1. Re: Media coder cs5 field order
johng12345 Dec 7, 2011 5:26 PM (in response to johng12345)Also I would like to add when I change the field order to Progressive under output it says "de-interlaced. Does that mean that using a field order of lower or upper does not do de-interlacing or does it still perform de-interlacing? Because I have always heard that you should always de-interlace the output footage for better quality. In which case I should always use progressive as the output field order? This s all a little confusing because I am not sure what is going on here.
John Gerard
2. Re: Media coder cs5 field order
literally_figurative Dec 8, 2011 7:46 AM (in response to johng12345)I don't know if it will, but maybe this thread I made recently will help a bit.
http://forums.adobe.com/message/4017023#4017023
I am now about to export to DVD under similar circumstances as we speak. (HDV and DSLR footage together) and am going to use my experience from that thread.
