I'm looping over a query inside cfscript. I need to place the results inside of another loop so I'm storing the results of the first query inside of a value list and then displaying that value list inside the second query results.
The only problem is I need to put more than one db column side by side in the value list
My code below...I need to add more columns beside the fname from the getstadd query. Is this even possible?
for (
intRow = 1 ;
intRow LTE getstaff.RecordCount ;
intRow = (intRow + 1)
var allstaff = "<span class='staffoncal'>" & ValueList(getstaff.fname, "<br />") & "</span>";
outString = outString & "height='#height#'>" & allstaff & "<p />" & allevents & "</td> ";
If you want to save the results to a variable, simply concatenate the values inside your for loop instead. But there is no need to create extra arrays. Just access the query columns with array notation:
yourVar = "";
for (intRow = 1 ;intRow <= getstaff.RecordCount ;intRow = intRow + 1)
yourVar = yourVar & getStaff.fnames[intRow] & " " & getStaff.lnames[intRow] & "....");
Valuelist is a function of just one column. As far as I know, you cannot apply it to multiple columns simultaneously.
Anyway, converting from the valuelist to an array will give you more freedom. You will then have individual arrays which you can concatenate, style or display in any way you want. Here follows an example
// array to hold list of first names
var fnames = arrayNew(1);
// array to hold list of corresponding last names
var lnames = arrayNew(1);
// initialize the arrays
var isSet = arraySet(fnames, 1,getstaff.recordCount, "")>
var isSet = arraySet(lnames, 1,getstaff.recordCount, "")>
// set the array entries
fnames = listToArray(valueList(getstaff.fname));
lnames = listToArray(valueList(getstaff.lname));
// concatenate fname and lname into full name and display
for (
intRow = 1 ;
writeoutput("<span class='staffoncal'>" & fnames[intRow] & " " & lnames[intRow] & "<br /></span>");
the problem is I can't really display the loop results right here:
I need to store those looped results in a variable and concatenate it to another variable later in the page. Here particularly, next to or with the allstaff var:
outString = outString & "height='#height#'>" & allstaff & "<p /></td> ";
yourVar = "";
There you are. That's what I mean when I say that doing it this way allows you some freedom.
Add the concatonated fields to your query.
Awesome. I think I got it now.
I was having problems because I used getStaff.fname as opposed getStaff.fname[intRow] when concatenated...
[intRow] was correct so what's the difference? I'm kind of new to cfscript and it looks funky. I'm so used to tags...
getStaff.fname[intRow] retrieves the value from a specific row in the query. Unless you are within a query loop, getStaff.fname retrieves the value in the first row of the query.
