One of the html editor's features is that it moves html tags
in a string of text when you edit pieces of the string separately.
In other words, if you have a sentence in bold and you
un-bold the first three words, the bold tag is moved to the fourth
word . Is the space inside the bold tag? That depends.
Then you unbold the rest of the sentence. The un-bold tag is
moved from the end back to the point where you began selecting
text. Is there now a "bold space" in the middle, or did we lose it?
That depends. Is there a <bold></bold> set with
nothing, not even a space, in the middle? That, too, depends.
Similarly, RH sometimes gets confused when you set
conditional build tags and change where the condition starts or
stops, or you remove the condition in chunks that aren't the same
as when you set the condition.
And similarly , when you edit bulleted or numbered
paragraphs.
You can't see what's wrong on the screen, and re-editing may
or may not straighten things out. The true code will tell.
Harvey
