Yesterday I downloaded the ePub script for RoboHelp 8. (We don't have RoboHelp 9.) I was able to import the script and get 7za in the default location so I didn't have to modify the script file, but when I try to run the script, I get this error:
Expected: ;
I have tried Debug in the script editing window and find that it yields the same error and highlights this line:
Date: Wed, 7 Dec 2011 15:27:25 -0600
The entire line is highlighted in orage, but Dec is specifically highlighted in blue. Any ideas as to why I get the error and can't run the script?
Tammy
I found the problem, which was in how I saved the downloaded file. So the problem was me, not the script. Sorry!
There's a command that is not properly ended with a semicolon. I wouldn't advise debugging that script as it's very limited. Try my eBook generator script: http://www.wvanweelden.eu/robohelp/ebookgenerator It's the RoboHelp 9 script plus optional Kindle creation.
Greet,
Willam
It looks like the script you recommended requires a lot of extras that I would have to have approved here to run. Does anyone have an answer to the error in the original Adobe script? I am really just trying this out and don't want to install a lot of extra things for that. I'd like to start by seeing what I could do with the Adobe script.
Unfortunately, that's true. For RH8 you need the LibIconv, there's not much I can do about that.
I can't find the line you indicated in the script. You are using the RH8 script provided on the Adobe blog right? What is the line number that the error occurs?
Greet,
Willam
Yes, I downloaded the script from http://blogs.adobe.com/techcomm/2010/04/robohelp_script_to_generate_epub_format_content_for_mobile_d.... The error occurs in line 3, which starts "Date".
