#\xF3\xA4D\x06%#\xE6\xD1\xC3\xFD3\x0B\x7F\x87wjzM\xABQ4eL/\xA2:,R\xCEw\xA6\x03X\x89Lh\x8E!e(>\x1D\x18\xF4\x8A\xE4FJ\xFDb\x8B\x95\x05:\xA2$\x05\xE5w\x17\xCF\x9FB\x13Ju\x03\xFC\xE03/\xD3\xAF^~_<\x1Ax%E\xB9\x91-\x1F\x80\xAF\xDF\xBC\xE9\x12\xCA\xCFIc\xA2\xB6\xD1C\xFF\xFD\xB2\x94w+\x14\x89\xBE\xCD\x85\x11(\x13\xC1\xF1\xF6\xA6\xBDtk^\x16\xCDa\xC6\xA6\xA7\xB8i\xE1\x8C\xF1R\x99\xB6v\xCB~yfzJ\xA20\xAFrl\x01]ua\xB50\xF8\xCE\x7F_E\x1F\xEE\xAC\xA11Y\xA9\xF4\xEE\xB3\xDF\xA1\x8A\xA2\\6\xB2\xB3i\xDB\xFE\xC3\xD470(\xFDB\xCC\xD2#\xC21\x8CZMM1\xAE\x8D*\x83\x8C\xB5\xAC\xD1%\xC5gh\x8B9\x88\xDC\x85\xB9\x99\x03\f\x95f\x14R\xC5\xB6\x15\xF9\xAE\xAB\xA8\x16\x05[*\xCD\x9A\\&\x9FQ\x0E\xF8\xC1\xB6\x83\x94\x96\xE4\x11#j\x96v\x98\xC7\xD2\x85\xD3\xF9\xDAr\xF1\xCA\xBE\xF3\xC4j\x89I\x92\x18\xD6\xA2\xAF\x01a\x92\x18JR\rwt\xFB\x81zZ0c\x02\xC3N1\xCD\x9F6\x8Ef\xB1\xE4\xEF?|\\~\x17W\x93\x89\b\x01*+\xCC\x91\xEF(\x8Aj\xEB\xEC\xA1\xD9|\x1D4S5\xDA\x9E1\xB1T\x82\xBC~\xAF\xCF*#\xC1\xE7H*m8AB\xA4|\xDB\xA1\x18\xD1\x90\xE4#(\xB6F\xE5t\x07\xEAh\xE0F\xC2\xADDGs\xD8\x9DLp9%\x87!\xB5.d\xAC\xD8\x8B\xC2<E\xFCb%\n\x06\x15\xCALK\xB6`E\x96\x13\xD9u\x0FC\xB1\xC5\xF6e\\I\x9E`;\\>\xC4\x00\xB6\xA8\x9A\x9F\xE8\x03\xF6&\xCBh\xB3\xBE\xE9$K\xEC\x11\xAA\x9APB7^\xBE\x80\xF2\xB3\xD3\xE9\x85\xB77Ky\xA2y\xE40De\x18\x9A2&+\x8D\xFE\xF2\x8B\x7F\x95\xFB\xD1>\xC6\x06f\xED\xADk$\x17\x8F\r\xE3\x85\x80\xA0\xF0\x0BN\x05\xEC\x8E\x12w\xB4\xA5\x8F\xC9\x8C>A\x19\x87^1(\xA5Jz]\x9Eb\x8F\x8B\x9B\x884\x91\x8Eh8\xD1)\xC4/d/a\xEA\xF8\x121\xA0\x90HL(HAST\xE7\x14[\xECw<\x0B\xC6\x15\x87\x9B\xB1?%9\x91z\x06|\xC6u\xB6H\xAD?\x1F\x7F|k3\x9D?{\x12Mg\xA3\xF9\xC3\xDB\xAF\xA6\xEB\xEF\xFB/}\xF1\x9D-\xBA\xE0Ief\xA6\x88w\x82j3\xCCEl\xDC}\x98n\xBDj1-]T%\xD7l\xE2\xF8\xA3g\xC0o\x15Leg\xA4\xB1\x16\xE9\x86\x14Z\xFC\xC7\xB7\xB6\xD0\x8E\x03G\xE9dw\x1F\xB5\xF3\xD9\xD7\xEF\x95\x18\xC3\xEDJ`fx\xE9_\xBE\xFF\xAC\x10\x0Enn\x82\xD35\f\xB9W\x8C1\xE9\f\xC0}6\xB3\x8E\xD8L\xC5A:\xE39mLX\x7F0Lk6\xEE\xD5\x99\xC1\xDF\xEFc/\xA6r\\\u00B1HSYa\xAE0 \x8A\xEF\x1F\x93f\x10nWM\x83|Nb#\nO\xC3\xC7m\xEA\x12\x15+\xD9X\xD4\xF0\x8B\x17\xD6\xCAg\xC0\xC2\xCD\x9F;\x8F\x89\x1B\x8C\xE9\x13\x9C\xD9\xAC\x8CT\x03\xC6\xFC\x92\xCA\xDD[\xD7$\xDE\f\b\x8B\x82\xD9\xBF\xD5\x9F\x90\xDF1Q\x84\xA3$?\x9Bvq\xF4\x1D\x96\xBAPE`\xED\xF5\r\xBBi\xDB\xDF\x8E\x8A\x1Ds:\x9D\x94\x90\xE0\x92\xC5\x1AcXs~\xF9\x83[h\xD5\xC3_\x12[\x10\x84\xCF\x1E'\xBD\xAC\xB1[kwYp\xD8\xBF\xD5\xD0\xB0\xC0\xB1b\x93\x9AD%\xCE3\xD1\xE3\xE1(v+\xED\xAEm\x94\x81\xCC\x9CTJ\xAF\xFF\xFC\x1B\xB4\xE6\x17\xF7\xD0S\xDF^\xC1\xAA\xEA\"3E\xA4?\xDC\x11#\xCD\x1E&\xF8{\xDBj\xA8\x8E\r(\x8E{V^F/\xFF\xECk\xF4\xBB\x1F\xDFNy9\x19lG\"r\x93\xC4p\xF2g\x8EVw\xD5\xEA\xCC\xBA\xF3\xBA\x0Bh\xCA\xD8b\x11\x00\x19\x1C\xB7\x8Bz\xB8\x1C\xC3\xD3A\xF0\x87q!;\x8B\nd\x1C`t\x07Ko0\xA4\xCA\x02\t\x1CEc2\xA9\xEEx;\xFD\xE1\xCD\xCD\xF2\xFD\xBB_\xBC\x92\xDEx\xEA\x9B\xEC\x81\xDDD\xBF\xFB\xD1\xED\xF4\xDA\x93\xDF\xA0\xB1\fy}\xDE\x00]\xB9x&]\xBA`\x1A-\xAE\x9ED_`\xCF(\x10\xD4\xE2\xA6\x95\xA2\xD8\xA3V\xED\xE8\x86\xDA\xE6\x0B\xAA}\xFE \x92\\:\f(v\x07_\x13\xDF\xE9t8i\xC0\x17\xA6;\x7F\xB2\x9A5`\x9F\xCCz\xB9\x19\x1B\xE1\xAD\x00\x97S\x93\x93\xAC\x00H0\x9A\xEF\xB1\xDB\"A\t\xA4\xAAw @\xDF\xF8\xCF\xE7%b\x84@\x9C3},\x95\xB2\x87\x92\x91\x9A\xA2Ca\xD4\xB5>\x1E\xEC\xCFW\xAF\x13\xC8@\xC1\xEA\xF7\xBE\xB8\x8C\xED\x00|r\xBB\xB4\x8D\x7F\x0B\x98i8PT;\xC8}\xC3\xC2\x9E\x0Fv\xD6\xC9o\x1F\xEC\xC0\xBF6\xF2\x87\xCC\x95\x85$^M\x92'\x91~\xF4\xEB5\xF4\xD4\x1F\xD7\x89\xD1=g\xFA8\xBAa\xE9<\x86\xB9\x89b\x83\xD0\x17\x87\xC3E\xFB\xEAN\x88\x16\r\xB0vl?\xD0\xC0}r\xC5M+\xC5\x1C7\x1C\x13\x0E\x14\xD5P\xD0\xAF\\p\xC7c\x0F\xF1(\xBF\x0F\x1A\x01'A\xC0px\x18H\x86\xD2m\xACke\x82\x94r\xE4\t7\x0F\xEE\\}s\x87x@\x13K\xC6H50:\x8C\xCCd\x0E\xFB\xF8\x05\x86\x0B\x89\br\x80\xE1\x01F\x1A\xDEDEa\xB6\x18m,xC\x164\x99=\x17\xE4\x8Ap\xB4\x88'\xD2'\xBE\xFFD\xF6\xBB\xCD\xD0\xBF\xE6h\xABD\xA3\xE8?l@\x01\xC7\x02\xA8\xC5\x87a>\xCC\x12\xADkM\x82\xB4\x8D\xEF\xF8\x1D\x02Q\xCE\xDF\x11\x80\x81\tG\x8E\x9F\x14\xD8\x81\xD1\x073\xF29\xC2\x05\x8Cb\xD5\r\xA0\n\xED\xCB\x84\b\x8F\xB3hL\x86|\xC6r\xA1S%\x04\xFF~\xF2Q\xA3`\x7F\x17\r\xB6\x1F\xA5\xAE\xE6\xC3\xAC\xB5\x85\xEB\x94y7?\xB2TU\xA5T\xC4%+\xB6\x03\xC1a\x11?\xBAy\x84\xE7\xC0S\xC5\xCC\x8B(\xFA\n\x11s\xC9\r\bl\x86\xF18\x90\"\x90%\xA3\x86\xEB\x1A0r;Nc\xF6\x07\xF9\x1E\x7FPO\xAEa\xA00\xF2f\"O3\xFC&\x97\xD4\xCE+\xFAr_E_dm\xE6f\xE4o\xA4W$\xA3m\xF8\xF4\xFAR\x1E=Q'\x06\x1B\xD79\x1DQ\xF1\x8B\xAA\xBB\xCD\x14\xD9)\xC5\x16\x05\x95\x92\x7F\x92%\xAC\xC3[;\x8E\xB4\x88\xBF\xBB\x85\xFA[\xEA\xA8\xA3\xA9\x8E\x16/\x98\xF3\xB8\xC3\x1B\bm\f\x87\xC2u\xEC:N\x01$\xC8\xE2}\xBB6\xA2%\x8E\x18\xEC\xD0\x03\xCBtb\xBD$\x10\xD1\xF9\xB19O@\xA2\xDB\xEE\x18\xE2\xCE\xB2]\x18\xF2\x1B\b\xECv;N=q*\xF0d\xE73\xF6Ov~\xA6'\xEA\x99h#!\xE1\xD4R\xEB\xE0\x87:\x9C\xCE\xD3\x8C\xD1><\xA2(FR\x10\x15 \xDE^\n\f\xF6Ph\xA0\x8F.\xBDx\xC9;\x0E&|\xAF\x16\x0E\xAC\x0E\x85\xB4\x87T\xBB\x93\x07\xEC\x94\xFAi\xC5n\xF8\xA4\xA3s\xB7gY\xCE\xA0I\"-\xC8D\xF7\xF7\xB4\x91\xAF\xAF\x932s\xB2k>\xBBl\xE9:\x89pY%V\xA9A\xFF=\xAA\xCD\x96js\xBA\xC9\xCE\xA7\xA2\xB8,7\x89F\xB6\xB3\xC9?}\r\x89\x9E\x89\rP`\xA0\x9B\x06;\x1A\xC9\xD7\xD3B\xDE\xEE.\xBA\xED\xEB_yz|E\xB9\xD7!\xC4\xD5\xB4\x86p\xC0\xFB\x00[\xE1G\xA1\xEBv\xA7\x87\xEC\t\x1E\x9D\tv\xD3R+\xA3\x93\xE8qM\x17\x1A\xE6\x95\xA5=\x1C\xF4\xE9F\xF6\xE41\x1Aho oo\x0F\x95TTl\xBA\xFBk_\xFE\xA5\x01qN!.s\xE9\xB1\x90o\xA0*\x1C\n\xAC\x94X\x00\xBF\x0B\f\x19\x06m\x94\xF4\xF1\xFB5\x98\xAA\fq\x9C\xE1\xEB'\x7F_\x07\x05\x07:\xC9;\xD8OA\xBF\xBF\xE1G\x0F~wEiq\x91\xCF\">$\xDCfw\x81\x01\xB7\x85\xFD\xFD=a\xFF\xE0]\xAA\xB9\xE3\x87\xF6I\xD40\xFC\x13I\xBE\xB1~X&~\x82~\x99<\xC1\fZnV\xF6\xD6\xEF\x7F\xE7\xEE\x957.\xBF*R\xA5l\xE3\xE0\xC1\xE1N\"W8\x03\xF8\x14T\x03\xDE\xAF\xB3qx\x95\xCF[\xB5px.\xB7$U\xCA\xDAh\xD5\xD4\b\xA0_\xAFRNMI~\xFE\xADWW\xFF\xBAr\xF2\x84\xD8*e\xCD\xB0\xC6\xE1\xA0\x97\xC2\xAC&\xA1\x80\x17\xB3,k\x99\x8D\x1C\tiX\x87\x99\xCE\xB8\xE4\xB1YI\xA1\xD1#\x9E\xC0\x931;ds8\x1B\x14\x95\xDE\xCA\x1A\x93\xFD\xE2P\xC2\xCBuS\x97?D\xDE\xAEf\xEA;QK\xBE\xAE\x13\xC0\xAA%|\xF7cl\x88\xABl\x8E\x04r$$\x92\xCD\x99 vAQl\xA3\xD8\x1F\x8F\xA7c\xA6\xE6\x91\xAEa\xBA\x055\xA5\xEB\xAA\xA5\x8B\x1F\xB9\xFF\xAB+\xFE\xA3\xA4 'R\xA5<\xEE\xD2\xAF\xB2%\xAE\x97\xB0W\r\xF9\x97sp\xB5\x8A=\x1C\xB73)\x9D\\)Y\xE4t\xA7\x1A\xC4\x8FM\xF1\x8E\x1E\xA7\xA1}\x8C\xF1\xD5\xF7\x1A\xC2B\xB8\xB2\x92\xA2U\xAB\x1F\xFD\xD6-\xE3J\xF2d\xFAK)\x9Aw-\x13\xFF(\x85\x06{\xE6\xF1\xC5\xEBX\xDA=\xEE\x8C<\xF2d\x15SBj6\xBB\x9CIb\x8C\x15\xDB(\xE1\x87g}\xF5)S\xA9V`\xCF\x07\xC9\xB4\xEE\xDE\x01\xBAda\xD5O\xFE\xE7\x81/J\x95\xB2\x92=\xE5|\n\xF4\xB4\xB99\xD0\xDA\xC4\xC6w\x86'\xB3\x90\x92\xF3\xC6\x93;3\x9F!'Y\\M}\x12 \x92\x97\x1F=N\x9F@\xB3\\\x1Fs\x8B\x9B\xB0\xCE\x00\x9C]\xBD\xFD\xDAcw_\xB7d\xF9\xC5\xB3\xD7;\xC2\xDE>\xE6P\xE8Z\xC5\xE6\x98\xE1J\xC9\xA6\xC4\xEC\x12\xF2d0\xE1\xDD)VpEQET\xA3>\xCF\xF0\x00Hr\xF9\x0E=m\xA3\xB1K\x9F\xA28\x95Uk\xB6\xDF\x7F\xC5\xB9\xD3\x98\xF8!\xBF\xEC\xA5\xECp'\x93;-\x97\xA1&G\xA2[\xC5\xD8\xBEk\x94\xDCg\x1F\xEF\x9A\x9F\x01\xDD\x89\x89ITs\xBC{\xC9\x86]G\xABdGY\x86\x9BjgR*\xC1\xC8\xDA\xD9\xE7G\xF2_\xFB\x84\b?h,\xAE@j\x16{\xE1Hu\\H5\x8Ajm\xA7u\xD7p\x1F\xEE\xC7=\xD8\x02F\xDF2\xF2\x1FW\x18\xCC2\x13\xBBB\xF6\xB7\xB7\xD6\\\u00E6P\x14\xFBb\xF6fR\x81\xEF\x0E1\xAE\xCE\xB8+\xD6\x86\x1E00F\xE9\xBD\xE4\xC2q\xDErq%\xE5e$Q\xDD\x89nzec\xAD\x10\xB5$'E\xF2\xEB\xAD]\x83\xFAV`\xA7h\x0B\xDB\xC6\x8CIO\xA2\xE5WL\x94\xED\x1F\xD7\xEDi\xA4\xAD\xB5-\xC2\x803){t51f\xD0\xCC9\x03s\xAB\xC8\x90\xB9\x93\x89\xB9UW\x9C \x12S\xE1<\x8C{#\xC4\xD7\x0B\xA6l\xCC\x84\x13\xED\xDD\xF3\x1C\x8A\xDD6\xD5\xCE\xAE\xA4\xDD\xE5&D\xBB\x98k\x1C\xAE\xD4\x87\x8DI\x0F\xEC\xA3\x83\xED\x18\xF1\x19\x8B\xE9\xB0!\xDD\x95\xF3\xC6\xD2\x94\xB2\x1CZ\xBF\xEB\x18\xFD\xE6\xDD}t\xC9\xAC2zx\xE5\"\xC2\xFE\xF1w?\xBB\x8Ej\x9B\xBA\x84\xB8C\x0F\xEC\x89\x9C\x9E\xEC\xA2\x15\x17N&O\x82\x8BZ\xBA\x06\xE8\xC3\xFD\xC7\xF9\xDA3,\xA8\xD0Hv\fLK\xF3\xC8\bP\x8A\xEE\x0B\xE8{\xEC\x80\x1D\x98<\x19\x93\x9E(\xFF\xA2\x0F8\xE3\x89\x1DU\xD9j\xD2i-\xF0\xC0\x181\x05:\x9C\xB8S1\f0J\x9D\x8E4\xB5\x97:\x18br\x15\x10]\xF2\xF8v\xDDZk\xE1\xF8\t\xCF\x12\x06\xB7i\xE5eU\xB4\xA4\xAA\x94ry`\xD8\xE5i\xDB\xA1\x16z\xF4\xE5-\xB2\x14\x12\x05\xAD\x83\x81\xA0\xD46b\x00X\x80\x07\x89G\xE1*J\b5\xFB\xA9]5l2\xD4\xEF\r\xCA\xC0\x03\xB2\xA3`\xD8\xD8\xEE\xFFt0\x17\xA4\xF3\xA6V\xD0\x0FW,\x12\xF9y\xFE\x83\x83\xF4\xD8+[\x04\xF2\xBC\x81\x10\xFF\xAD\x98\x99\x7F\x9E<\xFF\xE5\x8Fj\xE9g/m\xD6\xD7\x1E\x9F\t>\x99I7,\x99D\xB7\\Z%Z\xF0\xE2\x875\xF4\xE8K[\xA4Bn8\xB0\xA3iz\xBDH\xFF\x807\x89a\xC7\xE6\xB0\x19\xB3\xFF\x8A\xC1\x9Dxg\xB1Tc\x07\xD7{??\x8F>\xB7`\x82\xA8d{\xCF\xA0>\x9F\x9B\x9B*\xE5\xE6\xD1G\"k\xC2;\xDB\x0FS\xF3\xC9^Y\xA3Z\xD7\xDC\xA5\x97Xk\xAA\xD8\x01k\x1A\xD1n\x8F$\xA9\"=7\x12Va\x99\x9C\xC7_\xB0LH\xB6\f\xD6b\xB0\x8F\xB2R\xDD\xE4qa\xCAR\xA3Y\xE3\xC6P\x12\xB6n\x94\x89\xEB0\xCD\x9D\x90'\xDA\x89\xBE\x17e'\x1B\xE3U\x8D[5\x11\x1C\xC0\x12\\jh\xA4T\xE4\x19\xB3Q\x98\x94\xF7\xC8\xB4%\xC9<\xB5\xAC\x15P\x87\x11\xFF\x98{\x8F\xEA{\x92\xDA\xF4\xCD\xC3\xCCM\x7F\xAC}\"\x95\xB8@\x10\x93\xCF\x9F9g\x02]9\x7F\xBC\x10n\xD3\x81&\xFA\xE9\xF3\x1Be\xDD.\xA4:\x10\fP$6\xD3w\x85\xCD\xCAL\x92\x1AG\xD4\xBA\xA7%\xBAd\x8D*\xEE\xC5:\xE0Y\xE3\xF2e\x8F\xCE:\x86\xA2=GZ\xA3*\x80\x15\xEB~\x17k\xE9\xF9\xD3\xCAe\xF2\xBB\xA1\xAD\x9B\xF6\xD6\xB7\xC5\xEC\xFA\x84\xFEg&\xBBe\x1E\x1A\x84D\xBB\xC59\xC9\xECat\xC8J\xFBi\xE5\xB9\xB2\xA0\x1B\xBC\x84\x06\x82\xC0\xB2D)\xA4\x17\xF1\xCE\x99PH%c\xD2d\fh\xFBps\xA71\xC7\xAB\n\x84I}\x8Fl;\xE6\xB3\xB6\xAA\x1C\x9E\xE4\x1B\f\xD0\x13k\x16\xD9\xADz\x92\xB8\x88\xAF\x92\x14\xAA^4\xB3\\\u00A4\x15^\xC9\xB3ol\xA3\xFA\x13\x9D,\x1DN\xEA\xD2T\xDD8F\xED,;\xE8\xF7\xD3\xDC\x89\xF9\xF4\xE0\xCA\xC52\xD8;\x9E\xF8\x0B}\xB0\xF7\x18]1o\x02\xDD{\xDD\x02*\xC8J\x91I\xF6\xEE~\x1F\xDD\xF0\xA3\x97\xF4\xFD\x8A\xA3\x8C\xD5 K\xDE\x97\xAF\x98E\xDF\xBA\xF6\x1C\xA9l\xFB\xDASo\xCAd\xB7m\xC8\xDE\x9AYF}>\xFE\x96\xCA\f\x9ER\x92M;\x0F5\xD3\x94\xE2,*e\xC2\x0E\x1A\xC2\x91\xCC\xCC\xC0~\xD0\xA8\xE5\x19\x9B\x9FA\xDF\xBF\xE9<\x9A9>_:\x8B\xB9\xDC\xCE>/\xFD\xDF5;\xE97\xEF\xEC\x964\x01v\"\x97\xDD\xD0\xB1\xC7\x1A\xF7Q\xDF[n\x04\xC47\xEE\xB1\x11\x8Dt\xC7\xA40e$'\xC8`@\xDF\xE6\x93}t\xB8\xA9S$\x1A\x1E\xA4\xAC1\x8D^\x1DGQ\x1BZkd\xE1x>k\xC2=\x9F?G\xB6\xCC\xDD}\xB8\x95\xEE}\xF6mz\xE2\xE5M\xD4\xDC\xD1km\xD7\x85\x03j^Y\x96M+.\x9E.\xD5\tO\xBF\xBA\x856\xFF\x8D\r\xB0\xBE\x93\xB5\xF5\xB2\x03'\xDF\x93\x9D\xEA\xD1\xAB\xD5Xr\xF1\xEFl&(\xB4f\xE6\xD8<\x81\x8D=GZ\xE4\x16\xEC \x8BRv<\x07\xCC\x9F?\xA5\x88^\xFD\xE8ot\xDDC/\xD0#/|$\x86\xFB\xCE\xCF\xCE\xA1\xEA\t\xF9\"\b\xA8r3+4\xF0Y\x19\xE9\x8ES\x06\xCD\x1DV@\x1C\xB5\xEBk<\x92\x0F\xE3\x99\xE4v\xC8\xE6\x9Eh\xAF\xB3\x7FP\xB6^\xD4\xDF\x81\xA2\xBF\xBAC\x89\xB6\x1D\x9A.\x95Z\x14\x13P\xBE\xB1hj\x89\xEC\xF9\xD0\xCFF\xF9I&\xFA\xDA\x9DGd\xD9\x90\"\xD5s\x11\xB8\x07\xB6\xDFqe\xB5\xB8\x9Fol\xAE\xA5\xD5k\xF7\x88\xD4FK\x1E0\x1B6$\xC5\x93 \xB8\xBCi\x7F\x03U\xB0DW\xB2\xB7\x85\x95\xF6\x90\xEA\x93l\x93\xB60\xD3\xAA'\x14\xC8\xE2\b\xC0N%kF\xF5\xC4B:\xD6\xDAM\x8F\xBE\xB8\x91\xB5\xB7\x8Bv\xD65\xD3\xB9\xDC\xB7\x85\x95%\xECH\x94\xD1\x07\xBB\xEB\xA5\xF6H*\xE4\x00;\xA8)\xA5\xB3\x90|M\xF6\xDB\xA1(\xAE\x98x\x14\x0F\xEC\x98\xC5\xFEd\x04\x0E\x8A.\xCE\x8AQ@\xA3Y\x9Eu\x84\xFAh;j\x89)\x16d\x8C+\xC8\x94\xBA\x98nvM\xEB\x9AN\xB2\xBB\xEA\x92\xAD}1H\x13\x1BQK\xB4l\xFEDy\xF9MCk\x0F=\xC1\x04\x82\x97%\xDA\xA5\xC6\x96\x9C\xBB\x9DN\xD9=\x05\xCF>p\xAC\x8Dj\x1A\xDBi\xC1\xD4RZ\xC0R=\xA54\x87\xB5\xA1\x85\x0E6\xE8\xE5\x89`h:_[\x9C\x9B&\x1E\x0F0\xBD\x84m\xC4\\f\x046\xB3\xC6\x8E\xE5(u\x19\xCB}t\xD9\x15)A\xD4\xBD4\x87|V\xCC1\r\xDB\xE0\x9A\xC4\xB76\x99\xD6\xA2\xDE\x84pf\x1F\x1F\xF4\xEDe\xDC\xEB\xC4\x92\x1A\x86\x9F\\\u00D9\xC6\xD7\xCE~s\xC0(L\xD2b6\x9A\xD6\xAC\b\xCFd\x8A\xBEX\xC0m\xD4\xC1\xA8\x9A\x16\xB5A5\x89K\x16\x1D\xCDBK\x007\x90V0\xAC\xFED\xC7\xC7|~xB\x89\xDC\x1E\xB6\x12F\x9C\x80j3`\xFD\xE2\x19\x15\xF4\xB9s\xA7\xC8Z-\xBC#\xA5S\x96\xF4\xE8\xC5Yx\xC5\x07\xA4\x1Fp\x92\xCB\xC4~\xF4+\x97\xCBs\xFBX\xCA\xF1^\x94\x0F\xF7\xD43\xC3Z\x05\x9A\x90\x16\xFE\xD5\x1B[\xC5.\xB5v\xF6Y\xAF\x1C\x19\xB1\xC1\x8Dxt\xDA\xB0\xAC7\xFC\x8B\xAE\xDE~\xAAo\xE9\x92\x17\xD0\x14d\xA5\xD2\x1C\x96\x98?}\xB8_\f.\xC9\x92\x1Fg\xD4\xCA\x14\xCD \xA8\x1A\xC5\x10U\x06\x81kpm\x06CXGO\xBF\xBE\x11v\x941C\xFD\xE7\x9A\xCD5T56\x9F\xAE\\8\x85\xBEz\xF5|\xB6\x0FM\xF2Z\x8D\xD85\xB6a\x91d\xB7QK\x8F5];k\x9B\xC4+\xABf/\x06\xDE\xCF\xAECM:v3#\x93\xF0\xAA\x90\x147\xDB\xAB\x1E\xE9\x03\"\xE1\x87\x7F\xF3\x1Em\xAD9.\x1B\x8F\xC2\x1DF0\x95\xE0p\xE8+(\x99\xF8\xBF\x7Fw\xA7@+l\x90\xBEO\xFF0\x88o\xA0E\xC4\xE0\xC2\xD54_\x02\xA0\xAA\xF1\x9F\x9A^V\xF7\xC6\xC6\x03V\xAD\xFB\xD7\xAE^H\xD7\x9C7\x95\x16\xB2\x9A/\xE2S_;\xABEP,j\x8D\x96\tUX\x95\x0E\xA2 :\xBE\xE1\xC2\x19\xC2\x80\"\xBC\x14\xC6TS\xD2_\xA7\x84\xB6\x9E{s\x9B\xB8x\xE3\n\xB3\xE9\xD6\xCB\xE7\xE8\xA5\x88Q}\xC2\x9A2\xD8 xY\x03\xC6\xFBM\x0E\x1Do\xA7&\x8E+\xC0\x10\xBC\xC1\xE8\bjHY\xC3\xC0\x00\x10\x1B\xAF\x8E\xDA{\xB8\x99\x85\xA0_\x16\xC2-\x9CV&}\x84\x81\xCE\xE0>\xCD`\x86cs\x10\x10{bq6\xAD\xFE\xC1\r\xF4\xF2\xBF\xAD\x90\x97\xF4\x00z\x86E3U\x8DY\xC7\xC5\x11\xAE\xBDO\xD6QY\x92\x1F\x8E{\xAA\x10\x90\xB1v\xFB!z\xE1\xFD\xDDt\xFDE\xB3d\xDF\x9E\x9F\xDC~\x85`)\\\u00CE\xEB\x1F\xFC\xAD\xC0\x93^{\xA9\xC3\f\b\xE94\xF23\xF0&\xFE\xBA\xFF(\xBD\xBB\xAD\x96%\xBA\x92>\xBFd\xBA,\xF7G\x7FV>\xFC{!\xB8S\x02)]\xF2\xFEz\xA0\x9E\xDE\xD9ZK\xD7,\x9EN\xCB/\x98\xC1\x90p\x8460,H\x94\xA9\xE9\xEB\xC4\xB2\xD9\xB0b\x15$b\x07\xBC\xE9\x01\xC5\xAE\xFB\x8E\x9C\xA0\xAA\xF1\x85\xB4\x87\x89\x8C\xBD\x92a\xA8\xB1\xFC\x14Z\x93\x9F\x99\"\xF0\xF4_\x7F\xDAH\xF7\xFF\xCBEt\xE3\xC53\xE9\xBC\xE9\xE5\xD4\xD6\xDD\xCFm%I\xD1\xEDm?}\x9E6\xEC>\"Fy\x1A3\x03\xD49\x87\r\xF1\xC6\xBDGHs\xC4\x1Fd\xC9\x9A7U5\x10\x80\xFCl\xDB\xECu\xD6F\xC4\xE6\"\xDD8\x13\x16\xB2m/+\xCE#\xBF[+U\xC9\x17\xCD\x99\xC0\xD8\xAF\xAF6\xDF\xB8\xAF^\\\u00B1\x93\xDD\x03\xD4\xD4\xDE\xCBp2(\x84G\x950v\xE4\x96\x82\xD6\x90.\xB9\x0F\xAFz\x9B\x1A\xDB\xBAh\xD1\xF4\nY\x9DX\xDB\xD8&\x84G\xF2\n\x90\x80\x80\n\x8B\x16\x00\xF1\xCF\xBD\xB9\x85&\x97\x8D\x11M\xB9\xE6\xFC\xE9\f+\x8D\x02\x11\xB2X\x99\x99\x0B\x86\x02\xCA\x8E\xB5t\x92\xCF\xE7\x97q}\xB0\xABN\xDE\x89\xB2a\xF7a\xE9/\xDCF\xBCj\t\x8B\xE4d\xF3kf\xECK\xEF\xEF\x12&\\\u00CDmB\xB3\xF0\x9E\x14,\xC8\x80p`e>\x18\xF6\xFE\xCE:Z\xB8\xB5L\x96'\xAD\xF9\xEB\x01qk\x87\xF5\xDA\x13Y\x06\x1A\x96R\x92\xA9\xE3\x8A\xDA\x94\x9C\xCA\xC5K\x15\xBB\xE3UWb\x9A\xCB\x95\x94I\x0EOJ\xA4\x96<\xDE6Q\xDD\xCC\x04\xD7w\x10w\n\x1CA\xED\x11\x19\"\x15\xAC\xC8[\xE3\xF4\xF4\x01\x8C\xB1^Z\xAD\xA7\x96Uc\xBFd@\x0F\xFCn\xFC\xBD\xDF(\xE3\x96\xBDj\x1C6a2\xDA\x84\x7F\x8Dka\xF0\xCC\nb\xA4\x1A\xA2\xB7\x1F\x83\xD6\xC1{R\x8D\x94\x85i\xEC\xC1\x14<\xC3*\xDB\xE0\xEB\xB0!\x91\xB8\xBCF\x1A\x04^\x15R-\x89\xC6[0p=\x04\xC9i\xA4\x19\x82F\xFF1\x1E|\x1E\xD6.(\xB2\x89`HR\x12^\x9F\x8F\xCE\x9D5\xF9q\xD4\xEDl\xE4\xC1\xD51$L\xD1\x8C?\x0E\xB7D\x04WC\xF5\x01+X\xDEiB\n\x86\xED5\x162\x9B/\x14\x03\x0E\x07\x8D\xB2oY\xF8\xA6\xE7\xB7\x8Dt\x84Q\x0En\xD3_Z\t\x03\x1A\xF4\x85\xAC\xFC\xBEM\xD1\xF72\x8E\x8E|\xCD6L\x1F\xCA\x1F\b[f\xC5Z\xFD\x8Em\n|\xC6B=\xA3\xF6\xD7\xEF\x0F[}W\x8C\xEB\x12\x8CWL\x99\xED+F\xBF\x14\xC3\x8D\x85kk\xBE\xD4\f0\xAA\x0EK\xEAU\xC9-!9\bG\xE0\xBC\xEA\xC9\xEF\xD8\xEC\xCE\x84^\xB2\xD9W\xEBAP\xD8\xB8`\x84\xFB\xE9\x13Y\x042\x7F3\xBF\x9B\xB9t\x85\xB4\x98k,\xF76\xEAZk\xF3\xE8\x98\xFB?\xFE[t\x1B\x14\xF5\xAA&\xF3o\xD1\xAE\xF3\xDFmW\xA1!c\x88\xED\xF3\xA9\xDAW\x88\x86G\x1Bc\xAB\x17\bw0\x10\x80]\xAAY\xBAh\xE6:\x87\xDD\x95HJ(\xB0\x8A\xD9\x7F\x0Fs2u\xA8;8z\x9C\xF5\xF4\x95n`\rT\xE9\xE9\xEF\xA7\x9B>s\xF9\xD3\xE5Ec\xBC\x0E\x99\xAF\xB5\xD9\x1A\xD8\xF0=\xC0J\xF9\xA8\x95'\xD1T\x1A\xADW\x18!\xBD\xA3\xB4\xC9\xDAcG\r\xCB\x967\xE5\x059\x9Bn\xFF\xC2ez\x95\xB2\xDD\x91\x00\x9F\x05\x9Cy\x8C\x01\xB4\x8A\xF5p\xA5\x1E\x06G\"\xCC\xD1=\x05G*\xF1\x9A\xB9\xC7\x17\xE3\xBC\x1F\xDEW\xC3\xF7\xEE\xB8nEQ^\xB6^\xA5\x8C\xC9r\x1B\xF6\xBC\xD10wK\xB7\xB1\x1At\xB3\x16|]\xD3\xD4!;\x90\x8C2`x\x85\x0B\x9A\xB5o\x11\xE652\xD3R\xB6\xFC\xEB\xB7\xFE\xCF\xCAk.]\x18\xA9R\x96\x85\xCF\xA8)\xD4\xB3\xCBx\xF7\xD17\x98c\xAF\xF3\x9D_\xE1\xCF\xD5\xEC \xE5\xF2\xEF\t\xA3\xC4\x1F\x1E\xF5u;\xAF\xF5\xB2\xC7V\xC3\x91\xF3\xEF\x9F\x7F\xF2\xBB\xCFN\x1E[\x1CS,\xFB\xBF\x02\f\x001iY\x94\xC8\x93\x80\x9C\x00\x00\x00\x00IEND\xAEB`\x82";
w.add('image', undefined, pic);
w.show();
Regards
Trevor
P.s. I haven't figured out yet how to work with the scriptArgs to transfer variables to the doScript but I shall work on it more before I beg for mercy.
Guide ,
Hi Trevor,
Hey, you need to decode the stream! The Base64 format is a way to store binary data in ASCII, but ExtendScript cannot directly interprete this encoding—except in jsxbin, but this is another story.
So you have to reverse the encoding (see below). Anyway, in your case I don't see why you are using Base64 (?)
var base64Decode = function F(/*str*/s)
    var ALPHA = "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/=";
    F.cache || F.cache = {
        RE_NON_ALPHA: new RegExp('[^' + ALPHA + ']'),
        RE_BAD_EQUALS: /\=([^=]|\=\=)/
    if( (n % 4) || F.cache.RE_NON_ALPHA.test(s) || F.cache.RE_BAD_EQUALS.test(s) )
        throw Error("Invalid Base64 data");
    var    fChr = String.fromCharCode,
        n = s.length >>> 0,
        a = [],
        c = 0,
        i0, i1, i2, i3,
        b, b0, b1, b2;
    while( c < n )
        i0 = ALPHA.indexOf(s[c++]);
        i1 = ALPHA.indexOf(s[c++]);
        i2 = ALPHA.indexOf(s[c++]);
        i3 = ALPHA.indexOf(s[c++]);
        b = (i0 << 18) + (i1 << 12) + ((i2 & 63) << 6) + (i3 & 63);
        b0 = (b & (255 << 16)) >> 16;
        b1 = (i2 == 64) ? -1 : (b & (255 << 8)) >> 8;
        b2 = (i3 == 64) ? -1 : (b & 255);
        a[a.length] = fChr(b0);
        if( 0 <= b1 ) a[a.length] = fChr(b1);
        if( 0 <= b2 ) a[a.length] = fChr(b2);
    // Cleanup and return
    s = a.join('');
    a.length = 0;
    a = fChr = null;
    return s;
Marc
Guru ,
Hi Marc
Thanks for the decoder.
I am however completly confused.
1) I don't know what to do with it or how to use it (would be nice to know)
2) What I want to do is place a graphic in the script and for the sake of speed and portability not use another file.
I thought that one needed to covert the file into base 64 and that this is what you got the string in the line
Button = "\x89PNG\r\n\x1A\n\x00\x00\x00\rIHDR\x00\x00\x00_\x00\x00\x00Z\b\x06\x00\x00\x00\xDE\x81\x8AF\x00\x00\x00\x19tEXtSoftware\x00Adobe ImageReadyq\xC9e<\x00\x00&\xA2IDATx\xDA\xEC}\x07\x98]U\xB9\xF6\xB7O\x9Bs\xA6\xF7Lo\xE9\x99$\x932)$\x01\x12j\x80\xA0R\fRr\xF3\x03\xA2 \x8A\x8A\\DE\x05.W\xAFr\xA5\t^.z\x7F\x89\xBF%RE@BK\b\x81\xC4\xF4\x1E3\x93I&\x99\xC9L\xA6dz9}\xEF\xFB\xBD\xDF.\xE7\x9C!&g&\xF0?\x8F\x8F\xB3a?9\xE7\xCC\xDEk\xAF\xF5\x95\xF7+\xEB[k+\xB3\xBF\xF4\xDFt\x8A\xC3\xC3\xE7\x97\xF8\xBC\x9A\xCF\xE9|\xA6\xD3\xE81\xDC#\xC8gm(\xAC\xAE\xCFJ\xF5<\xB3\xE6\xA77\xEDu:\xEC1\x17\xD8\x0Bf-\x1Bz\xD3\xF9|\xFE\x96\xCF[\xF9,\xE3\xD3=J\xC7\x11\x1D\xA0t\xAEMQ\xE6\xF4\r\xFA?\xDB\xD4\xDEg\x9F\\\u009A\xB3)51!rA\xFE\xEC+\xA2oX\xCE\xE7K\x06\xD1\x95Q\xFA}\x12\x87Bv\x9B-eW]\xCB\xC5\xEFm?RvnU\xE9\x9F3R<\x9AN\xFCY\x16\xF1\xE7\xF1\xF9'\x03rF\x8FO\xEC\xD0\xE4t\xBB\x1C\xD4\xD6\xD5?\xA3\xE9d\x9F{\xE9\xDCq\xEF2C\x98\xF83/'\x03Z@\xF8\xE2Qb}Z<\xD0(\xC1e\xA7\x83\xC7\xDA\x16\x16\x8FI\x7F\x7FJY\xEE1\x9BF\xF2\xDF\xB5|\xCE0>\x8F\xFE\xF7i\xFD\xA73@Y\xB5f\xC7\xFD\x03\xBE 9\xF8\x17\x18\x86\x9B?5\x93\x1F\n\x83\xE9d\xB3)\xE4\xB0\xDB\f!\xD0\x04\x0B\x15\xE5L\xC2\xA2Q0\xAC\x8A\xE6\xDA\xF9^\xBB\xED\x1F\xDF\f%\xB0\xC7s\xF0h\xDB\x92\r\xBB\xEB\xAB\x1C<\xC0\xA9\xFC[\xF5\xA7\xF5\xB0\xB2\xBCt\xE6\xB6\x83\x06\xBCA:\xD1\xD1+\x8C\x00\x115M%\x15La\x0Eh\x7F\x87\xF0\xB8\xAF<?C\x18w\xB2{\x90\xBA\xFA\xBC\xF2\xF9\x1F\xDE\rb9zg\xEB\xA1\xCBX\xF2\xD5\xC5\xFC=\xF5\xAC%\x1C\x12\x8A\x86\x99\x98*\x13N\xE5\xAFN\xA7\x8D\x96\xCC\x1AK\xF9Y\xC9t\xA8\xB1\x83\xFE\xF0\xEE.*\xCCI\xA3\x0Bg\x8F%\x7F0D\xEFl\xAD\xA3~o\x80NE\xCF0\xB7\x97\x9A\x98H\x9FY8\x99\\\u008C\x95\xEF\xF1\xB5\x9B\xF6\xF7Q\x82\xD3~F\xEF\x02\x8C\xD3\xB5K\xF7\xD9l\x8A\xCD0|C\xFF\xA6P\xFC\xBCTt\xE8P5\xE3VEN:\xA5\xE8\x9C\xFE\xB0q[-\x9D}\xF3\x00;S\xCF\xD6\x96s \xC1\x12\x9AI\x13J\xB2)=\xD9C\xFE@\x88\x1AZ\xBBi\x7F}+\x05\x98\xC8\x01\xFE\x1E\n\x85\x98\xA0aa\x04\xAE\r\xF1\xE7\xED\x07\x9B\xA8\xA7\x9F\xA5\xD9\x80\xA3\xA1\x06Jc\x0E\xE2~<\x05\xF7\xF2\x0F|\xDA\xCE \x04a\xD6\xB6\fZTUF\nwn\xDF\xD1V\xDAQ\xDBD.\xBB]\x9E\x99\x9F\x95B\x8BY \xA0A5\xC7\xDAi\xDB\xC1\xE3\x16\x1C\x9E\t>\xAB\xC6\xE7\xD3\xB4\x8A<\xF9~\xE8\xF8I\xDAr\xA01\xAE{\x87\x1EN\x87B\xF5M\x1D\xA5\f;j\xEE\xD9J|\xF5\xA4\":\xB7\xAA\x82\x1B\xB5\x89\xD4\x83\xB39\x19I\x8Cm\xAD\x02/\xBA\xB3\xA5qG1\xE0Vrr\x87!\xF9Mm]PA\xEB\x1A\x95\x89m\xDA\x07SB\xA3\x8D\x95\\\u00C7g\xD8\x92>\x1D\xB6\xA2\x0FU\r\xB3\x00$PAv\xAA\xDC\xE3c\xA6\xEF>\xD4\xC4\xFD\xC2}a*e\x18+\xCAM\x93\xE7\xF4\x0E\xF8\xE4w-Jxu\xAD\xD5Dc\xEC\xAC1f\xF3\xAA\x16\x16\xA2\xE5s\xBB\xF8\xAD\xA1\xB5K\x9E\xA5\r\x9F\xF6\xA21\xFD^_\x120\xDF1R\xC2C\x92J\xC7\xB0\x94M/\x93\x88\xAC\xAD\xB3\x9F>\xDA[O^\x7F\x10\x81\x05\xF9\x02\x01=R\xD3D\x90\xE53$\b\xC4\xB0\f/\x9F\xD0\x1C\x18\xD4\xAC\xD4D\xB9\xAFo\xD0'p$7\xE1>\x8D\"\xCC`b\xA5'\xBB\xE5:\xDC\x87k\xA3\xE3A\\\u00E3Ip\xB0\xA6\x85\xE5\xEF\x99)\x1EBT\xD9\xCD\x1A\xE6`\xA6\x16f\xA5R\x90\x19\x0Fz\xBB\x9D\x0E&p\xA4\xED03?5\xC9MIn\x970\xB8\x9BmL\x80\x99\xE7d\xADA_\xBC\xBE\x80\xB4\x0B\xE2{\xFD\x81X\b\x1B\xA6\xDB\t\xB9qX 6\x12\xC8\xE1[+\xCB\xC7\xC8\xA00\xD0\x0Fw\x1F\xA6\x03\f5.\xC6e\xF4\t\x9A\x10E=\x86\x9F M*\xCDa;0N\x06\xFA\xC6G\x07\xE8XK\x17\xE5\t\x14\x8C\x13iM`\x82\xC0\xB0\xBE\xB4n\x0F\xB7\x19\xB2\x82\x14\x9C\xB8\x7Fri.]2o\xA2\xFC\xF4\xD6\xE6\x83\xD4\xD5;\x10\xAB\xFA\xCC\x9C\xA4\x04\xA7\x0E[|&\xF2\xE7\\\u00D6\xC2\xB6\xCE^\x1A\x93\x99B\xD9\xE9\x89bO\x14\xEE3\xFA\x89>\xFAYX\\l\xDC\xCF\x9B1\x8E\xFB\x97K\xC9\x1E\x97\x8C\xA7\xB5\xAB\x9F6\xB20\x1Dm\xEE\xD4\x89\xEF\x0FZ\xB6\x03\x8C\x00,\x926r\x07\xC0\x16\x91\xA8\xE1\x9D\x80\b\x0F\x1B\xC2\xEC\xF4$QU`\xF7qVE7\xFF\x06o\xC6\x1E\r\x1DQ\xF7\x00zRxp8a\xC2\\<\xF8K\xE6N\xA4\n\xB6\x03\x81`\x98\xF6\xD45SKG\x8F\xA55\x96T\xB2\x96\xE1\x9E\x05\xD3JE2\x0F\x1Ek\xA1Z\x860\x1D\xB6\"\xCF\xC0=I|\x1D\xFA\xD4\xD1\xDD/D+d\xA6\x8A\xBD\xC9N\x11\x83\xDDn\xFC\x9E\xC0\xCF\x86\xE0\x80\x19\x80\xCD\xF9\x95%\fE^z\x9B\x99Z\xDB\xD0&\xF7]6\x7F\x92h$\x98\x01&\xE1Z<\xC7\xCF\x82@#\xA4\x9Dy:\xC4\x88\x8D\xE0\x00!\x13\\.Jt;E\xCA\xFBY\xFD\xFD\xC1 \xBCw\x03gb\xC3k\xBEC\xA4\x12\xD2\x126N\xA8?\\I\x18A?\xAB\xF7\x07;\x0F\xD1\xCE\x9A\xE3\xE2b\xA2M\x10\x9B\f\xCC\x07\xF1\xE62q\xC6d$\xD3q\xB6\x15\x1Bv\x1E\xD6=\x15M\xB3<\x0E\f\xC8\xC9p\xA4\xDF\xAF\xD1\x91\xE6\x93\x02#\xD0(7\x13\xBD\x98=-\x10\xED(\xFF\x0E\xA1\xC1uPNh\x03G\x9CB\xF877\x1E\xA0F\x16\"00\x83!\xAB07\x9D&\xB2\xB6\x9E8\xD9-\xE3\x0B\x86B\x923\xF3\x81\xF8tv\x92\xEF m\x84\xA8#\x86Uw-\xF1\x19\x86K\xFCK\xC5\x16\xA19\xC5\xA0\x86\x85\xE1\xE6\t\xE9\xCCc(\x10\fe\x8C?v\xA2S$\x13D\r\xA9\x9Au=pvla\x163)M0~\xED\xD6\x1A\x1A\xF4\xF9Yk\xEC\x14\xDD\x7F\xC0\xA0\xC3\xA5\x072 \xC9\x89\xF6\x1E*\xCAI\x17X\x03\x03\xF0\xAC\xB6\xAE>&d\x8F\xDC\xE7\x00\xA3\xF8y\xF0\xD0\x90{9q\xB2\x97\x06\xBD~\x11\x86D\xD6.\b\x18F\x93\xC7\f\x87m\x80\xD7\x86va\xE4\x83B|\xA2\x11\xD3\x0F\xC4\xD7F(\xF9$\xAA\x17\x10\xC3\x83\x9C\x85\x87\xB1\x15^\n:\x1C\xD3'-Bmy\x16N\xC5\xF8\x8D?\xBB\xD98b@!\xF6\x1C\x82\xC1`Dk\xA4_\x9A@\x13\x9A\xCCH\xF5H\xDC\x10dh\x82\xDB*Z4D\xEA\xC0L\xA7\xDD)\x06\x17\xFD\xE8\xEE\x1B\x10\x89-\xE1@o\xEA\xD8<JeC}\xA0\xFE\x04\xF5\xB1\x97\x03\xCD`\xDAK\xBF\xA1\x01\xD0D`\xFD\x17.\x99\xA5\x8F\x85\t\f\x8C?z\xA2\x83\x19\xD6+\xD7\x06x\xBC\r-\x9D\x84\xBC<\x98\xAF\x98c\xFA\xFFM|H+\xA4\x04X\x9F\xC6\x83\x82\x07\x92\xC3\xAAlv\x0E4\x87!\x8C\xF6R\"g\x04\xF7t\xC3\xA5K!\x8C\x9F\x8F\x07\xAC\x18\x11\xB0\x85\x8D\xDC\xDE\xFE\xC3\xCDL\xC4L*\xCB\xCF\xA2sg\x8C\xA5W\xD6\xED\x12\x02G{\x9A\x804H0\x9E\x0FxA\x8C\xD0\xC8\xFD\xA9\x9E\\B\xE3\x8Ar\xA4-\xD8%\xD8\x13\xDC\xEB\xB4;\xD8 #\xFA6\x99\xA1\xD0\xBE\xBA&\xB69\xAC\x01\xDC/\x9C\x88Y\xE0\xF9`, \xF8+\xEF\xEF2\xA2TI\x15\x9F\x15\xF1m\xA4\x99\xEA=\xFC\x13nc]c\xABH\t:\xB2pz\x85`)<\x8C\xB4\xA4\x04\xF1\x83cp\xC6\x90f\xF3\x84\xE4@2\x01Y\x90\xB6\t\xC59\xDCf0\xE2\x9B\x8A\xFF\xAF\t\f\xC1\xA6l;pL\f_)\x1B\xE7\xE9\xE3\x0BtM\x89\xEA\x0F\b\xEAN\xD0\r>\xE2\b\xD8\t\x18\xEF>\xC6rxQ\xC0tH\xB1\xCA\xBF\x831@H\xD8\x84\x16\x86!0\x1D\xDE\x0F\\\u00CB\x1A6\xE6\x88Az\x11\x00*\x92\x0E\x90\xB6\x92\xD8\xBE-[TIW-\xAE\x12a\x13o\xEC,\xE8\x07\xC9\x1F1h\xC1XAR\xC63\xD1JY\"\x8B\xD9\xE7\xBF\xFE\x92ji\x1B*\xFF\xE2{;\f\xA81\xE9\xA9\xC6\xE0>\x88t\xE4x\xBB\f\xBE\x80\r\xDB9\xD3*\xA8\x94\xA5\x1B>\xFF\x1B\x1F\xEE\x95\x01+\x86\xA7\n\xAD\xA8a\xC8h\x9CT,\xD2?\xAF\xB2\x8C\x8E6\x9D\xA4Nv5\xEDf\xC2\x8E\x89\x0F\xC6\xC3\xA3\n\x85\x82r\xBF\x8Fa\xB1\x95\xDD\xCC\xAC\xB4$j\xE5\xE7\f\xB2\x94\xDB<n\xD1\f\x85\xDC\x94\xC21@Gw\x1F\xED=t\x9C\xE6O+g\x97w<\xB7\x9F\xC9\xFD\x1F\xE4\xF8\xC0C\xE9lt\xD1\x97f\xB6\x1F3&\x16r\x94[$AR\x07\xDB\x8E\xF7w\xD4\x92\xCDIg%\xF9}#\xE5\x9C\"F(Hol\xD8\xC3\xB0\xD0\xC4\x10\xE2\x17\t\x86\xBB\x19\n\xA9b\x10\xC5@\xD9H\f\x97Ix\xF9n#1b \xCE\x9B\x1F\xED\x15&\xA0\xBD\x8A\"=E\x81\x00\b\xC4\xC4u\x90PhW\x80\t\xBAy\xEF\x11\xF18\xD2\xF8\x9AE3\xC7\xE9A\x92\x1A\x91\xFCdO\x82<\x17nk \xA8\xBB\x86\xC7\x9A;\xA4\xED\xA3\xFC/\xAE\x85\xCD\xC0\t\xA9Nf\xC3\x8A\x88{\xC3\x8E\x1Az\x7F[\x8DhIEA6\xCD\x99\\&L\xC0s\x01e\nK@+\xC3QgO?\xF50c\x9A\xDA:A\xBC\x11K=\x8F\xCD\xAFL\xBE\xE6\xFE\x87\x98,\xDF?\x9Bi23-\x00)\xF1\xF0`\xE0\x9Dtq\x07\x11\xA6g\xA7'\x0BfC\xD2:{\x06(\x91\x89\x93\x96\xA4O\x0Bw\xF6\x0E\x8A\xFA\xE3~Hofj\x92\xFC\x0Bu\xF7\n\f8\xE47HZ\xDF\xA0\x97\xB19 \xF7I\x9B\x86\xB4\x9Fd\x9F\x1D\x04&\xDD\xE9\xA2\x14n\x1B\f\x00VC+p\x00N\xD0N\x07??hD\xA8\x19)I\x12X\xC1\xDD\xC5u\xB8\x17\x11{2kE2C&R\x0Bp'\xFB\x07\xFD\x92\x96@rN\x8F\x80=b\x1B\xA0\x196\x9BmD\x8958\rS*\n\xD6)\x93\xAF\xFE\xDER\xFE\xFE*\xFAx\xB6\x99\xCD\xB0\xAA\x1A\x81\x8E\"\x1D\x04\xD1\xCC\xA0D1\f\x94\xE4N\fb\xE1\xBBbXL\xCD\xC8\xA9\b\xC6\xF3\xEF\x92j6B~\xD1\x16\xBB\xCD\xCA\xE3\x80H\x16\xF4\xD9\xED\x1F\x8B?` \xC5\x0EE\xCD\x1F\x84\x8D\x14\x86\xF9<\xAB_Q\xD7Er;\xAA\x95\x83\xB1Y\xD9\xCB\xC8\x18u\x83k\x1B1\x9D`\xF0\x17V\x8D\x7F\x1C\x98\xBF\x91\xBF\xD7\xF19\xE5l\x89/A\x8F\xD5Q\xCDr\xE7\xCC\xDC\x0B0\x1F\x9F\xEC\xF6\xD8k\xAC\xFB\xADk#\xBFG&PN\xF5\x1B}\xCC\xDB\xC0\xE3\x1Dv\xE5c\x7F\xD3\x9F\x19ich\xBF\"zLC&m\x86\xF4Q9\xF5s\xE3\xC7\tv\x06\xFC!:w\xD6\x84w\x80\xF9\x98\xE1X}6V{\xF4\x8C\xFF\x84\x87\xC4\xC6\xBF\xE6\xE2\xF9\x95\xEB\xCC\bw\x15\x9F\xF7|\x12\x93*\xA3\xC7\xE9\x83#\xD8\xB3\x1B\xAE\x9D\xFFtyA\xB6\xD7a\xA8T\x03\x9F\x0F\xF0\xF9\xE8(\x85>\xB5\xF2\x1D\n\xB0\x13\xC1.\xF9\xA6\xDB\xAEY\xFCK=\xB7\x13\xB1\xD6\x8F\xF1Y\xC5\xE7\xCAQJ}\xE2\x02/\xDE\x97\xD7\x1Fh\xB8\xEF\x96+V\x14\xE6f\xF8N\x95X\xBB\x8D\xCF\x1E>\xEF\xD2Fi\xF6I\t\xBCD\xDB\x19)\xC9[\xFF\xED\xCEkV^uA\xF5a\xCBS\x0B\xB3\x010\xA7\xCE\xF8\xDF \x7F\xFC:C\xD1\xAB\xEC~\xDD\xCA\xFE\xF9\\\u00BE\xA6\x90O\xCFh\xED\xE0\x88H\xDF\xC1n\xF1~\xB7\xCB\xF9\xFC\xEF\x7F\xF2\x95_O,\xCB\x1F\x8C\xC9\x10\xA4e\x8D\x91\x9C\x05\xA2\xCAT\x0E.\x10\xCD\xB16\xAC-\xCA\xCBN/.\xC8I\xF2\xF9\x83\xE9\xC1\xB0\xEA\x81\xEF\xAC\x89\x1F>z\x9C\xB6\x9C\x80\xFF\x0F\xC3\xAB\t\xA9!\x7F(\xDC\xD0\xDA\xD1\xF3VOO\xEF\x8BC\t/\xACY\xFE\xE0\x0BT\x9E\x97N\x13Kr\xA4\xB2\x80\xA3\xC3%\xEC\x13?\x16\b\x84\xAB\xFA\xBD~\x1Ad\x9F\x14\xD1)&\xCAUu\x94\xF4\xF1Ts\xA8\x92\xC2P\xC9\x8B\b\x99\xA3\xF2\xD6\xAE\x81\xAE\xB1\xF9\xE9\x8F\xDCx\xF1\xF4\xFF\xC8\xCBL\xB6\x88\xA8\xDC\xF5\xC4\xEBT\x96\x9FA\xC59\xA9\x94\xE4IX\xCE\x01\xC6*\x0E\xC1\xDD\xBD\x1CVw\xF5\xF9d\xF2\xC2\xEB\x0FID\xA8j\xA3\x92\x7F&|\xD7\xAC\xA9O\x92H\x1B\xE9\x13\xD0\xB2\xB1\xB5\x07s\x17\xAB\x9E\xBCk\xD9-\x15\x05\x19\x12\xA19r\xD2\x12ev\x9F\x89>\x8F\xF1\xE99\xAF/\xECF\xCE\xA5\xB1\xBD\x87Z:\xFA\xA9g\xC0\xCB\xE1\xB0\x9E\xD3\xD6F\x89\x1F7\x13\x90\x1BBT\x8DT\x89^\xEA\xA2Q\xED\xD1\xD6\x95\xFF\xFE\xEB\xB7Z\x9E\xF9\xF6\xE7\xEF\xC3\x9C\x83#\xD9\xE3D\xBE\xDA\xCD\x1Cz\xC6\xEB\x0Fz@\xF8\xBA\xA6\x0E\xAAo\xEE\xA4\x0E\xFE\xEC\x83\xD4\xAB\xEA\xD9\xCC\x96\xFDS\xBA\x96RS\xC4\x84G\x86\x15I\xC0@(L\x1E\xA7Fk6l\xBF\xF7\xA5\xEA\xF27\xBFp\xE9\xBC\xF5\x98\xBCG\x8A\xF6Z5\x1C\x9E\x01|:z\xA2\x8B\xEA\x1A\xDBQK.\x13\x0BQUw\xA3G\xBC\xB8\xAF\xC9\xD4\xBAL\xDA\x84\x91\xBA6\xA6W\xC3A?9\x95\xA0\xF2\xEC\xEA\xBF\xDC\xBF\xEC\xDC\xAA\xF5\x8EP(d\xF7\xF9\xB4\x9B1Ct\xB2g\x80\x8E\xB7u\xCAD\x81\xDF\x1F\xF8\x98!\x19\xC9\x81\xA98\xD8\nd\x01\x91\xEB'\xC3 \xD1)\xAA\xCD\x86\x1E\xB8n\xD0\xE8\x07f\xA2 E\xFFH\nh\xCD\xD9\xA9\x86\x1DPC\xE4\xB4i\xB4{\xDF\xC1%\xEFm\xDCQ\xE5\xF0\xF9\x03S\x03A\xA5\x1A\xB8~\x92\x89\x8EZ\x17\xAF\xDF7\xE2Z*\x0B\x9E\x14][P(\x8BJ\x80.\x86\xB0\xED\x07\x1B\x05\xC2\x90\xA7\x87$\x04UM&2\xB4\xBFCxLx_X=N\xBEC\x1B\x8F0\x1C:\x1C\xB6a\xF5\xE3T\xFC=\xDD\xDF\xCE\xA6\xDD\xD31A/\xD7\b\x93\xC6q\x95\x12\x0E\xD8_{{\xFDe\x8EA\x9F\x7F1\x12j\x90\xD0\x9E\xBE~\x1A\x18\x1C\x94Y\x1Ee\x98\x1C\xC6D\xB8\x9E\xCE\xB5\x0B\xE1\x02\xFC\x90\x14\x8F\x9B\x1E\xBE\xFD\n\xCA\xCDH\xA1\xDD\x87\x8E\xD3\xB2\xBB\x9F\xA1\xB9SJ\xF9\xB7+\xD9\x8B\xF2\xD3}O\xFD\x89\x9A;z\xF4r\xBC!\x07\x84aJN.=\xFE\xCD\xAB\xE5\xFB\x13\xAB\xD7\xD1\xCF~\xF7\x9E\xCC`\x9D\xE9P\x8D\xFC\xBD\t\x97\x8E\xA8U\x80`\xBE\xE92\xDB\x86\xE4\xF2\x87\xD3.\xD2\xCE\xB6a\xE6\xF4\xA5(\x00\xF3\xDAZ\x88\x1A\x8F7\xCFs\f\x0E\xFA\xA6\xA29T\"\f\xA0\xF0\xC9\xEFg\xEE\xA8q\x83\xBC^\xBD\x15\xA2\x0B\xE7N\xA2\xCB\x17N\xA5\xB1E9R\xC2\xB7q\xCF\x11\xFA\xE3\xDB\xDBd&\b\xC4\xC7\xCC\x14\xDA\xAE\x9ETL\x93\xCB\xF5J\xDF\xF1E\xD9t\xB4\xB9\x9D\x1C\xEES\xCC\xE3\xB0\x8A\x86\xA5@I?\xA4Z\xD9\xEC\xFC\x19`\xEE\x829\x13\xE9\x9B7\\$\xDF_]\xBF\x9B~\xF5\xCA\x87\x94\xE8qI\xBC2kR\t\xFD\xE06}\x05\xE6[\x9B\xF6\xD3/^X\xCF.\xA03.\xF8\xBC\xF9\xCA\x05t\xF5\x053\xE5\xFB{[\x0E\xD2\x93\xAB\xD7\xC6uo\f\xF1\xC3\x80\x1E\xA2\x9A\x9A\xDAR\x87\xD7\xEF\xCF\x85 \xF0\xBF2\x9F\x1A\x96\x95$j\\ \xAFiz\xC1\xE8\x9D\xCB\x97\xD0=+.\x89\xF9\xDB\x8C\xF1\xC5\xF4\xF2\xBB\xDB\"\x13\x11(`u\xDA\xE9\x95u;\xA4\xCA\r\x95\x04\x9B\xF6\xD41\x96\xDB\x84\xA0\x90F}\x15\x8B^*\x82\xDFb&,\f\xC2\xC3\x88\x05\rG\x00R;\xB4D\x1BZ[\x9E\x9FE\x95\x15\xF9\xBA\xA4\xF3\xF5\xAB^\xFB\x88\x90F\x81\x1D[R=\xD1\xFA[\x87LAr[\xAA\xCD\x1A\x0Ff\xC9`\xFF\xA0\x15p\x07\xCD\xC5\x18h\x17e&\xE6\xBD[\xF7\x1F\x95\xEA\t\xF4?^\x07\x14s\xD28\x15-L\xBD\xBD\xDDI\x0E\xBF?(ieT`\x85d\xC29\x18w\xE5\xAD\xD7\x17\xA4\xF3fO\xB4\b\xDF\xD8\xDAI?}\xEE/2W\xEA\x92R\x8D\x81\x98\x99(\x85\xC2\xE4\xF3\xF9\xE8\xB9?\x7F(\xDFAL\x85\x89\nw\x16\x85K\x93\xCAr\xE5\xBE&n\xA7\xA5\xB3W02ZjT\xE4\xA1\xB8\x7F\xE5\x05Yr\x1D\xA0\xAE\xA9\xBD+\xD6p\xB3Jg\xA6F\xA0i\\q.\x15q\x00\x89\x12AL\xEC\xCF\xAB,\xB5\xFE\x96\x91\x9AHXk\x01C\b\x82\x83\xF9E\xB9\x19\x94\x97\x9D&\xDA\\\u00CF\xF7\xF4\xB3\x90`^Z\xE1v;z\xFA\xAC{\xBBz\xFB\xE4>M\xB5\xC7M|\xC1|5$\xE3`\x15\xB0!\xB1\xA6i\xC6\f\x8B\xD4\x9B\xABzyG<\xE4\xC7\xF5\xD7/\x9Dk\xC1\xCF\x8F\xFF\xE7uz\xFE\x9D-2\t\r|\xC4Dv\xB4a\xC0@\xAE\xBDp6}\xE7\x96e2W{\xE7\x8F\xFF\x1F}\xB0\xBD\x86fN,\xA1\x07\xEE\xB8\x8A\xE6T\x96\xCB|)&\xDA\x97\xDF\xFB\xB4hb\xB4\x9A\xF5\xF5\x0F\xF0\xFD\xB3\xE8\xC7w]+\xDAq\xF7\x7F\xFE\x81\x8E4\xB6\xC6\xA8>\xFA\x8Fjd\xF3\x80\xB1\x9F>\xBE\x90\xF6\x1Dj\xA4i\x13\x8AiRy\x81\xF57\x94\x8D\xA0zA\xCAD\x92\xDCt\xEF\x97?CW\x9E?\x93\x7F\xD7'\xF8Q\x91\xF1\xD8o\xDF\xA2w7\xEF\x97\xF1u\xF5\xF4G\x88\xCF}\xB4\xE8\x15\xA7\xF3\xAFK~\xD8\xC2~\x1B\xD4\x12\x13\xDA\xC0y\xF9W\x8D\xEF\x84\x1Af\xB2\xE4TV\x14J\xDB(\xC1\xDE\xB8\xAB\x962\xA4\xEC\xC3.\xA7\xC9H\x9D\xF6\x9A@\x06\xDC\xCD\xAC\xF4d\xCANO\x91\xB2\x0FT\x1C?~\xEF\x8D4wj\x85\xD8\x85\xD7\xD6\xEF\xA4\x9D\x07\x8FJ\xDDO\xF4T*\xF0\xBA0'\x9D\xEE\xBBy\x19\x134\x81^_\xBF\x8B^{\x7F\x87^\x8E\x1E\xD5/\xB4\x99\x9B\xA9O\xC8\x1Df\xC6\xE08g\xDAX)m\x9C;\xA5L\x9E_{\xACE~\x07\xC1QZ\x88\x12\x93\x1F~\xF9\xB3t\xC3e\xE7P+;\x00\x0F>\xF3\n\xBD\xFB\xD7}T9\xB6\x90~\xFE\xED\x9BX#\xF3\xA4D\x06%#\xE6\xD1\xC3\xFD3\x0B\x7F\x87wjzM\xABQ4eL/\xA2:,R\xCEw\xA6\x03X\x89Lh\x8E!e(>\x1D\x18\xF4\x8A\xE4FJ\xFDb\x8B\x95\x05:\xA2$\x05\xE5w\x17\xCF\x9FB\x13Ju\x03\xFC\xE03/\xD3\xAF^~_<\x1Ax%E\xB9\x91-\x1F\x80\xAF\xDF\xBC\xE9\x12\xCA\xCFIc\xA2\xB6\xD1C\xFF\xFD\xB2\x94w+\x14\x89\xBE\xCD\x85\x11(\x13\xC1\xF1\xF6\xA6\xBDtk^\x16\xCDa\xC6\xA6\xA7\xB8i\xE1\x8C\xF1R\x99\xB6v\xCB~yfzJ\xA20\xAFrl\x01]ua\xB50\xF8\xCE\x7F_E\x1F\xEE\xAC\xA11Y\xA9\xF4\xEE\xB3\xDF\xA1\x8A\xA2\\6\xB2\xB3i\xDB\xFE\xC3\xD470(\xFDB\xCC\xD2#\xC21\x8CZMM1\xAE\x8D*\x83\x8C\xB5\xAC\xD1%\xC5gh\x8B9\x88\xDC\x85\xB9\x99\x03\f\x95f\x14R\xC5\xB6\x15\xF9\xAE\xAB\xA8\x16\x05[*\xCD\x9A\\&\x9FQ\x0E\xF8\xC1\xB6\x83\x94\x96\xE4\x11#j\x96v\x98\xC7\xD2\x85\xD3\xF9\xDAr\xF1\xCA\xBE\xF3\xC4j\x89I\x92\x18\xD6\xA2\xAF\x01a\x92\x18JR\rwt\xFB\x81zZ0c\x02\xC3N1\xCD\x9F6\x8Ef\xB1\xE4\xEF?|\\~\x17W\x93\x89\b\x01*+\xCC\x91\xEF(\x8Aj\xEB\xEC\xA1\xD9|\x1D4S5\xDA\x9E1\xB1T\x82\xBC~\xAF\xCF*#\xC1\xE7H*m8AB\xA4|\xDB\xA1\x18\xD1\x90\xE4#(\xB6F\xE5t\x07\xEAh\xE0F\xC2\xADDGs\xD8\x9DLp9%\x87!\xB5.d\xAC\xD8\x8B\xC2<E\xFCb%\n\x06\x15\xCALK\xB6`E\x96\x13\xD9u\x0FC\xB1\xC5\xF6e\\I\x9E`;\\>\xC4\x00\xB6\xA8\x9A\x9F\xE8\x03\xF6&\xCBh\xB3\xBE\xE9$K\xEC\x11\xAA\x9APB7^\xBE\x80\xF2\xB3\xD3\xE9\x85\xB77Ky\xA2y\xE40De\x18\x9A2&+\x8D\xFE\xF2\x8B\x7F\x95\xFB\xD1>\xC6\x06f\xED\xADk$\x17\x8F\r\xE3\x85\x80\xA0\xF0\x0BN\x05\xEC\x8E\x12w\xB4\xA5\x8F\xC9\x8C>A\x19\x87^1(\xA5Jz]\x9Eb\x8F\x8B\x9B\x884\x91\x8Eh8\xD1)\xC4/d/a\xEA\xF8\x121\xA0\x90HL(HAST\xE7\x14[\xECw<\x0B\xC6\x15\x87\x9B\xB1?%9\x91z\x06|\xC6u\xB6H\xAD?\x1F\x7F|k3\x9D?{\x12Mg\xA3\xF9\xC3\xDB\xAF\xA6\xEB\xEF\xFB/}\xF1\x9D-\xBA\xE0Ief\xA6\x88w\x82j3\xCCEl\xDC}\x98n\xBDj1-]T%\xD7l\xE2\xF8\xA3g\xC0o\x15Leg\xA4\xB1\x16\xE9\x86\x14Z\xFC\xC7\xB7\xB6\xD0\x8E\x03G\xE9dw\x1F\xB5\xF3\xD9\xD7\xEF\x95\x18\xC3\xEDJ`fx\xE9_\xBE\xFF\xAC\x10\x0Enn\x82\xD35\f\xB9W\x8C1\xE9\f\xC0}6\xB3\x8E\xD8L\xC5A:\xE39mLX\x7F0Lk6\xEE\xD5\x99\xC1\xDF\xEFc/\xA6r\\\u00B1HSYa\xAE0 \x8A\xEF\x1F\x93f\x10nWM\x83|Nb#\nO\xC3\xC7m\xEA\x12\x15+\xD9X\xD4\xF0\x8B\x17\xD6\xCAg\xC0\xC2\xCD\x9F;\x8F\x89\x1B\x8C\xE9\x13\x9C\xD9\xAC\x8CT\x03\xC6\xFC\x92\xCA\xDD[\xD7$\xDE\f\b\x8B\x82\xD9\xBF\xD5\x9F\x90\xDF1Q\x84\xA3$?\x9Bvq\xF4\x1D\x96\xBAPE`\xED\xF5\r\xBBi\xDB\xDF\x8E\x8A\x1Ds:\x9D\x94\x90\xE0\x92\xC5\x1AcXs~\xF9\x83[h\xD5\xC3_\x12[\x10\x84\xCF\x1E'\xBD\xAC\xB1[kwYp\xD8\xBF\xD5\xD0\xB0\xC0\xB1b\x93\x9AD%\xCE3\xD1\xE3\xE1(v+\xED\xAEm\x94\x81\xCC\x9CTJ\xAF\xFF\xFC\x1B\xB4\xE6\x17\xF7\xD0S\xDF^\xC1\xAA\xEA\"3E\xA4?\xDC\x11#\xCD\x1E&\xF8{\xDBj\xA8\x8E\r(\x8E{V^F/\xFF\xECk\xF4\xBB\x1F\xDFNy9\x19lG\"r\x93\xC4p\xF2g\x8EVw\xD5\xEA\xCC\xBA\xF3\xBA\x0Bh\xCA\xD8b\x11\x00\x19\x1C\xB7\x8Bz\xB8\x1C\xC3\xD3A\xF0\x87q!;\x8B\nd\x1C`t\x07Ko0\xA4\xCA\x02\t\x1CEc2\xA9\xEEx;\xFD\xE1\xCD\xCD\xF2\xFD\xBB_\xBC\x92\xDEx\xEA\x9B\xEC\x81\xDDD\xBF\xFB\xD1\xED\xF4\xDA\x93\xDF\xA0\xB1\fy}\xDE\x00]\xB9x&]\xBA`\x1A-\xAE\x9ED_`\xCF(\x10\xD4\xE2\xA6\x95\xA2\xD8\xA3V\xED\xE8\x86\xDA\xE6\x0B\xAA}\xFE \x92\\:\f(v\x07_\x13\xDF\xE9t8i\xC0\x17\xA6;\x7F\xB2\x9A5`\x9F\xCCz\xB9\x19\x1B\xE1\xAD\x00\x97S\x93\x93\xAC\x00H0\x9A\xEF\xB1\xDB\"A\t\xA4\xAAw @\xDF\xF8\xCF\xE7%b\x84@\x9C3},\x95\xB2\x87\x92\x91\x9A\xA2Ca\xD4\xB5>\x1E\xEC\xCFW\xAF\x13\xC8@\xC1\xEA\xF7\xBE\xB8\x8C\xED\x00|r\xBB\xB4\x8D\x7F\x0B\x98i8PT;\xC8}\xC3\xC2\x9E\x0Fv\xD6\xC9o\x1F\xEC\xC0\xBF6\xF2\x87\xCC\x95\x85$^M\x92'\x91~\xF4\xEB5\xF4\xD4\x1F\xD7\x89\xD1=g\xFA8\xBAa\xE9<\x86\xB9\x89b\x83\xD0\x17\x87\xC3E\xFB\xEAN\x88\x16\r\xB0vl?\xD0\xC0}r\xC5M+\xC5\x1C7\x1C\x13\x0E\x14\xD5P\xD0\xAF\\p\xC7c\x0F\xF1(\xBF\x0F\x1A\x01'A\xC0px\x18H\x86\xD2m\xACke\x82\x94r\xE4\t7\x0F\xEE\\}s\x87x@\x13K\xC6H50:\x8C\xCCd\x0E\xFB\xF8\x05\x86\x0B\x89\br\x80\xE1\x01F\x1A\xDEDEa\xB6\x18m,xC\x164\x99=\x17\xE4\x8Ap\xB4\x88'\xD2'\xBE\xFFD\xF6\xBB\xCD\xD0\xBF\xE6h\xABD\xA3\xE8?l@\x01\xC7\x02\xA8\xC5\x87a>\xCC\x12\xADkM\x82\xB4\x8D\xEF\xF8\x1D\x02Q\xCE\xDF\x11\x80\x81\tG\x8E\x9F\x14\xD8\x81\xD1\x073\xF29\xC2\x05\x8Cb\xD5\r\xA0\n\xED\xCB\x84\b\x8F\xB3hL\x86|\xC6r\xA1S%\x04\xFF~\xF2Q\xA3`\x7F\x17\r\xB6\x1F\xA5\xAE\xE6\xC3\xAC\xB5\x85\xEB\x94y7?\xB2TU\xA5T\xC4%+\xB6\x03\xC1a\x11?\xBAy\x84\xE7\xC0S\xC5\xCC\x8B(\xFA\n\x11s\xC9\r\bl\x86\xF18\x90\"\x90%\xA3\x86\xEB\x1A0r;Nc\xF6\x07\xF9\x1E\x7FPO\xAEa\xA00\xF2f\"O3\xFC&\x97\xD4\xCE+\xFAr_E_dm\xE6f\xE4o\xA4W$\xA3m\xF8\xF4\xFAR\x1E=Q'\x06\x1B\xD79\x1DQ\xF1\x8B\xAA\xBB\xCD\x14\xD9)\xC5\x16\x05\x95\x92\x7F\x92%\xAC\xC3[;\x8E\xB4\x88\xBF\xBB\x85\xFA[\xEA\xA8\xA3\xA9\x8E\x16/\x98\xF3\xB8\xC3\x1B\bm\f\x87\xC2u\xEC:N\x01$\xC8\xE2}\xBB6\xA2%\x8E\x18\xEC\xD0\x03\xCBtb\xBD$\x10\xD1\xF9\xB19O@\xA2\xDB\xEE\x18\xE2\xCE\xB2]\x18\xF2\x1B\b\xECv;N=q*\xF0d\xE73\xF6Ov~\xA6'\xEA\x99h#!\xE1\xD4R\xEB\xE0\x87:\x9C\xCE\xD3\x8C\xD1><\xA2(FR\x10\x15 \xDE^\n\f\xF6Ph\xA0\x8F.\xBDx\xC9;\x0E&|\xAF\x16\x0E\xAC\x0E\x85\xB4\x87T\xBB\x93\x07\xEC\x94\xFAi\xC5n\xF8\xA4\xA3s\xB7gY\xCE\xA0I\"-\xC8D\xF7\xF7\xB4\x91\xAF\xAF\x932s\xB2k>\xBBl\xE9:\x89pY%V\xA9A\xFF=\xAA\xCD\x96js\xBA\xC9\xCE\xA7\xA2\xB8,7\x89F\xB6\xB3\xC9?}\r\x89\x9E\x89\rP`\xA0\x9B\x06;\x1A\xC9\xD7\xD3B\xDE\xEE.\xBA\xED\xEB_yz|E\xB9\xD7!\xC4\xD5\xB4\x86p\xC0\xFB\x00[\xE1G\xA1\xEBv\xA7\x87\xEC\t\x1E\x9D\tv\xD3R+\xA3\x93\xE8qM\x17\x1A\xE6\x95\xA5=\x1C\xF4\xE9F\xF6\xE41\x1Aho oo\x0F\x95TTl\xBA\xFBk_\xFE\xA5\x01qN!.s\xE9\xB1\x90o\xA0*\x1C\n\xAC\x94X\x00\xBF\x0B\f\x19\x06m\x94\xF4\xF1\xFB5\x98\xAA\fq\x9C\xE1\xEB'\x7F_\x07\x05\x07:\xC9;\xD8OA\xBF\xBF\xE1G\x0F~wEiq\x91\xCF\">$\xDCfw\x81\x01\xB7\x85\xFD\xFD=a\xFF\xE0]\xAA\xB9\xE3\x87\xF6I\xD40\xFC\x13I\xBE\xB1~X&~\x82~\x99<\xC1\fZnV\xF6\xD6\xEF\x7F\xE7\xEE\x957.\xBF*R\xA5l\xE3\xE0\xC1\xE1N\"W8\x03\xF8\x14T\x03\xDE\xAF\xB3qx\x95\xCF[\xB5px.\xB7$U\xCA\xDAh\xD5\xD4\b\xA0_\xAFRNMI~\xFE\xADWW\xFF\xBAr\xF2\x84\xD8*e\xCD\xB0\xC6\xE1\xA0\x97\xC2\xAC&\xA1\x80\x17\xB3,k\x99\x8D\x1C\tiX\x87\x99\xCE\xB8\xE4\xB1YI\xA1\xD1#\x9E\xC0\x931;ds8\x1B\x14\x95\xDE\xCA\x1A\x93\xFD\xE2P\xC2\xCBuS\x97?D\xDE\xAEf\xEA;QK\xBE\xAE\x13\xC0\xAA%|\xF7cl\x88\xABl\x8E\x04r$$\x92\xCD\x99 vAQl\xA3\xD8\x1F\x8F\xA7c\xA6\xE6\x91\xAEa\xBA\x055\xA5\xEB\xAA\xA5\x8B\x1F\xB9\xFF\xAB+\xFE\xA3\xA4 'R\xA5<\xEE\xD2\xAF\xB2%\xAE\x97\xB0W\r\xF9\x97sp\xB5\x8A=\x1C\xB73)\x9D\\)Y\xE4t\xA7\x1A\xC4\x8FM\xF1\x8E\x1E\xA7\xA1}\x8C\xF1\xD5\xF7\x1A\xC2B\xB8\xB2\x92\xA2U\xAB\x1F\xFD\xD6-\xE3J\xF2d\xFAK)\x9Aw-\x13\xFF(\x85\x06{\xE6\xF1\xC5\xEBX\xDA=\xEE\x8C<\xF2d\x15SBj6\xBB\x9CIb\x8C\x15\xDB(\xE1\x87g}\xF5)S\xA9V`\xCF\x07\xC9\xB4\xEE\xDE\x01\xBAda\xD5O\xFE\xE7\x81/J\x95\xB2\x92=\xE5|\n\xF4\xB4\xB99\xD0\xDA\xC4\xC6w\x86'\xB3\x90\x92\xF3\xC6\x93;3\x9F!'Y\\M}\x12 \x92\x97\x1F=N\x9F@\xB3\\\x1Fs\x8B\x9B\xB0\xCE\x00\x9C]\xBD\xFD\xDAcw_\xB7d\xF9\xC5\xB3\xD7;\xC2\xDE>\xE6P\xE8Z\xC5\xE6\x98\xE1J\xC9\xA6\xC4\xEC\x12\xF2d0\xE1\xDD)VpEQET\xA3>\xCF\xF0\x00Hr\xF9\x0E=m\xA3\xB1K\x9F\xA28\x95Uk\xB6\xDF\x7F\xC5\xB9\xD3\x98\xF8!\xBF\xEC\xA5\xECp'\x93;-\x97\xA1&G\xA2[\xC5\xD8\xBEk\x94\xDCg\x1F\xEF\x9A\x9F\x01\xDD\x89\x89ITs\xBC{\xC9\x86]G\xABdGY\x86\x9BjgR*\xC1\xC8\xDA\xD9\xE7G\xF2_\xFB\x84\b?h,\xAE@j\x16{\xE1Hu\\H5\x8Ajm\xA7u\xD7p\x1F\xEE\xC7=\xD8\x02F\xDF2\xF2\x1FW\x18\xCC2\x13\xBBB\xF6\xB7\xB7\xD6\\\u00E6P\x14\xFBb\xF6fR\x81\xEF\x0E1\xAE\xCE\xB8+\xD6\x86\x1E00F\xE9\xBD\xE4\xC2q\xDErq%\xE5e$Q\xDD\x89nzec\xAD\x10\xB5$'E\xF2\xEB\xAD]\x83\xFAV`\xA7h\x0B\xDB\xC6\x8CIO\xA2\xE5WL\x94\xED\x1F\xD7\xEDi\xA4\xAD\xB5-\xC2\x803){t51f\xD0\xCC9\x03s\xAB\xC8\x90\xB9\x93\x89\xB9UW\x9C \x12S\xE1<\x8C{#\xC4\xD7\x0B\xA6l\xCC\x84\x13\xED\xDD\xF3\x1C\x8A\xDD6\xD5\xCE\xAE\xA4\xDD\xE5&D\xBB\x98k\x1C\xAE\xD4\x87\x8DI\x0F\xEC\xA3\x83\xED\x18\xF1\x19\x8B\xE9\xB0!\xDD\x95\xF3\xC6\xD2\x94\xB2\x1CZ\xBF\xEB\x18\xFD\xE6\xDD}t\xC9\xAC2zx\xE5\"\xC2\xFE\xF1w?\xBB\x8Ej\x9B\xBA\x84\xB8C\x0F\xEC\x89\x9C\x9E\xEC\xA2\x15\x17N&O\x82\x8BZ\xBA\x06\xE8\xC3\xFD\xC7\xF9\xDA3,\xA8\xD0Hv\fLK\xF3\xC8\bP\x8A\xEE\x0B\xE8{\xEC\x80\x1D\x98<\x19\x93\x9E(\xFF\xA2\x0F8\xE3\x89\x1DU\xD9j\xD2i-\xF0\xC0\x181\x05:\x9C\xB8S1\f0J\x9D\x8E4\xB5\x97:\x18br\x15\x10]\xF2\xF8v\xDDZk\xE1\xF8\t\xCF\x12\x06\xB7i\xE5eU\xB4\xA4\xAA\x94ry`\xD8\xE5i\xDB\xA1\x16z\xF4\xE5-\xB2\x14\x12\x05\xAD\x83\x81\xA0\xD46b\x00X\x80\x07\x89G\xE1*J\b5\xFB\xA9]5l2\xD4\xEF\r\xCA\xC0\x03\xB2\xA3`\xD8\xD8\xEE\xFFt0\x17\xA4\xF3\xA6V\xD0\x0FW,\x12\xF9y\xFE\x83\x83\xF4\xD8+[\x04\xF2\xBC\x81\x10\xFF\xAD\x98\x99\x7F\x9E<\xFF\xE5\x8Fj\xE9g/m\xD6\xD7\x1E\x9F\t>\x99I7,\x99D\xB7\\Z%Z\xF0\xE2\x875\xF4\xE8K[\xA4Bn8\xB0\xA3iz\xBDH\xFF\x807\x89a\xC7\xE6\xB0\x19\xB3\xFF\x8A\xC1\x9Dxg\xB1Tc\x07\xD7{??\x8F>\xB7`\x82\xA8d{\xCF\xA0>\x9F\x9B\x9B*\xE5\xE6\xD1G\"k\xC2;\xDB\x0FS\xF3\xC9^Y\xA3Z\xD7\xDC\xA5\x97Xk\xAA\xD8\x01k\x1A\xD1n\x8F$\xA9\"=7\x12Va\x99\x9C\xC7_\xB0LH\xB6\f\xD6b\xB0\x8F\xB2R\xDD\xE4qa\xCAR\xA3Y\xE3\xC6P\x12\xB6n\x94\x89\xEB0\xCD\x9D\x90'\xDA\x89\xBE\x17e'\x1B\xE3U\x8D[5\x11\x1C\xC0\x12\\jh\xA4T\xE4\x19\xB3Q\x98\x94\xF7\xC8\xB4%\xC9<\xB5\xAC\x15P\x87\x11\xFF\x98{\x8F\xEA{\x92\xDA\xF4\xCD\xC3\xCCM\x7F\xAC}\"\x95\xB8@\x10\x93\xCF\x9F9g\x02]9\x7F\xBC\x10n\xD3\x81&\xFA\xE9\xF3\x1Be\xDD.\xA4:\x10\fP$6\xD3w\x85\xCD\xCAL\x92\x1AG\xD4\xBA\xA7%\xBAd\x8D*\xEE\xC5:\xE0Y\xE3\xF2e\x8F\xCE:\x86\xA2=GZ\xA3*\x80\x15\xEB~\x17k\xE9\xF9\xD3\xCAe\xF2\xBB\xA1\xAD\x9B\xF6\xD6\xB7\xC5\xEC\xFA\x84\xFEg&\xBBe\x1E\x1A\x84D\xBB\xC59\xC9\xECat\xC8J\xFBi\xE5\xB9\xB2\xA0\x1B\xBC\x84\x06\x82\xC0\xB2D)\xA4\x17\xF1\xCE\x99PH%c\xD2d\fh\xFBps\xA71\xC7\xAB\n\x84I}\x8Fl;\xE6\xB3\xB6\xAA\x1C\x9E\xE4\x1B\f\xD0\x13k\x16\xD9\xADz\x92\xB8\x88\xAF\x92\x14\xAA^4\xB3\\\u00A4\x15^\xC9\xB3ol\xA3\xFA\x13\x9D,\x1DN\xEA\xD2T\xDD8F\xED,;\xE8\xF7\xD3\xDC\x89\xF9\xF4\xE0\xCA\xC52\xD8;\x9E\xF8\x0B}\xB0\xF7\x18]1o\x02\xDD{\xDD\x02*\xC8J\x91I\xF6\xEE~\x1F\xDD\xF0\xA3\x97\xF4\xFD\x8A\xA3\x8C\xD5 K\xDE\x97\xAF\x98E\xDF\xBA\xF6\x1C\xA9l\xFB\xDASo\xCAd\xB7m\xC8\xDE\x9AYF}>\xFE\x96\xCA\f\x9ER\x92M;\x0F5\xD3\x94\xE2,*e\xC2\x0E\x1A\xC2\x91\xCC\xCC\xC0~\xD0\xA8\xE5\x19\x9B\x9FA\xDF\xBF\xE9<\x9A9>_:\x8B\xB9\xDC\xCE>/\xFD\xDF5;\xE97\xEF\xEC\x964\x01v\"\x97\xDD\xD0\xB1\xC7\x1A\xF7Q\xDF[n\x04\xC47\xEE\xB1\x11\x8Dt\xC7\xA40e$'\xC8`@\xDF\xE6\x93}t\xB8\xA9S$\x1A\x1E\xA4\xAC1\x8D^\x1DGQ\x1BZkd\xE1x>k\xC2=\x9F?G\xB6\xCC\xDD}\xB8\x95\xEE}\xF6mz\xE2\xE5M\xD4\xDC\xD1km\xD7\x85\x03j^Y\x96M+.\x9E.\xD5\tO\xBF\xBA\x856\xFF\x8D\r\xB0\xBE\x93\xB5\xF5\xB2\x03'\xDF\x93\x9D\xEA\xD1\xAB\xD5Xr\xF1\xEFl&(\xB4f\xE6\xD8<\x81\x8D=GZ\xE4\x16\xEC \x8BRv<\x07\xCC\x9F?\xA5\x88^\xFD\xE8ot\xDDC/\xD0#/|$\x86\xFB\xCE\xCF\xCE\xA1\xEA\t\xF9\"\b\xA8r3+4\xF0Y\x19\xE9\x8ES\x06\xCD\x1DV@\x1C\xB5\xEBk<\x92\x0F\xE3\x99\xE4v\xC8\xE6\x9Eh\xAF\xB3\x7FP\xB6^\xD4\xDF\x81\xA2\xBF\xBAC\x89\xB6\x1D\x9A.\x95Z\x14\x13P\xBE\xB1hj\x89\xEC\xF9\xD0\xCFF\xF9I&\xFA\xDA\x9DGd\xD9\x90\"\xD5s\x11\xB8\x07\xB6\xDFqe\xB5\xB8\x9Fol\xAE\xA5\xD5k\xF7\x88\xD4FK\x1E0\x1B6$\xC5\x93 \xB8\xBCi\x7F\x03U\xB0DW\xB2\xB7\x85\x95\xF6\x90\xEA\x93l\x93\xB60\xD3\xAA'\x14\xC8\xE2\b\xC0N%kF\xF5\xC4B:\xD6\xDAM\x8F\xBE\xB8\x91\xB5\xB7\x8Bv\xD65\xD3\xB9\xDC\xB7\x85\x95%\xECH\x94\xD1\x07\xBB\xEB\xA5\xF6H*\xE4\x00;\xA8)\xA5\xB3\x90|M\xF6\xDB\xA1(\xAE\x98x\x14\x0F\xEC\x98\xC5\xFEd\x04\x0E\x8A.\xCE\x8AQ@\xA3Y\x9Eu\x84\xFAh;j\x89)\x16d\x8C+\xC8\x94\xBA\x98nvM\xEB\x9AN\xB2\xBB\xEA\x92\xAD}1H\x13\x1BQK\xB4l\xFEDy\xF9MCk\x0F=\xC1\x04\x82\x97%\xDA\xA5\xC6\x96\x9C\xBB\x9DN\xD9=\x05\xCF>p\xAC\x8Dj\x1A\xDBi\xC1\xD4RZ\xC0R=\xA54\x87\xB5\xA1\x85\x0E6\xE8\xE5\x89`h:_[\x9C\x9B&\x1E\x0F0\xBD\x84m\xC4\\f\x046\xB3\xC6\x8E\xE5(u\x19\xCB}t\xD9\x15)A\xD4\xBD4\x87|V\xCC1\r\xDB\xE0\x9A\xC4\xB76\x99\xD6\xA2\xDE\x84pf\x1F\x1F\xF4\xEDe\xDC\xEB\xC4\x92\x1A\x86\x9F\\\u00D9\xC6\xD7\xCE~s\xC0(L\xD2b6\x9A\xD6\xAC\b\xCFd\x8A\xBEX\xC0m\xD4\xC1\xA8\x9A\x16\xB5A5\x89K\x16\x1D\xCDBK\x007\x90V0\xAC\xFED\xC7\xC7|~xB\x89\xDC\x1E\xB6\x12F\x9C\x80j3`\xFD\xE2\x19\x15\xF4\xB9s\xA7\xC8Z-\xBC#\xA5S\x96\xF4\xE8\xC5Yx\xC5\x07\xA4\x1Fp\x92\xCB\xC4~\xF4+\x97\xCBs\xFBX\xCA\xF1^\x94\x0F\xF7\xD43\xC3Z\x05\x9A\x90\x16\xFE\xD5\x1B[\xC5.\xB5v\xF6Y\xAF\x1C\x19\xB1\xC1\x8Dxt\xDA\xB0\xAC7\xFC\x8B\xAE\xDE~\xAAo\xE9\x92\x17\xD0\x14d\xA5\xD2\x1C\x96\x98?}\xB8_\f.\xC9\x92\x1Fg\xD4\xCA\x14\xCD \xA8\x1A\xC5\x10U\x06\x81kpm\x06CXGO\xBF\xBE\x11v\x941C\xFD\xE7\x9A\xCD5T56\x9F\xAE\\8\x85\xBEz\xF5|\xB6\x0FM\xF2Z\x8D\xD85\xB6a\x91d\xB7QK\x8F5];k\x9B\xC4+\xABf/\x06\xDE\xCF\xAECM:v3#\x93\xF0\xAA\x90\x147\xDB\xAB\x1E\xE9\x03\"\xE1\x87\x7F\xF3\x1Em\xAD9.\x1B\x8F\xC2\x1DF0\x95\xE0p\xE8+(\x99\xF8\xBF\x7Fw\xA7@+l\x90\xBEO\xFF0\x88o\xA0E\xC4\xE0\xC2\xD54_\x02\xA0\xAA\xF1\x9F\x9A^V\xF7\xC6\xC6\x03V\xAD\xFB\xD7\xAE^H\xD7\x9C7\x95\x16\xB2\x9A/\xE2S_;\xABEP,j\x8D\x96\tUX\x95\x0E\xA2 :\xBE\xE1\xC2\x19\xC2\x80\"\xBC\x14\xC6TS\xD2_\xA7\x84\xB6\x9E{s\x9B\xB8x\xE3\n\xB3\xE9\xD6\xCB\xE7\xE8\xA5\x88Q}\xC2\x9A2\xD8 xY\x03\xC6\xFBM\x0E\x1Do\xA7&\x8E+\xC0\x10\xBC\xC1\xE8\bjHY\xC3\xC0\x00\x10\x1B\xAF\x8E\xDA{\xB8\x99\x85\xA0_\x16\xC2-\x9CV&}\x84\x81\xCE\xE0>\xCD`\x86cs\x10\x10{bq6\xAD\xFE\xC1\r\xF4\xF2\xBF\xAD\x90\x97\xF4\x00z\x86E3U\x8DY\xC7\xC5\x11\xAE\xBDO\xD6QY\x92\x1F\x8E{\xAA\x10\x90\xB1v\xFB!z\xE1\xFD\xDDt\xFDE\xB3d\xDF\x9E\x9F\xDC~\x85`)\\\u00CE\xEB\x1F\xFC\xAD\xC0\x93^{\xA9\xC3\f\b\xE94\xF23\xF0&\xFE\xBA\xFF(\xBD\xBB\xAD\x96%\xBA\x92>\xBFd\xBA,\xF7G\x7FV>\xFC{!\xB8S\x02)]\xF2\xFEz\xA0\x9E\xDE\xD9ZK\xD7,\x9EN\xCB/\x98\xC1\x90p\x8460,H\x94\xA9\xE9\xEB\xC4\xB2\xD9\xB0b\x15$b\x07\xBC\xE9\x01\xC5\xAE\xFB\x8E\x9C\xA0\xAA\xF1\x85\xB4\x87\x89\x8C\xBD\x92a\xA8\xB1\xFC\x14Z\x93\x9F\x99\"\xF0\xF4_\x7F\xDAH\xF7\xFF\xCBEt\xE3\xC53\xE9\xBC\xE9\xE5\xD4\xD6\xDD\xCFm%I\xD1\xEDm?}\x9E6\xEC>\"Fy\x1A3\x03\xD49\x87\r\xF1\xC6\xBDGHs\xC4\x1Fd\xC9\x9A7U5\x10\x80\xFCl\xDB\xECu\xD6F\xC4\xE6\"\xDD8\x13\x16\xB2m/+\xCE#\xBF[+U\xC9\x17\xCD\x99\xC0\xD8\xAF\xAF6\xDF\xB8\xAF^\\\u00B1\x93\xDD\x03\xD4\xD4\xDE\xCBp2(\x84G\x950v\xE4\x96\x82\xD6\x90.\xB9\x0F\xAFz\x9B\x1A\xDB\xBAh\xD1\xF4\nY\x9DX\xDB\xD8&\x84G\xF2\n\x90\x80\x80\n\x8B\x16\x00\xF1\xCF\xBD\xB9\x85&\x97\x8D\x11M\xB9\xE6\xFC\xE9\f+\x8D\x02\x11\xB2X\x99\x99\x0B\x86\x02\xCA\x8E\xB5t\x92\xCF\xE7\x97q}\xB0\xABN\xDE\x89\xB2a\xF7a\xE9/\xDCF\xBCj\t\x8B\xE4d\xF3kf\xECK\xEF\xEF\x12&\\\u00CDmB\xB3\xF0\x9E\x14,\xC8\x80p`e>\x18\xF6\xFE\xCE:Z\xB8\xB5L\x96'\xAD\xF9\xEB\x01qk\x87\xF5\xDA\x13Y\x06\x1A\x96R\x92\xA9\xE3\x8A\xDA\x94\x9C\xCA\xC5K\x15\xBB\xE3UWb\x9A\xCB\x95\x94I\x0EOJ\xA4\x96<\xDE6Q\xDD\xCC\x04\xD7w\x10w\n\x1CA\xED\x11\x19\"\x15\xAC\xC8[\xE3\xF4\xF4\x01\x8C\xB1^Z\xAD\xA7\x96Uc\xBFd@\x0F\xFCn\xFC\xBD\xDF(\xE3\x96\xBDj\x1C6a2\xDA\x84\x7F\x8Dka\xF0\xCC\nb\xA4\x1A\xA2\xB7\x1F\x83\xD6\xC1{R\x8D\x94\x85i\xEC\xC1\x14<\xC3*\xDB\xE0\xEB\xB0!\x91\xB8\xBCF\x1A\x04^\x15R-\x89\xC6[0p=\x04\xC9i\xA4\x19\x82F\xFF1\x1E|\x1E\xD6.(\xB2\x89`HR\x12^\x9F\x8F\xCE\x9D5\xF9q\xD4\xEDl\xE4\xC1\xD51$L\xD1\x8C?\x0E\xB7D\x04WC\xF5\x01+X\xDEiB\n\x86\xED5\x162\x9B/\x14\x03\x0E\x07\x8D\xB2oY\xF8\xA6\xE7\xB7\x8Dt\x84Q\x0En\xD3_Z\t\x03\x1A\xF4\x85\xAC\xFC\xBEM\xD1\xF72\x8E\x8E|\xCD6L\x1F\xCA\x1F\b[f\xC5Z\xFD\x8Em\n|\xC6B=\xA3\xF6\xD7\xEF\x0F[}W\x8C\xEB\x12\x8CWL\x99\xED+F\xBF\x14\xC3\x8D\x85kk\xBE\xD4\f0\xAA\x0EK\xEAU\xC9-!9\bG\xE0\xBC\xEA\xC9\xEF\xD8\xEC\xCE\x84^\xB2\xD9W\xEBAP\xD8\xB8`\x84\xFB\xE9\x13Y\x042\x7F3\xBF\x9B\xB9t\x85\xB4\x98k,\xF76\xEAZk\xF3\xE8\x98\xFB?\xFE[t\x1B\x14\xF5\xAA&\xF3o\xD1\xAE\xF3\xDFmW\xA1!c\x88\xED\xF3\xA9\xDAW\x88\x86G\x1Bc\xAB\x17\bw0\x10\x80]\xAAY\xBAh\xE6:\x87\xDD\x95HJ(\xB0\x8A\xD9\x7F\x0Fs2u\xA8;8z\x9C\xF5\xF4\x95n`\rT\xE9\xE9\xEF\xA7\x9B>s\xF9\xD3\xE5Ec\xBC\x0E\x99\xAF\xB5\xD9\x1A\xD8\xF0=\xC0J\xF9\xA8\x95'\xD1T\x1A\xADW\x18!\xBD\xA3\xB4\xC9\xDAcG\r\xCB\x967\xE5\x059\x9Bn\xFF\xC2ez\x95\xB2\xDD\x91\x00\x9F\x05\x9Cy\x8C\x01\xB4\x8A\xF5p\xA5\x1E\x06G\"\xCC\xD1=\x05G*\xF1\x9A\xB9\xC7\x17\xE3\xBC\x1F\xDEW\xC3\xF7\xEE\xB8nEQ^\xB6^\xA5\x8C\xC9r\x1B\xF6\xBC\xD10wK\xB7\xB1\x1At\xB3\x16|]\xD3\xD4!;\x90\x8C2`x\x85\x0B\x9A\xB5o\x11\xE652\xD3R\xB6\xFC\xEB\xB7\xFE\xCF\xCAk.]\x18\xA9R\x96\x85\xCF\xA8)\xD4\xB3\xCBx\xF7\xD17\x98c\xAF\xF3\x9D_\xE1\xCF\xD5\xEC \xE5\xF2\xEF\t\xA3\xC4\x1F\x1E\xF5u;\xAF\xF5\xB2\xC7V\xC3\x91\xF3\xEF\x9F\x7F\xF2\xBB\xCFN\x1E[\x1CS,\xFB\xBF\x02\f\x001iY\x94\xC8\x93\x80\x9C\x00\x00\x00\x00IEND\xAEB`\x82";
of  in your sprite button code http://www.indiscripts.com/post/2011/04/sprite-buttons-in-scriptui
This string doesn't need decoding as demonstrated in the #targetengine "myNewSession" script that I posted above which displays the image when your magic string is used.
So it looks like I'm on the wrong track with the 64bit encoding and my question is:
how did you get the string value "\x89PNG\r\n\x1A\n\x00\x00\x00\rIHDR\x00\x.......
Or more importantly how can I get a string value for my picture (for example "c:\image2.jpg") ?
P.s. forgot to say thanks for your quick reply.
Message was edited by: ~ Trevor ~
Guide ,
Feb 02, 2012 Feb 02, 2012
I think I already answered that question in another thread. Basically:
1) Load you image file into a new File(...) instance.
2) Set myFile.encoding to 'BINARY'.
3) Open myFile in read mode: myFile.open('r')
4) Read the whole file into a string: s = myFile.read()
5) Retrieve s.toSource() and use it as a literal in your code.
Marc
Guru ,
Thanks yet again
A lot clearer now
I  can now get the string for my image and display it in a UI window
but I haven't be able to work out how to add it to a textframe or in any other form to my page in indesign.
Is this possible?
Feb 03, 2012 Feb 03, 2012
It's a ScriptUI function only.
(I know because I tried to do the same -- being able to generate embedded images would be an interesting solution to a certain class of problems.)
Guru ,
Feb 05, 2012 Feb 05, 2012
@ Jongware
Thanks, good to know.
@ Jeff
An good solution to the portability problem albeit with limitations.
Enthusiast ,
Why can't you just write out your embedded string to file, place it (and embed it with link.unlink() if you want)?
var newFile = new File(Folder.appData + "/new file.png");
if (!newFile.exists) {
     newFile.encoding = 'BINARY';
     newFile.open('w');
     newFile.write(s);
     newFile.close();
Jeff
Jun 10, 2012 Jun 10, 2012
Hey Marc thank you,
i'm trying to pass a bitmap's binaryString to flash and construct the bitmap as a bitmapData there,
do you have any ideas how can this be done in as3,
thanks again.
Jun 11, 2012 Jun 11, 2012
An ExtendScript binary string is not the same as an ActionScript ByteArray.
Why/how are you trying to pass the image to Flash?
Feb 15, 2021 Feb 15, 2021
//https://www.labnol.org/code/19920-encode-decode-base64-javascript
function base64Encode(e) {
	var k = "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/=";
	var t = "";
	var n, r, i, s, o, u, a;
	var f = 0;
	//e = utf8_encode(e);
	l = e.length;
	var c = 0;
	while (c<l) {
		c+=1000;
		while (f < l && f < c) {
			n = e.charCodeAt(f++);
			r = e.charCodeAt(f++);
			i = e.charCodeAt(f++);
			s = n >> 2;
			o = (n & 3) << 4 | r >> 4;
			u = (r & 15) << 2 | i >> 6;
			a = i & 63;
			if (isNaN(r)) {
				u = a = 64
			} else if (isNaN(i)) {
				a = 64
			t = t + k.charAt(s) + k.charAt(o) +
				k.charAt(u) + k.charAt(a)
		$.sleep(1);
	return t
Here is a version that doesn't kill the host (like Illustrator) when the input is to big. It takes a break now and then (see variable c for the number of cyles). Hope this helps…
