1. Re: import jpeg orientation and size problems
JSS1138 Dec 10, 2011 12:30 PM (in response to nefl777)Scale to Frame Size much be checked before you import your stills. It won't have any effect on stills already imported.
2. Re: import jpeg orientation and size problems
nefl777 Dec 10, 2011 12:46 PM (in response to JSS1138)Hi and thanks for taking the time to answer!
I doublechecked that I had 'scale to frame' clicked in my preferences, and then I imported a still.
It still appears portrait when it should be Landscape. when I click on it in the media browser, this is what I see
and, here are my preferences. which were set before the import.
I'm on a Mac. In "finder" which is the directory utility, the icons appear as they should. In other words, the images are not in need of rotating before I use them.
any other ideas ?
thanks !
3. Re: import jpeg orientation and size problems
JSS1138 Dec 10, 2011 12:49 PM (in response to nefl777)The portrait issue is something else. Not sure what causes that. (Other than it actually being oriented that way and using a flag to tell programs to turn it automatically, which PP doesn't recognize.)
4. Re: import jpeg orientation and size problems
Bill Hunt Dec 10, 2011 1:11 PM (in response to JSS1138)What often happens with portrait Images is that one uses a program, like Bridge, to do the rotation. However, until the Image has been Saved, the actual pixels have not been Rotated - only the display. A flag is placed in the metadata, on how to display the image. One needs to Save in the new Orientation, to get it correct.
Now, one CAN adjust the Fixed Effect>Rotation with the Still Selected, in the Effects Control Panel.
Good luck,
Hunt
5. Re: import jpeg orientation and size problems
nefl777 Dec 10, 2011 1:34 PM (in response to Bill Hunt)Interesting.
I actually received these jpg files from a friend, on a CD. when I copied them onto my Mac, they appear in Finder as they should.
I'll fiddle with other programs to see how they appear.
In the meantime, yes, the Effects rotation thing is what I'm using to adjust.
thanks guys!
6. Re: import jpeg orientation and size problems
Bill Hunt Dec 10, 2011 6:07 PM (in response to nefl777)Not being a Mac-person, I cannot comment on Finder, but would guess that it's reading the metadata on how to display the images. If the Images were actually Rotated (pixel movement) in PS, their orientation should be as you expect.
Good luck,
Hunt
