I tried to install subclipse v1.4.x but failed, Flash Builder 4.6 on Mac OSX 1.6.8 snow leoperd.
What is the best svn client that can connect to subversion server version 1.4 ?
( If I remember correctly, Flash Builder 4.5 contains a svn client... )
following is error message on fail. thx.
(profile=epp.package.java, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=)。
No repository found containing: osgi.bundle,org.eclipse.draw2d,3.7.1.v20110830-1143
No repository found containing: osgi.bundle,org.eclipse.gef,3.7.1.v20110830-1143
No repository found containing: osgi.bundle,org.eclipse.wst.common.emfworkbench.integration,1.2.101.v201107140600
No repository found containing: osgi.bundle,org.eclipse.wst.common.frameworks,1.2.101.v201107192200
No repository found containing: osgi.bundle,org.eclipse.wst.common.modulecore,1.2.101.v201108231700
No repository found containing: osgi.bundle,org.eclipse.wst.common.modulecore.ui,1.0.101.v201108231700
No repository found containing: osgi.bundle,org.eclipse.wst.dtd.core,1.1.501.v201107252021
No repository found containing: osgi.bundle,org.eclipse.wst.sse.core,1.1.601.v201108151912
No repository found containing: osgi.bundle,org.eclipse.wst.sse.ui,1.3.1.v201108191312
No repository found containing: osgi.bundle,org.eclipse.wst.standard.schemas,1.0.401.v201108151912
No repository found containing: osgi.bundle,org.eclipse.wst.validation,1.2.302.v201107140600
No repository found containing: osgi.bundle,org.eclipse.wst.xml.core,1.1.601.v201108302147
No repository found containing: osgi.bundle,org.eclipse.wst.xml.ui,1.1.201.v201108151912
No repository found containing: osgi.bundle,org.apache.lucene.highlighter,2.9.1.v20100421-0704
No repository found containing: osgi.bundle,org.apache.lucene.memory,2.9.1.v20100421-0704
No repository found containing: osgi.bundle,org.apache.lucene.misc,2.9.1.v20100421-0704
No repository found containing: osgi.bundle,org.apache.lucene.queries,2.9.1.v20100421-0704
No repository found containing: osgi.bundle,org.apache.lucene.snowball,2.9.1.v20100421-0704
No repository found containing: osgi.bundle,org.apache.lucene.spellchecker,2.9.1.v20100421-0704
No repository found containing: osgi.bundle,org.eclipse.emf.codegen,2.6.0.v20110913-1156
No repository found containing: osgi.bundle,org.eclipse.jem,2.0.500.v201104271400
No repository found containing: osgi.bundle,org.eclipse.jem.proxy,2.0.400.v201101101900
No repository found containing: osgi.bundle,org.eclipse.jem.workbench,2.0.400.v201104251400
No repository found containing: osgi.bundle,org.eclipse.jst.common.annotations.controller,1.1.300.v200908252030
No repository found containing: osgi.bundle,org.eclipse.jst.common.annotations.core,1.1.300.v201004141630
No repository found containing: osgi.bundle,org.eclipse.jst.common.frameworks,1.1.500.v201104081500
No repository found containing: osgi.bundle,org.eclipse.jst.common.project.facet.core,1.4.200.v201103170302
No repository found containing: osgi.bundle,org.eclipse.jst.j2ee,1.1.501.v201108231845
No repository found containing: osgi.bundle,org.eclipse.jst.j2ee.core,1.2.101.v201108110300
No repository found containing: osgi.bundle,org.eclipse.jst.j2ee.jca,1.1.500.v201108102200
No repository found containing: osgi.bundle,org.eclipse.jst.j2ee.web,1.1.501.v201108231500
No repository found containing: osgi.bundle,org.eclipse.jst.jee,1.0.401.v201105122000
No repository found containing: osgi.bundle,org.eclipse.jst.server.core,1.2.202.v20110419
No repository found containing: osgi.bundle,org.eclipse.pde.build,3.7.0.v20110512-1320
No repository found containing: osgi.bundle,org.eclipse.pde.core,3.7.1.v20110822-2108
No repository found containing: osgi.bundle,org.eclipse.wst.common.project.facet.ui,1.4.200.v201103311536
No repository found containing: org.eclipse.update.feature,org.eclipse.wst.common_core.feature,3.3.1.v201107190400-7B7DFO5F7RZHOeJ-SxQ1NJ
No repository found containing: org.eclipse.update.feature,org.eclipse.wst.common_ui.feature,3.3.1.v201107190400-7C79FULEdhO_pfuh6nYekfK0TyR2OK
No repository found containing: osgi.bundle,org.eclipse.wst.internet.monitor.core,1.0.505.v20110419
No repository found containing: osgi.bundle,org.eclipse.wst.server.discovery,1.0.200.v20110518
No repository found containing: osgi.bundle,org.eclipse.wst.server.ui,1.1.306.v20110823_1704
No repository found containing: osgi.bundle,org.eclipse.wst.web,1.1.500.v201104251400
No repository found containing: org.eclipse.update.feature,org.eclipse.wst.xml_core.feature,3.3.1.v201108102009-7C7OFeKF7RZHQNI3R-OuRb
No repository found containing: org.eclipse.update.feature,org.eclipse.wst.xml_ui.feature,3.3.1.v201108102009-7H7EFZ3DxumTlaI6nheRdHo2p1KaDIL1Uz-S3PL
Try Eclipse 1.6 - works nice with my FB4.6
In the standalone version of FB 4.6 no svn client is usable, they install but are not visible...
It worked with the prerelease builds of FB 4.6!
imho i don´t think FB4.5 had SVN installed - would be nice!
I just updated my FB4.6 prerelease to the release version and installed subclipse 1.6 via "install new software"....seems to work!
Did you uninstall FB before updating?
