2 Replies Latest reply: Apr 29, 2013 5:44 AM by Innovatology RSS
    Build 4.6
    Galip39290 Community Member
      I have just downloaded Flex 4.6 framework, and I cannot build the sdk.
      When I run ant main, I've got a lot of errors :
          [compc] ^
          [compc]
          [compc] C:\FlexSDK\4.6.0\frameworks\projects\framework\src\mx\core\ILayoutEl
      ement.as(29): col: 41 Error: Interface IEventDispatcher was not found.
          [compc]
          [compc] public interface ILayoutElement extends IEventDispatcher
          [compc]                                         ^
          [compc]
          [compc] C:\FlexSDK\4.6.0\frameworks\projects\framework\src\mx\core\ILayoutDi
      rectionElement.as(1): col: 1 Error: The definition of base class Object was not
      found.
          [compc]
          [compc] ////////////////////////////////////////////////////////////////////
      When I build 4.5.1, I have no error and everythink works fine.
      Is there a difference in 4.6, should I define a new environnment variable or add an argument to the ant command ?
      Thanks in advance.
      Nicolas Beaudrot.
        • 1. Re: Build 4.6
          swartzbaugh3 Community Member
          I'm also unable to compile the 4.6 sdk. I am able to build all previous versions but 4.6 throws a ton of errors.
          Has anyone been able to successfully build sdk 4.6 on windows?
          To build I did the following:
          cd FLEX_HOME/frameworks/
          ant
          Am I missing something? Like I said, I was able to successfully build all previous versions doing this.
          • 2. Re: Build 4.6
            Innovatology Community Member
            The build.xml file probably contains an incorrect version:
            <property name="playerglobal.version" value="11.0"/>
            Your environment variable PLAYERGLOBAL_HOME should point to a directory containing various version numbers. The version number specified above must exist and contain the relevant playerglobal.swc file.
