Our IT department recently installed Robohelp 9 on my laptop. I was previously using RoboHelp 5. When I select Generate and Save for WebHelp (Primary Layout) for RoboHelp for HTML, the Publish button is shaded/inactive. Our IT Department appears to be at a loss as to how to resolve this problem. Does any one have any suggestions as to how it can be resolved so I can publish my project?
Thank you.
Welcome to our community
Whether your Publish button is active or not depends on whether a Publishing Destination has been defined in your Single Source Layout recipe. In version 9, right-click the Single Source Layout in the pod and choose Properties:
Navigate to the Publish section in the left area of the dialog, then note what you see on the right. My guess is that you will find this area empty with no destinations declared. If that's the case, you will need to click the New button and define one. Otherwise, you will likely just click to enable any destination that is defined but not enabled.
Cheers... Rick
