1. Re: 'AIR App' failed to install via iTune sync with Flash Builder 4.6
markerline Dec 1, 2011 12:48 AM (in response to Teerasej Jiraphatchandej)In order to get more relevant error messages, try to install the app using your desktop iTunes and then sync via USB cable to see what the iTunes desktop app error messages are. Usually they will point you in the right direction.
2. Re: 'AIR App' failed to install via iTune sync with Flash Builder 4.6
Teerasej Jiraphatchandej Dec 1, 2011 1:07 AM (in response to markerline)iTune doesn't show any error message after the synchronization was completed. Everything works like there is no problem. It looks like the problem is in the IPA package because the app was transferred to the device but the device doesn't accept it.
or do I need another way to find error message in iTune app?
I already uninstall both Flash Builder 4.6 and AIR for IOS with uninstaller in 'Application/Utilities/', then reinstall again, the problem still exists
3. Re: 'AIR App' failed to install via iTune sync with Flash Builder 4.6
Teerasej Jiraphatchandej Dec 1, 2011 9:18 AM (in response to Teerasej Jiraphatchandej)Just solved it.
I found the way to solve this is to create new certificate file and mobile provision from iOS Developer portal and re-install them in iTune application.
I don't sure about the origin of problem, but I suspect the update of XCode and iTune. I updated them between using FB 4.6 pre-release version and full version.
FYI, I found all my AIR app which built with 4.6 pre-release fail to install in iOS device via XCode too.
4. Re: 'AIR App' failed to install via iTune sync with Flash Builder 4.6
markerline Dec 1, 2011 10:00 AM (in response to Teerasej Jiraphatchandej)1 person found this helpfulIf I remember correctly you need a new provision for each version of the application you intend on releasing.
5. Re: 'AIR App' failed to install via iTune sync with Flash Builder 4.6
Teerasej Jiraphatchandej Dec 12, 2011 3:05 AM (in response to markerline)Thank you, markerline.
The point is, with same provision, I could not release same mobile project to iOS application.
6. Re: 'AIR App' failed to install via iTune sync with Flash Builder 4.6
simon.oconnor Mar 5, 2012 4:00 PM (in response to Teerasej Jiraphatchandej)Thankyou for the info about creating new certs. It's fixed the issue I was also having trying to debug on an iPad. Insanely annoying having an app just refuse to deploy with NO message, NO error, NO reason.
Hurray for iOS.
Creating apps for Android devices is so much more straightforward.
7. Re: 'AIR App' failed to install via iTune sync with Flash Builder 4.6
Brian Vaughn Apr 6, 2012 9:23 AM (in response to Teerasej Jiraphatchandej)Tried your suggestion for recreating the cert and profile, but I'm still encountering the same error. No useful information, just a "failed to install" alert. Anyone else having this problem?
8. Re: 'AIR App' failed to install via iTune sync with Flash Builder 4.6
UglyStudios Apr 28, 2012 8:03 AM (in response to Brian Vaughn)I had this problem working with Flash 5.5 building an iPhone app.
Even though I was saving the ipa file with the same name, to use the same certificate, provisioning etc.
I was saving it from newer versions of my fla file, filenameV3.fla, etc.When saved over my original fla file, filename.fla and published it from there it installed on the iPhone without the error.
Don't know if this applies to your Flash Builder project.
I also don't know if this is perminant fix or I just got lucky this time.
Very frustrating.
9. Re: 'AIR App' failed to install via iTune sync with Flash Builder 4.6
goseta Aug 31, 2012 12:34 PM (in response to simon.oconnor)in xcode you can check the organizer window under the window menu, when u are installing the app it show debug messages under your device -> console option, there it say it has signature problems, hope that helps!
10. Re: 'AIR App' failed to install via iTune sync with Flash Builder 4.6
Flex_CRJ Dec 16, 2012 10:06 PM (in response to Teerasej Jiraphatchandej)app.xml if you mension the package id
11. Re: 'AIR App' failed to install via iTune sync with Flash Builder 4.6
marciofermino Dec 25, 2012 1:26 PM (in response to Flex_CRJ)Hi friends!,
I type from Brazil, I need help.
Recreate new Certificate and Mobile Provision, but the Itunes show me error "failed to install"
Thank's.
contact skype marciofermino,
12. Re: 'AIR App' failed to install via iTune sync with Flash Builder 4.6
marciofermino Dec 28, 2012 2:02 PM (in response to marciofermino)Yes !!!!!!!!!!!! only create new certificate!
