1 2 3 4 5 Previous Next 161 Replies Latest reply on Jun 15, 2018 11:31 PM by henrycloud Go to original post
      • 120. Re: Print File Name with pdf Document
        ReinhardF Level 3
        it seems you have an older version. In the latest you can choose if you only want to print Date and filename only.
        The latest version you can download from:
        http://www.Refob.de/downloads/acrobat/SetRemoveFooter.js
        If you have the old version I assume you can delete or comment out (= write // in the front of the text) this lines:
        var fp = this.addField(String("page"+p+1), "text", p, [330,10,280,28]);     //<- this set up the page number file
        fp.textSize=8; fp.value = "Page: " + String(p+1)+ "/" + this.numPages;  //<- this fomat the page number field
        If that not help, please copy in the js-code you work with, so also other with a more compareable working time, can give you the small changes.
        best regards, Reinhard
        • 121. Re: Print File Name with pdf Document
          hilljensen Level 1
          Hi ReinhardF!
          I would like to have a footer showing only this:
          The full file path + date
          What changes should I do in your original script which, however, works perfect in AA X.
          Regards
          Arne
          • 122. Re: Print File Name with pdf Document
            ReinhardF Level 3
            you can change in the script following lines:
            var AcDateFormat = "yyyy/mmm/dd  HH:MM"
            to
            var AcDateFormat = "yyyy/mmm/dd"
            and
            fd.value =  util.printd(AcDateFormat, AcDate) + "   (" + FileNM +")";
            to
            fd.value =  util.printd(AcDateFormat, AcDate) + "   (" + Path +")";
            • 123. Re: Print File Name with pdf Document
              hilljensen Level 1
              Thanks, I have allready changed those two lines.
              But I would also get rid of all lines that is about page numbers, because I will not use that.
              How to change the line : fd.value = util.printd .........................
              to show the full path first an then the date?
              Thanks in advance!
              Best regards
              Arne
              • 124. Re: Print File Name with pdf Document
                ReinhardF Level 3
                Change to:
                fd.value =  "Path: " + Path +"  Date: " + util.printd(AcDateFormat, AcDate);
                or similar, where "..." is "my Text".
                HTH, Reinhard
                • 125. Re: Print File Name with pdf Document
                  Michael314 Level 1
                  Reinhard,
                  Dies ist eine sehr gute Arbeit!
                  I have read this thread with interest since I nioticed it today and have placed your JavaScript in my Acrobat 6.0 install folder. I have been able to make modifications to the components of the footer (date format, adding PRELIMINARY to the textstring, changing text size). It works very well and gives me a new tool for identifying preliminary versions of manuals.
                  Would you explain how to change the location of the footer? I would like to place it a little higher on the page.
                  BTW, I noticed that Acrobat has a feature called Add Headers & Footers but it is much more time consuming to use and does not have the flexibility, ease of use, and performance of your script.
                  Danke,
                  Michael F
                  • 126. Re: Print File Name with pdf Document
                    ReinhardF Level 3
                    Danke Michael,
                    habe einfach nicht die Zeit es mal komplett - mit mehr Optionen - zu überarbeiten.
                    "Would you explain how to change the location of the footer? I would like to place it a little higher on the page."
                    You can inrease the y-coordinates: upper left (y1) and lower right (y2):
                    If you want the field 10 Pts higher you can change:
                    var fd = this.addField("xftDate", "text", p, [30,15, TotWidth-30-30,30]);
                    to
                    var fd = this.addField("xftDate", "text", p, [30,15+10, TotWidth-30-30,30+10]);
                    The difference between y1 and y2 is the field hight.
                    The calculation for the field placing on the page start at lower left corner (= 0).
                    HTH, Reinhard
                    • 127. Re: Print File Name with pdf Document
                      hilljensen Level 1
                      This goes both to ReinhardF and Michael314!
                      I'm a total novise as far as programming is concerned. I have ReinhardF's javascript and it works perfect i AA X.
                      I wonder if some of you experts could make me a Javascript that show the full file path and nothing else on the first page only of a document as a footer.
                      Please give me the option of choosing between left, center or right position.
                      Thanks!!!!
                      Best regards
                      Arne
                      • 128. Re: Print File Name with pdf Document
                        Michael314 Level 1
                        Arne,
                        Reinhard did give you a hint back in post 124.
                        Change the fd.value statement to this:
                        fd.value =  "Path: " + Path;
                        When you open the PDF file and select any of the Set Date... commands, it will insert only the file path.
                        I think the pages affected are controlled by this statement but I don't know how to adjust it.
                        for (var p = 0; p < this.numPages; p++)
                        Yours,
                        Michael F
                        • 129. Re: Print File Name with pdf Document
                          ReinhardF Level 3
                          "I think the pages ..." thats correct.
                          @ Arne
                          Change:
                          to
                          for (var p = 0; p < 1; p++)
                          to get it only on the first page, or:
                          for (var p = 1; p < this.numPages; p++)
                          to get it on all, but not on first.
                          The second question: "Please give me the option of choosing between left, center or right position" astonished me. It's already in the menu selection. I think at least you can test the script before asking.
                          • 130. Re: Print File Name with pdf Document
                            Ma-ik Level 1
                            Hello ReinhardF
                            great script, just does what I expected. One Question
                            Line:
                            & "fd.textSize=6;   "&vbLF _
                            I changed Textsize to 10 and it works fine, but is there a possibility to get the textstyle bold? I tried:
                            & "fd.textStyle=bold;   "&vbLF _
                            but didn't work. I don't to the Scripting Parameters so I ask in this Forum.
                            • 131. Re: Print File Name with pdf Document
                              hilljensen Level 1
                              Hi!
                              Sorry about that second question, it is already solved.
                              The last thing I 'll ask is what lines to be removed when I don't need the page numbering.
                              Thanks for the great effort!
                              Best regards
                              Arne
                              • 132. Re: Print File Name with pdf Document
                                ReinhardF Level 3
                                there exists no property "textStyle". You have to choose a font in bold. So font:
                                font.TimesB, font.HelvB, font.CourB
                                can be used. If you add a I at the end it will be bold+Italic.
                                So you can Write (in above VBS file):
                                &"  fd.textSize=10; fd.textFont = font.TimesB;  "&vbLF_
                                Pay attention to the point that JS is case sensitive.
                                Load down the AcroJs.pdf helpfile and have a look at the Field Object -> Field properties.
                                So you may use textColor or fieldBorder or ...
                                Good luck, Reinhard
                                PS: That just gives me the idea to change the VBS-files so that the js-variable will be set by reading saved poor JS-Code.
                                That avoid the change to vbs-writing (&"         "&vbLF), the js-code could directly tested in the acrobat-js-console and all saved versions could be executed by selecting the file. I think I will put it on my list.
                                • 133. Re: Print File Name with pdf Document
                                  Michael314 Level 1
                                  Reinhard,
                                  To give users some variety, they can also use non-bold fonts, so brief font list looks like this:
                                  fd.textFont = fontname;
                                  where fontname can be:
                                  font.Times
                                  font.TimesB
                                  font.Helv
                                  Font.HelvB
                                  font.Cour
                                  font.CourB
                                  We're taqlking about text in a footer, so you should not need more variety than this.
                                  Yours,
                                  Michael F
                                  • 134. Re: Print File Name with pdf Document
                                    ReinhardF Level 3
                                    "...... so you should not need more variety than this."
                                    They have it already. You forgot the italic fonts - lol. :-)
                                    • 135. Re: Print File Name with pdf Document
                                      ReinhardF Level 3
                                      @Arne
                                      simple delete or comment out (like as follow) these lines:
                                      // app.addMenuItem({ cName: "Set Page ", cParent: "Footer", cExec: "SetFooter(4)"});
                                      // app.addMenuItem({ cName: "Set Both", cParent: "Footer", cExec: "SetFooter(5)"});
                                      // app.addMenuItem({ cName: "Remove Both", cParent: "Footer", cExec: "RemoveFooter(5)"});
                                      // app.addMenuItem({ cName: "Remove Page", cParent: "Footer", cExec: "RemoveFooter(4)"});
                                      The statement cName:"..xxx.." is only the menu item display name. So you change it for rest to whatever you want-
                                      Good luck, Reinhard
                                      • 136. Re: Print File Name with pdf Document
                                        harringg_ Level 1
                                        @Reinhard
                                        Thank you very much for your useful script and your helpful replies to users questions here.  This will streamline my workflow 100x
                                        I've taken the script in AA X and modified page position to fit specific documents.
                                        As a quick guide to help others, initially I didn't have a good grasp on the placement syntax and would like to share with others here what I "figured out".
                                        [10,30,545,40]
                                        10 = Places the start of the text box 10 pixels from the left most edge (x1 coordinate) of the document
                                        30 = Places the bottom of the text box 30 pixels from the bottom (y1 in your post) edge of the document
                                        545 = Places the end of the text box 545 pixels from the left most edge (x2 coordinate) of the document (ie. 535 pixel wide text box, starting 10 pixels from left most edge)
                                        40= Places the top of the text box 40 pixels from the bottom edge (y2 in your post) of the document (ie. 10 pixel high text box)
                                        Is this logic correct?
                                        Also, I plan to share this with other collegues in my office, I would like to put the following header in the script, with your permission.  If you would like me to add any other credit text, please post it or send via PM
                                        //Original script written by ReinhardF, Nov 13, 2006
                                        //For specific questions, visit http://forums.adobe.com/thread/302996?tstart=0
                                        Thanks again!
                                        • 137. Re: Print File Name with pdf Document
                                          harringg_ Level 1
                                          Is there a way to rotate the text 90 degrees?
                                          I have documents that have text at the top most and bottom most part of the page, but an inch of whitespace on the right hand side.
                                          What I'm hoping to do is have text run along the right-hand side and when the page is in a 3-ring binder, the text is running LR reading order starting in the lower right corner, running up to the top right side of the page.
                                          • 138. Re: Print File Name with pdf Document
                                            ReinhardF Level 3
                                            "Is this logic correct?" -> Yes it is.
                                            "Also, I plan to share" -> No problem.
                                            "Is there a way to rotate the text 90 degrees?" No problem : fd.rotation=90
                                                 found at; AcroJs.pdf Field object -> Field property =>rotation
                                            "have text run along the right-hand side " Not realy a porblem, you need: var TotHeight = aRect[1] - aRect[3];
                                                  found at; AcroJs.pdf Doc object ->  Doc methods  = > getPageBox
                                            With that you have all information to set it als header, in the middle or wherever you want.
                                            Good luck, Reinhard
                                            • 139. Re: Print File Name with pdf Document
                                              hilljensen Level 1
                                              Hi ReinhardF!
                                              I have tried to modify the script to meet my needs, that is ONLY the filepath to be shown on the first page only, no need for page number or date.
                                              My script looks like this:
                                              app.addSubMenu({  cName:  "Footer", cUser: "File Path", cParent: "fil", nPos: 20});
                                              app.addMenuItem({ cName: "Left", cParent: "Footer", cExec: "SetFooter(1)"});
                                              app.addMenuItem({ cName: "Center", cParent: "Footer", cExec: "SetFooter(2)"});
                                              app.addMenuItem({ cName: "Right", cParent: "Footer" , cExec: "SetFooter(3)"});
                                              app.addMenuItem({ cName: "Remove", cParent: "Footer", cExec: "RemoveFooter(1)"});
                                              function SetFooter(ARG)
                                              var re = /.*\ / | \ .pdf$/ig;
                                              var Path = this.path;
                                              var Box2Width = 50
                                                  var aRect = this.getPageBox("Crop", p);
                                                  var TotWidth = aRect[2] - aRect[0]
                                                  if (ARG<=3 | | ARG ==9)
                                                   { var fd = this.addField("xftDate",  "text" , p, [30, 15,  TotWidth-30-30, 30]);
                                                        fd.value = Path;
                                                         fd.textSize=6; fd.readonly = true;
                                                         if (ARG==1){ fd.alignement="left"  };
                                                         if (ARG==2){ fd.alignement="center"  };
                                                         if (ARG==3){ fd.alignement="right"  };
                                                 if  (ARG==4 | |  Arg==5  | | ARG==9)
                                                  {  var bStart=(TotWidth/2)-(Box2Width/2)
                                                       var bEnd=((TotWidth/2+8Box2Width/2))
                                                       if (ARG==5){var bStart=8TotWidth-Box2Width-30); var bEnd=(TotWidth-30);}
                                                       var fp = this.addField(String("xftPage"+p+1),  "text" , p, [bStart, 30, bEnd, 15]);
                                              Function RemoveFooter(ARG)
                                              if  (ARG<=3 | | ARG===9)  {var x = this.removeField("xftDate");}
                                              Is ther anything more I can remove from this script, and still make it to work for the file path only?
                                              Just to reduse the script to a minimum.
                                              Thanks from Arne!
                                              • 140. Re: Print File Name with pdf Document
                                                ReinhardF Level 3
                                                "Is ther anything more I can remove from this script"
                                                Sure, take this:
                                                app.addSubMenu({cName:  "Footer", cUser: "File Path", cParent: "File", nPos: 20});
                                                app.addMenuItem({cName: "Left", cParent: "Footer", cExec: "SetFooter(1)"});
                                                app.addMenuItem({cName: "Center", cParent: "Footer", cExec: "SetFooter(2)"});
                                                app.addMenuItem({cName: "Right", cParent: "Footer" , cExec: "SetFooter(3)"});
                                                app.addMenuItem({cName: "Remove", cParent: "Footer", cExec: "this.removeField('xftDate');"});
                                                var Box2Width = 50;
                                                var page = 0;
                                                var aRect = this.getPageBox("Crop", page);
                                                var TotWidth = aRect[2] - aRect[0];
                                                var fd = this.addField("xftDate",  "text" , page, [30, 15,  TotWidth-30-30, 30]);
                                                fd.value = Path;
                                                fd.textSize = 6;
                                                fd.readonly = true;
                                                if (ARG==1){fd.alignement="left"};
                                                if (ARG==2){fd.alignement="center"};
                                                if (ARG==3){fd.alignement="right"};
                                                • 141. Re: Print File Name with pdf Document
                                                  hilljensen Level 1
                                                  Thanks ReinhardF!!!
                                                  This is more than perfect!
                                                  By the way, do you know why this does not work with Reader?
                                                  Best regards from Arne.
                                                  • 142. Re: Print File Name with pdf Document
                                                    ReinhardF Level 3
                                                    Reader don't can add fields - only fill existing.
                                                    Only with Reader you can use a freeware tool like BeCyPdfAsm (http://www.becyhome.de/news_eng.htm) to set a footer.
                                                    • 143. Re: Print File Name with pdf Document
                                                      try67 MVP & Adobe Community Professional
                                                      Reader can add fields, if the right to do so has been applied to the file
                                                      in Acrobat.
                                                      • 144. Re: Print File Name with pdf Document
                                                        hilljensen Level 1
                                                        Hi try67!
                                                        How do you do this?
                                                        Regards
                                                        Arne
                                                        • 145. Re: Print File Name with pdf Document
                                                          In Acrobat? Depends on your version. In Acrobat X it's under File - Save As
                                                          - Reader Extended PDF - Enable Additional Features...
                                                          • 146. Re: Print File Name with pdf Document
                                                            hilljensen Level 1
                                                            I have tested this procedure, and it works with AA X.
                                                            But you need to have AA X, it can't be done in Reader. That means you have to save it in AA X and then open the file in Reader and then run the function.
                                                            Most people have only Reader and then it can't be done.
                                                            • 147. Re: Print File Name with pdf Document
                                                              hilljensen Level 1
                                                              Hi Reinhard!
                                                              Can you please test the shortened script from answer 140? It allways place the file path to the left even if I press menu item "Center" or "Right".
                                                              Regards Arne
                                                              • 148. Re: Print File Name with pdf Document
        Bernd Alheit Adobe Community Professional & MVP
        You may use
        if (ARG==2){fd.alignment="center"};
        not
        • 149. Re: Print File Name with pdf Document
        hilljensen Level 1
        Thanks, Bernd!!
        A mis-spelling can cause unexpected errors.
        • 150. Re: Print File Name with pdf Document
        Fer1403 Level 1
        Mr. Reinhardf Im using your script and I will like to change the code a little bit in order to get just some parts of the path,
        Ex. my actual path is something like /1/2/3/4/5/abc.pdf and will like to change the footer to something like 4/5/abc.
        1/2/3 will be always the same part of the path; all documents are in the same drive.
        I know I need to change this part of you code
        var re =/.*\/|\.pdf$/ig;
        var FileNM = this.path.replace(re,"")+".pdf";
        But I can’t get what I want.
        Any help will be appreciated
        • 151. Re: Print File Name with pdf Document
        interstate 8 Level 1
        Is it possible to print the the specific bookmark title/page title of each page in the footer of the pdf?
        • 152. Re: Print File Name with pdf Document
        Jasonkzh Level 1
        Another method, but not using Java Script, and this method may applied to each single file only.
        http://www.uwec.edu/help/Acrobat9/for-date.htm
        • 153. Re: Print File Name with pdf Document
        WKLee_KC Level 1
        I have modified Java Script. This is to make footer as the bookmark name of each pages(only applies 1st level bookmarks). I use this script when I merge many files into one PDF.
        Please see below:
        app.addSubMenu({ cName: "BMKFooter",cUser: "BookMark Footer", cParent: "File", nPos: 21 });
        app.addMenuItem({ cName: "Set", cParent: "BMKFooter", cExec: "SetFooter(9)"});
        app.addMenuItem({ cName: "-------------------------------", cParent: "BMKFooter",cExec: "{}"});
        app.addMenuItem({ cName: "Remove", cParent: "BMKFooter", cExec: "RemoveFooter(9)"});
        //Set/remove Footer
        var bmk = this.bookmarkRoot;
        var BMKName;
        var lastBMKPage=0;
        var currentBMKPage=0;
        var p=0;
        if(bmk.children != null){
        for(var i = 0; i < bmk.children.length; i++){
        BMKName=bmk.children[i].name;
        if(i<=bmk.children.length-2){
        bmk.children[i+1].execute();
        lastBMKPage = this.pageNum-1; }
        else {lastBMKPage = this.numPages -1;}
        for ( p = currentBMKPage; p <= lastBMKPage; p++){
        var aRect = this.getPageBox("Crop",p);
        if (ARG==9)
        {var  fd = this.addField(String("xftDate"+p+1), "text", p, [30+TotWidth/2,15, TotWidth-30,40]);
        fd.value = " " + BMKName +" "; //print bookmark name
        fd.textSize=10; fd.readonly = true;
        fd.alignment="right";
        currentBMKPage = lastBMKPage +1;
        function RemoveFooter(ARG)
        if (ARG==9)
        {for (var p = 0; p < this.numPages; p++)
        {var x = this.removeField(String("xftDate"+p+1));}
        //if (ARG==9)
        //{ for (var p = 0; p < this.numPages; p++)
        //{var x = this.removeField(String("xftPage"+p+1)); }
        //if (ARG<=3 || ARG==9) {var x = this.removeField("xftRem");}
        This is very late response. But I hope this is helpful for you.
        • 154. Re: Print File Name with pdf Document
        lhb1511@qq.com Level 1
        Hi ReinhardF!
        In Acrobat 9 Pro Batch, execute JavaScript, please provide a script to add the footer and displays the date and file name,
        Thank you very much!
        • 155. Re: Print File Name with pdf Document
        saintjohnny Level 1
        For googlers who find this thread down the road:
        I made a tool to batch stamp PDF filenames.  You can get it here:
        http://saintjohnny.com/pdffilenamelabeler
        I've also added so that you can also stamp prefix/suffix before and after the filename, as well as stamp custom text ignoring filenames, and change the height of the stamp to go on the top of the page as a header if needed.  Since this isn't a true footer/header, it retains the information when combining PDFs later on which is a plus.
        • 156. Re: Print File Name with pdf Document
        gina_block Level 1
        Perhaps someone has already suggested this, but if you are using Acrobat Pro (I'm on 11.0.0), go to Tools (now located on the upper right of the PDF) > Print Production > Add Printer Marks > Page Information. This will place the filename on the lower left of your PDF. You can also add trim, reg marks, and color bars, etc.
        • 157. Re: Print File Name with pdf Document
        linnrokenes Level 1
        The script to print filename in footer is great, but is there a way to print the filename ie in top or bottom center of the "selected view"?
        • 158. Re: Print File Name with pdf Document
        markwepl Level 1
        I really don't understand all this Java Script stuff.  Why, oh why, is this not built into the basic product?  Seems like a NO BRAINER.  Absolutely should not take a programmer to do this simple task...
        Just saying...
        • 159. Re: Print File Name with pdf Document
        gkaiseril MVP & Adobe Community Professional
        One can use the add water mark from text to place the file name anywhere on the page. One could also add a field to any location on the page and set it's value to the file name.
