I am recieving an exit code: 7 upon trying to install a trial version of Illustrator CS5.
justinfinite Nov 26, 2011 3:06 PMlog: Exit Code: 7 -------------------------------------- Summary -------------------------------------- - 0 fatal error(s), 47 error(s), 43 warning(s) ----------- Payload: {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86 1.0.0.0 ----------- ERROR: Error 1935.An error occurred during the installation of assembly component {43CC1B37-B20C-3EBC-9C04-F809989E4FD3}. HRESULT: 0x8007370A. ERROR: Install MSI payload failed with error: 1603 - Fatal error during installation. MSI Error message: Error 1935.An error occurred during the installation of assembly component {43CC1B37-B20C-3EBC-9C04-F809989E4FD3}. HRESULT: 0x8007370A. WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure WARNING: DW036: Payload cannot be installed due to dependent operation failure ERROR: DW050: The following payload errors were found during install: ERROR: DW050: - Adobe ExtendScript Toolkit CS5.5: Install failed ERROR: DW050: - Microsoft_VC90_ATL_x86: Install failed ERROR: DW050: - Microsoft_VC90_CRT_x86: Install failed ERROR: DW050: - AdobeColorNA CS5.5: Install failed ERROR: DW050: - Adobe Illustrator CS5.1: Failed due to Language Pack installation failure ERROR: DW050: - Adobe XMP Panels CS5: Install failed ERROR: DW050: - CSXS Story Extension: Install failed ERROR: DW050: - Photoshop Camera Raw: Install failed ERROR: DW050: - Camera Profiles Installer: Install failed ERROR: DW050: - Adobe Extension Manager CS5.5: Install failed ERROR: DW050: - Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll: Install failed ERROR: DW050: - AdobeColorCommonSetRGB: Install failed ERROR: DW050: - Adobe Device Central CS5.5: Failed due to Language Pack installation failure ERROR: DW050: - AdobeColorCommonSetCMYK: Install failed ERROR: DW050: - Microsoft_VC90_MFC_x86: Install failed ERROR: DW050: - Adobe Linguistics CS5: Install failed ERROR: DW050: - PDF Settings CS5: Install failed ERROR: DW050: - AdobeTypeSupport CS5: Install failed ERROR: DW050: - Adobe CSXS Infrastructure CS5.5: Install failed ERROR: DW050: - AdobeHelp: Install failed ERROR: DW050: - Microsoft_VC80_CRT_x86: Install failed ERROR: DW050: - Adobe Device Central CS5.5_DeviceCentral3.5LP-en_US: Install failed ERROR: DW050: - Camera Profiles Installer_6.3_AdobeCameraRawProfile6.0All: Install failed ERROR: DW050: - AdobeColorJA CS5.5: Install failed ERROR: DW050: - AdobeOutputModule: Install failed ERROR: DW050: - Adobe WinSoft Linguistics Plugin CS5: Install failed ERROR: DW050: - Microsoft_VC90_MFCLOC_x86: Install failed ERROR: DW050: - AdobePDFL CS5: Install failed ERROR: DW050: - AdobeCMaps CS5: Install failed ERROR: DW050: - Adobe CSXS Extensions CS5.5: Install failed ERROR: DW050: - Adobe ReviewPanel CS5.5: Install failed ERROR: DW050: - Required Common Fonts Installation: Install failed ERROR: DW050: - HIL Help Search: Install failed ERROR: DW050: - Microsoft_VC80_MFC_x86: Install failed ERROR: DW050: - Adobe Player for Embedding 3.1: Install failed ERROR: DW050: - Microsoft_VC80_MFCLOC_x86: Install failed ERROR: DW050: - SiteCatalyst NetAverages CS5.5: Install failed ERROR: DW050: - Adobe Illustrator CS5.1_AdobeIllustrator15_1en_USLanguagePack: Install failed ERROR: DW050: - Recommended Common Fonts Installation: Install failed ERROR: DW050: - AdobeJRE: Install failed ERROR: DW050: - Suite Shared Configuration CS5.5: Install failed ERROR: DW050: - Adobe Bridge CS5.1: Install failed ERROR: DW050: - Photoshop Camera Raw_6.3_AdobeCameraRaw6.0All: Install failed ERROR: DW050: - AdobeColorEU CS5.5: Install failed -------------------------------------------------------------------------------------
