Show 4 replies
1. Re: converting a swf to quicktime mov file
Rob Dillon Dec 8, 2011 5:01 PM (in response to socahweir)You can export a video file from Flash using the Export option in the File Menu.
2. Re: converting a swf to quicktime mov file
socahweir Dec 8, 2011 8:05 PM (in response to Rob Dillon)I tried using the movie export option. A popup comes up titled "Recording Flash Content." It freezes and does not ever finish creating the file. I tried downgrading the player from Flash Player 10 to Flash Player 5. This did not work either.
3. Re: converting a swf to quicktime mov file
Deceitfuls Dec 8, 2011 8:33 PM (in response to socahweir)Which option do you use to stop the exporting? After the last frame or after time elapsed? If you used after the last frame, that's probably why. Try using after time elapsed and try it again.
4. Re: converting a swf to quicktime mov file
socahweir Dec 8, 2011 8:38 PM (in response to Deceitfuls)Of course it would be that easy! Thanks so much. This works perfectly.
