4 Replies Latest reply: Jun 13, 2013 2:06 AM by cbuliarca RSS
    Problem with layer sets opening
    Domaneni Community Member
      I have a problem open layer sets. In my script I get layers index and then iterate throught this layers.
      Here is the script:
      function getAllLayersByIndex(){
             function getNumberLayers(){
             var ref = new ActionReference();
             ref.putProperty( charIDToTypeID("Prpr") , charIDToTypeID("NmbL") )
             ref.putEnumerated( charIDToTypeID("Dcmn"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
             return executeActionGet(ref).getInteger(charIDToTypeID("NmbL"));
             function hasBackground() {
                 ref.putProperty( charIDToTypeID("Prpr"), charIDToTypeID( "Bckg" ));
                 ref.putEnumerated(charIDToTypeID( "Lyr " ),charIDToTypeID( "Ordn" ),charIDToTypeID( "Back" ))//bottom Layer/background
                 var desc =  executeActionGet(ref);
                 var res = desc.getBoolean(charIDToTypeID( "Bckg" ));
                 return res
             function getLayerType(idx,prop) {
                 ref.putIndex(charIDToTypeID( "Lyr " ), idx);
                 var type = desc.getEnumerationValue(prop);
                 var res = typeIDToStringID(type);
                 return res
             function getLayerVisibilityByIndex( idx ) {
                 ref.putProperty( charIDToTypeID("Prpr") , charIDToTypeID( "Vsbl" ));
                 ref.putIndex( charIDToTypeID( "Lyr " ), idx );
                 return executeActionGet(ref).getBoolean(charIDToTypeID( "Vsbl" ));;
             var cnt = getNumberLayers()+1;
             var res = new Array();
             if(hasBackground()){
          var i = 0;
                }else{
          var i = 1;
             var prop =  stringIDToTypeID("layerSection");
             for(i;i<cnt;i++){
                var temp = getLayerType(i,prop);
                if(temp != "layerSectionEnds") res.push(i);
             return res;
      function makeActiveByIndex( idx, visible ){
          var desc = new ActionDescriptor();
            desc.putReference( charIDToTypeID( "null" ), ref );
            desc.putBoolean( charIDToTypeID( "MkVs" ), visible );
         executeAction( charIDToTypeID( "slct" ), desc, DialogModes.NO );
      var groups = getAllLayersByIndex();
          for(var i = groups.length-1; i >= 0 ; i--) {
            makeActiveByIndex( groups[i], true );
            ....working with layers....
      I think, my problem is in function makeActiveByIndex, because it doesn't make active a folder and doesn't open it.
      You can see it on this picture. Active layer set is "Skupina 1" and it is in layer set "hlavicka". But "hlavicka" is not open. WHY??
      Can you help me fix this problem??
      Thank you Domaneni
        • 1. Re: Problem with layer sets opening
          Michael L Hale Community Member
          Making a layerSet active that is in a closed layerSet will not open the parent layerSet. That is true wheither you use action manager or the Photoshop Object Model. To open a close layerSet in a script you have to make one of the artLayers in that set active.
          • 2. Re: Problem with layer sets opening
            So here is no way how open all layer sets on start?? I mean function or something like that. Only way is go through all artLayers and make than active??
            • 3. Re: Problem with layer sets opening
              There is no direct way to open or close a layerSet with a script. But you don't have to make all the layers active. You only need to make one layer in the set active to open the set. If there are nested layerset you only need to make one layer in the intermost set active to open all the parent layersets.
              • 4. Re: Problem with layer sets opening
                cbuliarca Community Member
                Hi, for the past days I've worked on a script to toogle opening and closing layeSets, I've taken the code that TeddyBear posted here: http://ps-scripts.com/bb/viewtopic.php?p=14773 and adjusted it a little bit, and that's what I came up with, I hope it will help you:
                <javascriptresource>
                  <name>BCM> ToogleOpen_CloseGroup...</name>
                  <category>BCM</category>
                </javascriptresource>
                //For code readability
                // http://ps-scripts.com/bb/viewtopic.php?f=9&t=3235
                function getActiveLayerIndex() {
                    ref.putProperty( charIDToTypeID("Prpr") , charIDToTypeID( "ItmI" ));
                    ref.putEnumerated( charIDToTypeID("Lyr "), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
                    return executeActionGet(ref).getInteger(charIDToTypeID( "ItmI" ));
                function cTID(s){return charIDToTypeID(s)}
                function sTID(s){return stringIDToTypeID(s)}
                // The main function
                function closeGroup(layerSet) {
                   var m_Name = layerSet.name;
                   var m_Opacity = layerSet.opacity;
                   var m_BlendMode = layerSet.blendMode;
                   var m_LinkedLayers = layerSet.linkedLayers;
                  var currINDEX = getActiveLayerIndex();
                   var m_bHasMask = hasLayerMask();
                   if(m_bHasMask) loadSelectionOfMask();
                   if(layerSet.layers.length <= 1) {
                      addTempLayerSetIn(currSetIDX-1);
                      makeActiveByIndex(currSetIDX+2, false);
                      ungroup();
                      groupSelected(m_Name);
                      deleteTempLayerSetbyIdx(currSetIDX+1);
                   } else {
                       makeActiveByIndex(currSetIDX, false);
                      ungroup();
                   var m_Closed = activeDocument.activeLayer;
                   m_Closed.opacity = m_Opacity;
                   m_Closed.blendMode = m_BlendMode;
                   for(x in m_LinkedLayers) {
                      if(m_LinkedLayers[x].typename == "LayerSet")
                         activeDocument.activeLayer.link(m_LinkedLayers[x]);
                   if(m_bHasMask) maskFromSelection();
                   return m_Closed;
                // Below are all necessary subroutines for the main function to work
                function ungroup() {
                   var m_Dsc01 = new ActionDescriptor();
                   var m_Ref01 = new ActionReference();
                   m_Ref01.putEnumerated( cTID( "Lyr " ), cTID( "Ordn" ), cTID( "Trgt" ) );
                   m_Dsc01.putReference( cTID( "null" ), m_Ref01 );
                   try {
                      executeAction( sTID( "ungroupLayersEvent" ), m_Dsc01, DialogModes.NO );
                   } catch(e) {}
                function addLayer() {
                   var m_ActiveLayer          =    activeDocument.activeLayer;
                   var m_NewLayer             =    activeDocument.layerSets.add();
                   m_NewLayer.move(m_ActiveLayer, ElementPlacement.PLACEBEFORE);
                   return m_NewLayer;
                function hasLayerMask() {
                   m_Ref01.putEnumerated( sTID( "layer" ), cTID( "Ordn" ), cTID( "Trgt" ));
                   var m_Dsc01= executeActionGet( m_Ref01 );
                   return m_Dsc01.hasKey(cTID('Usrs'));
                function activateLayerMask() {
                   m_Ref01.putEnumerated( cTID( "Chnl" ), cTID( "Chnl" ), cTID( "Msk " ) );
                   try {
                      executeAction( cTID( "slct" ), m_Dsc01, DialogModes.NO );
                   } catch(e) {
                      var m_TmpAlpha = new TemporaryAlpha();
                      activateLayerMask();
                      m_TmpAlpha.consume();
                function deleteMask(makeSelection) {
                   if(makeSelection) {
                   m_Ref01.putEnumerated( cTID( "Chnl" ), cTID( "Ordn" ), cTID( "Trgt" ) );
                   try {
                      executeAction( cTID( "Dlt " ), m_Dsc01, DialogModes.NO );
                   } catch(e) {}
                function selectLayerMask() {
                   m_Ref01.putEnumerated(cTID("Chnl"), cTID("Chnl"), cTID("Msk "));
                   m_Dsc01.putReference(cTID("null"), m_Ref01);
                   m_Dsc01.putBoolean(cTID("MkVs"), false );
                   try {
                      executeAction(cTID("slct"), m_Dsc01, DialogModes.NO );
                   } catch(e) {}
                function loadSelectionOfMask() {
                   selectLayerMask();
                   m_Ref01.putProperty( cTID( "Chnl" ), cTID( "fsel" ) );
                   var m_Ref02 = new ActionReference();
                   m_Ref02.putEnumerated( cTID( "Chnl" ), cTID( "Ordn" ), cTID( "Trgt" ) );
                   m_Dsc01.putReference( cTID( "T   " ), m_Ref02 );
                   try {
                      executeAction( cTID( "setd" ), m_Dsc01, DialogModes.NO );
                   } catch(e) {}
                function maskFromSelection() {
                   if(!hasLayerMask()) {
                      m_Dsc01.putClass( cTID( "Nw  " ), cTID( "Chnl" ) );
                      m_Dsc01.putReference( cTID( "At  " ), m_Ref01 );
                      m_Dsc01.putEnumerated( cTID( "Usng" ), cTID( "UsrM" ), cTID( "RvlS" ) );
                      try {
                         executeAction( cTID( "Mk  " ), m_Dsc01, DialogModes.NO );
                      } catch(e) {
                         activeDocument.selection.selectAll();
                   } else {
                      if(confirm("Delete existing mask?", true, "Warning")) {
                         deleteMask();
                function groupSelected(name) {
                   m_Ref01.putClass( sTID( "layerSection" ) );
                   m_Ref02.putEnumerated( cTID( "Lyr " ), cTID( "Ordn" ), cTID( "Trgt" ) );
                   m_Dsc01.putReference( cTID( "From" ), m_Ref02 );
                   var m_Dsc02 = new ActionDescriptor();
                   m_Dsc02.putString( cTID( "Nm  " ), name);
                   m_Dsc01.putObject( cTID( "Usng" ), sTID( "layerSection" ), m_Dsc02 );
                   return activeDocument.activeLayer;
                function addToSelection(layerName) {
                   m_Ref01.putName( cTID( "Lyr " ), layerName );
                   m_Dsc01.putEnumerated( sTID( "selectionModifier" ), sTID( "selectionModifierType" ), sTID( "addToSelection" ) );
                   m_Dsc01.putBoolean( cTID( "MkVs" ), false );
                   try {
                   } catch(e) {}
                function TemporaryAlpha() {
                   activeDocument.selection.store((this.alpha = activeDocument.channels.add()));
                   activeDocument.selection.deselect();
                   this.consume = function() {
                      activeDocument.selection.load(this.alpha);
                      this.alpha.remove();
                     if( idx.constructor != Array ) idx = [ idx ];
                     for( var i = 0; i < idx.length; i++ ){
                          ref.putIndex(charIDToTypeID( 'Lyr ' ), idx[i])
                          desc.putReference( charIDToTypeID( 'null' ), ref );
                          if( i > 0 ) {
                               var idselectionModifier = stringIDToTypeID( 'selectionModifier' );
                               var idselectionModifierType = stringIDToTypeID( 'selectionModifierType' );
                               var idaddToSelection = stringIDToTypeID( 'addToSelection' );
                               desc.putEnumerated( idselectionModifier, idselectionModifierType, idaddToSelection );
                          desc.putBoolean( charIDToTypeID( 'MkVs' ), visible );
                          executeAction( charIDToTypeID( 'slct' ), desc, DialogModes.NO );
                function deleteActiveLayer(){
                   var idDlt = charIDToTypeID( "Dlt " );
                       var desc752 = new ActionDescriptor();
                       var idnull = charIDToTypeID( "null" );
                           var ref529 = new ActionReference();
                           var idLyr = charIDToTypeID( "Lyr " );
                           var idOrdn = charIDToTypeID( "Ordn" );
                           var idTrgt = charIDToTypeID( "Trgt" );
                           ref529.putEnumerated( idLyr, idOrdn, idTrgt );
                       desc752.putReference( idnull, ref529 );
                   executeAction( idDlt, desc752, DialogModes.NO );
                function isLayerSet( idx ) {
                     var propName = stringIDToTypeID( 'layerSection' );
                     ref.putProperty( charIDToTypeID( "Prpr" ) , propName);
                     ref.putIndex( charIDToTypeID ( "Lyr " ), idx );
                     var desc =  executeActionGet( ref );
                     var type = desc.getEnumerationValue( propName );
                     var res = typeIDToStringID( type );
                     // alert(res);
                     return res == 'layerSectionStart' ? true:false;
                function openGroup1(theGroup) {
                   currSetIDX= getActiveLayerIndex();
                   if(isLayerSet( currSetIDX ))
                    getNamesPlusIDsOfLayerSet();
                function getNamesPlusIDsOfLayerSet(){
                   ref.putEnumerated( charIDToTypeID('Lyr '), charIDToTypeID('Ordn'), charIDToTypeID('Trgt') );
                   var count = executeActionGet(ref).getInteger(charIDToTypeID('Cnt '));
                  var parId = executeActionGet(ref).getInteger(stringIDToTypeID( 'layerID' ));
                   var Names=[];
                   var x = 0;
                   var y = 0;
                   var r = 0;
                    var i = currINDEX;
                   for(i; i > 0 ; i--){
                        ref.putIndex( charIDToTypeID( 'Lyr ' ), i );
                        var layerName = desc.getString(charIDToTypeID( 'Nm  ' ));
                        var Id = desc.getInteger(stringIDToTypeID( 'layerID' ));
                        var ls = desc.getEnumerationValue(stringIDToTypeID("layerSection"));
                        ls = typeIDToStringID(ls);
                        // alert(layerName+": _ :"+ls);
                        if(ls == "layerSectionStart"){x++};
                        if(layerName.match(/^<\/Layer group/) )
                          y ++;
                          r = x - y;
                          if(r == 0 && ls == "layerSectionEnd"){break};
                          continue
                        if(ls == "layerSectionContent"){makeActiveByIndex(i,false);break};
                        var layerType = typeIDToStringID(desc.getEnumerationValue( stringIDToTypeID( 'layerSection' )));
                        var isLayerSet =( layerType == 'layerSectionContent') ? false:true;
                Names.push([[Id],[layerName],[isLayerSet]]);
                return Names;
                function getLayersNb()//function to find out if the number of layers in the document
                    ref.putProperty( charIDToTypeID( 'Prpr' ), stringIDToTypeID('numberOfLayers') );
                    ref.putEnumerated( charIDToTypeID( "Dcmn" ), charIDToTypeID( "Ordn" ), charIDToTypeID( "Trgt" ) );
                    var numberOfLayers = desc.getInteger(stringIDToTypeID('numberOfLayers'));
                    return numberOfLayers;
                function toogleOpenCloseSet(){
                  myALayerIDX = getActiveLayerIndex();
                  myGroupP = app.activeDocument.activeLayer;
                  if(!isLayerSet(myALayerIDX)){
                      myGroupP = app.activeDocument.activeLayer.parent;
                      if(myGroupP.typename != "Document"){
                        if(isSetOpened1(myGroupP)){closeGroup(myGroupP)}else{openGroup1(myGroupP)};
                  }else{
                function getFristLayerSetChildVisible(){
                  xx = false;
                   var Names=[];
                    var x = 0;
                    var y = 0;
                    var r = 0;
                    var i = currINDEX;
                        var vis = desc.getInteger(stringIDToTypeID( 'visible' ));
                        // alert(layerName+": _ :"+vis);
                /*        if(desc.hasKey(stringIDToTypeID("visible")))
                          alert(desc.getType(stringIDToTypeID("visible")));
                        if(vis == 1 && Id!=parId && r!=0){
                          var theOBj = {id:Id, lname:layerName, idx:i};
                          xx =true;
                          Names.push(theOBj);
                          break;
                          y ++;
                          r = x - y;
                          continue
                    return Names;
                function getLastChildIdx(){
                  xx = false;
                    var i = currINDEX;
                    var x = 0;
                    var y = 0;
                    var r = 0;
                    var lastChIdx = 0;
                          y ++;
                          r = x - y;
                            lastChIdx = i;
                            break;
                        // alert(x+" _ "+y+" _ "+r+" _ "+layerName);
                    return lastChIdx;
                function getNbOfChilds(){
                  xx = false;
                    var i = currINDEX;
                    var nb = 0;
                    var x = 0;
                    var y = 0;
                    var r = 0;
                          y ++;
                          r = x - y;
                            break
                          continue
                        nb++;
                    return nb;
                function isSetOpened1( group ){
                  app.activeDocument.activeLayer = group;
                  xx = true;
                  currSetIDX = getActiveLayerIndex();
                  var fIdx = getActiveLayerIndex();
                  if(fIdx == getActiveLayerIndex())
                    xx = false;
                  return xx;
                function addTempLayerSetIn(idxx){
                    var idMk = charIDToTypeID( "Mk  " );
                        var desc58 = new ActionDescriptor();
                            var ref63 = new ActionReference();
                            var idlayerSection = stringIDToTypeID( "layerSection" );
                            ref63.putClass( idlayerSection );
                        desc58.putReference( idnull, ref63 );
                    executeAction( idMk, desc58, DialogModes.NO );
                    // =======================================================rename
                    var idsetd = charIDToTypeID( "setd" );
                        var desc202 = new ActionDescriptor();
                            var ref209 = new ActionReference();
                            ref209.putEnumerated( idLyr, idOrdn, idTrgt );
                        desc202.putReference( idnull, ref209 );
                        var idT = charIDToTypeID( "T   " );
                            var desc203 = new ActionDescriptor();
                            var idNm = charIDToTypeID( "Nm  " );
                            desc203.putString( idNm, "mb-dummy tempTestLayerSetOpen_Closed" );
                        desc202.putObject( idT, idLyr, desc203 );
                    executeAction( idsetd, desc202, DialogModes.NO );
                    // =======================================================move
                    var idmove = charIDToTypeID( "move" );
                        var desc59 = new ActionDescriptor();
                            var ref64 = new ActionReference();
                            ref64.putEnumerated( idLyr, idOrdn, idTrgt );
                        desc59.putReference( idnull, ref64 );
                            var ref65 = new ActionReference();
                            ref65.putIndex( idLyr, idxx );
                        desc59.putReference( idT, ref65 );
                        var idAdjs = charIDToTypeID( "Adjs" );
                        desc59.putBoolean( idAdjs, false );
                        var idVrsn = charIDToTypeID( "Vrsn" );
                        desc59.putInteger( idVrsn, 5 );
                    executeAction( idmove, desc59, DialogModes.NO );
                function deleteTempLayerSetbyIdx(idxx){
                          ref.putIndex(charIDToTypeID( 'Lyr ' ), idxx);
                          // ref.putIdentifier(charIDToTypeID( 'Lyr ' ), idxx);
                  executeAction( idDlt, desc, DialogModes.NO );
                toogleOpenCloseSet();
