1. Re: After Installing Elements 10, stuff doesn't work - help?
99jon Dec 9, 2011 2:13 PM (in response to Highdesertdweller)Normally works well unless you are using a portable PC with restrictive display.
Go to the control panel and check dpi scaling under Appearance or Display.
It’s not uncommon to see a setting of 125% or higher to improve screen readability but PSE requires a dpi of 96 or 100%
Whilst the Editor Menu will appear at 120% to 149% the Organizer Menu (and the advanced button in downloader) won’t. Sometimes the mouse or tool cursors are distorted.
Try a setting of 115% or 116% otherwise 100%. A common display resolution, notably for notebooks/laptops, and netbooks is 1024 x 768 but PSE requires a screen height of 800 for full functionality. If your height resolution is out of the range 768 to 800 try experimenting with the slider.
2. Re: After Installing Elements 10, stuff doesn't work - help?
Highdesertdweller Dec 9, 2011 4:10 PM (in response to 99jon)I'm in Editor and so that shouldn't be the issue....Organizer looks fine, but haven't tried it because I bought this program specifically for Editor. Thanks.
3. Re: After Installing Elements 10, stuff doesn't work - help?
R_Kelly Dec 9, 2011 4:33 PM (in response to Highdesertdweller)When you press the X on the top right of the screen do you hear a beeping sound?
Is this the line your talking about when typing? If so that is just showing you where the baseline for the text is and should go away when you commit the text.
The double underline is when you select the text to edit it (double click on the text layer in the layers palette)?
4. Re: After Installing Elements 10, stuff doesn't work - help?
Highdesertdweller Dec 9, 2011 5:52 PM (in response to R_Kelly)Yes, I just figured that out.....hmmmm.....where do they tell you that and why is it necessary to be so confusing. Just viewing the text as you type tells you where it's going to be......not a good design. Just my opinion after spending over an hour just trying to figure that out! Wonder what they were thinking....???
