I'm having a heck of a time trying to send the contents of an
XSD file from Coldfusion through a Stored Procedure to Oracle and
have it register successfully. I keep getting the error message "An
error was encountered - -31020 -ERROR- ORA-31020: The operation is
not allowed, Reason: invalid characters in path name ". I am using
the CF XMLParse function to parse the XSD into a XML Document
variable. After some processing, I pass the ToString() value of the
XML variable to the procedure using cf_sql_clob as the sqltype. For
some reason unforseen to me, there are some invalid characters
within the passed value which causes the Oracle
DBMS_XMLSCHEMA.registerSchema() function to fail. At first I
thought there was a problem with the XSD contents but I was able to
successfully register the same file strictly using a Oracle stored
procedure without any interaction with CF. I've tried several
different things such as changing the data type in both the CF call
and the procedure parameters. I also tried to use cffile to read to
contents and pass the value directly to the procedure without using
any XML functions. Since I was able to register the XSD, I'm
assuming it's not a problem with the contents of the file. Anyone
have any ideas on why it's not working? Thanks in advance. Here's
the code I'm using for both:
