Can I re-stream a stream from wowza to fms 4.5?
I have a wowza stream with the url similiar to rtmp://wowzaip/edge/app.stream. Is it possible to restream this to fms 4.5?
Never tried , but there should not be any problem in republishing. FMS accepts any source of RTMP as an input. Thanks for trying it out.
Yes. You can.
If you want FMS to pull from Wowza, you can use the netconnection and stream classes on the FMS side. If you want to push from Wowza to FMS, use the Wowza PushPublisher class (you can find examples on Wowza's forum)
Does anyone have a working example of how to pull the stream. Where and how in the main.asc do I add the url to pull from Wowza. I am a newbie to FMS 4.5. A little nudge in the right direction will help me a whole lot. Thanks.
// ADOBE SYSTEMS INCORPORATED
// Copyright 2009 Adobe Systems Incorporated
// All Rights Reserved.
// NOTICE: Adobe permits you to use, modify, and distribute this file in accordance with the
// terms of the Adobe license agreement accompanying it. If you have received this file from a
// source other than Adobe, then your use, modification, or distribution of it requires the prior
// written permission of Adobe.
load("ExLiveStream.asc");
//This function is called when the application starts and can be
//used for initialization.
application.onAppStart = function()
trace( "onAppStart - " + application.name + "\n" );
application.streams = new Object();
application.childServers = new Object();
application.clientID = 0;
//This function is called when a client connects to the application.
//Api calls are setup to receive commands from the clients
application.onConnect = function( newClient )
application.clientID++;
newClient.clientID = application.clientID;
//clients send FCPublish to ask for the premission to publish a stream
newClient.FCPublish = function( name )
if (application.streams[name])
if (!application.streams[name].publisher)
//the stream exists, but there is no publisher
application.acceptPublish( name, newClient );
else if (newClient != application.streams[name].publisher)
//the stream is already published by another client
this.call("onFCPublish", null, {code:"NetStream.Publish.BadName", description:name});
else
//allow publish from the same client
this.call("onFCPublish", null, {code:"NetStream.Publish.Start", description:name});
else
//stream doesn't exist, create a new one
application.streams[name] = new ExLiveStream(name, "rtmp://localhost/dummy", 1000, 1);
//clients send FCUnpublish to release the usage of a stream, so other clients can publish to the stream
newClient.FCUnpublish = function( name )
if (application.streams[name] && newClient == application.streams[name].publisher)
application.acceptUnpublish( name, newClient );
this.call("onFCUnpublish", null, {code:"NetStream.Unpublish.Success", description:name});
//add alternate unpublish function used by several encoders
newClient.releaseStream = function( name )
//force to unpublish
// first be nice, and issue an unpublish notification
// worst case if the the unpublish failed, force a removal of the stream
s = Stream.get(name);
s.play(false);
//when a client wants to subscribe to a live stream in this app.
newClient.FCSubscribe = function( name )
if (application.streams[name] == null)
application.streams[name] = new ExLiveStream( name, "rtmp://localhost/dummy", 1000, 1, null );
application.streams[name].addSubscriber(this);
this.call("onFCSubscribe", null, {code:"NetStream.Play.Start", description:name});
//when a client stops subcribing.
newClient.FCUnsubscribe = function( name )
if (application.streams[name] != null)
application.streams[name].removeSubscriber(this);
this.call("onFCUnsubscribe", null, {code:"NetStream.Play.Stop", description:name});
//when another server wants to register as a child server
newClient.FCAddChild = function()
//go through the all the streams and return the stream name to the client
for (i in application.streams)
if (application.streams.publisher)
this.call("addStream", null, i);
//add the client to the subscriber list
application.childServers[this.clientID] = newClient;
return true;
//When a client disconnects
application.onDisconnect = function( client )
//walk through all the streams and remove the disconnecting client form the subscriber list.
for (p in application.streams)
application.streams
.removeSubscriber( client );
client.FCUnpublish( p );
//if the client is a child server, remove it from the property of childServers.
application.childServers[client.clientID] = null;
delete application.childServers[client.clientID];
//Accept a publisher and notify everyone the stream is add
application.acceptPublish = function( name, client )
application.streams[name].setPublisher(client);
client.call("onFCPublish", null, {code:"NetStream.Publish.Start", description:name});
//notify all subscribers
application.streams[name].notifyClient("onFCSubscribe", {code:"NetStream.Play.PublishNotify", description: name});
//notify all the childServers a new stream is published
for (i in application.childServers)
application.childServers.call("addStream", null, name);
//Accept an unpublisher and notify everyone the stream is removed
application.acceptUnpublish = function( name, client )
application.streams[name].setPublisher(null);
application.streams[name].notifyClient("onFCSubscribe", {code:"NetStream.Play.UnpublishNotify", description: name});
//notify all the childServers a stream is unpublished
application.childServers.call("removeStream", null, name);
I have the same problem. I have to pull a stream from a non-FMS server then broadcast it.
NetConnection can connect to a remote server however, according to the API, if I understand it correctly, the remote server must be a Flash remoting server.
Have you found the solution to this?
