3 Replies Latest reply on Dec 20, 2011 6:15 AM by Rohit . Kumar
    Session Timeout when using StreamingAMFChannel
    ildaronline
      Hi. When using a StreamingAMFChannel the clients http session expires dropping the connection. I use programmatically created multiple mx:Consumer instances. Session expirations occur after 900 seconds from consumer subscription. How can i solve it?
        • 1. Re: Session Timeout when using StreamingAMFChannel
          Rohit . Kumar Adobe Employee
          Can you paste your services-config.xml as well as your client side code for setting up the consumer?
          Rohit
          • 2. Re: Session Timeout when using StreamingAMFChannel
            ildaronline Level 1
            Hi, Rohit,
            my services-config.xml
            <?xml version="1.0" encoding="UTF-8"?>
            <services-config>
            <!--    <factories>-->
            <!--        <factory id="SpringFactory" class="com.adobe.factories.MyFactory" /> -->
            <!--    </factories> -->
            <!--    <factories>-->
            <!--        <factory id="spring" class="blazeds.spring.factory.SpringFactory"/>-->
            <!--    </factories>-->
                <services>
                    <service-include file-path="remoting-config.xml" />
                    <service-include file-path="proxy-config.xml" />
                    <service-include file-path="messaging-config.xml" />
                    <default-channels>
                       <channel ref="my-amf"/>
                       <!-- <channel ref="my-streaming-amf"/>-->
                    </default-channels>
                </services>
                <security>
                    <login-command class="flex.messaging.security.TomcatLoginCommand" server="Tomcat"/>
                    <!-- Uncomment the correct app server
                    <login-command class="flex.messaging.security.TomcatLoginCommand" server="JBoss">
                    <login-command class="flex.messaging.security.JRunLoginCommand" server="JRun"/>
                    <login-command class="flex.messaging.security.WeblogicLoginCommand" server="Weblogic"/>
                    <login-command class="flex.messaging.security.WebSphereLoginCommand" server="WebSphere"/>
                    <security-constraint id="basic-read-access">
                        <auth-method>Basic</auth-method>
                        <roles>
                            <role>guests</role>
                            <role>accountants</role>
                            <role>employees</role>
                            <role>managers</role>
                        </roles>
                    </security-constraint>
                </security>
                <channels>
                    <channel-definition id="my-amf" class="mx.messaging.channels.AMFChannel">
                        <endpoint url="http://{server.name}:{server.port}/{context.root}/spring/messagebroker/amf" class="flex.messaging.endpoints.AMFEndpoint"/>
                    </channel-definition>
                    <channel-definition id="my-secure-amf" class="mx.messaging.channels.SecureAMFChannel">
                        <endpoint url="https://{server.name}:{server.port}/{context.root}/messagebroker/amfsecure" class="flex.messaging.endpoints.SecureAMFEndpoint"/>
                        <properties>
                            <add-no-cache-headers>false</add-no-cache-headers>
                        </properties>
                    <channel-definition id="my-polling-amf" class="mx.messaging.channels.AMFChannel">
                        <endpoint url="http://{server.name}:{server.port}/{context.root}/messagebroker/amfpolling" class="flex.messaging.endpoints.AMFEndpoint"/>
                        <properties>
                            <polling-enabled>true</polling-enabled>
                            <polling-interval-seconds>4</polling-interval-seconds>
                        </properties>
                    <channel-definition id="my-streaming-amf" class="mx.messaging.channels.StreamingAMFChannel">
                          <endpoint url="http://{server.name}:{server.port}/{context.root}/spring/messagebroker/streamingamf" class="flex.messaging.endpoints.StreamingAMFEndpoint" />
                         <properties>
                              <idle-timeout-minutes>0</idle-timeout-minutes>
                              <max-streaming-clients>10</max-streaming-clients>
                              <server-to-client-heartbeat-millis>5000</server-to-client-heartbeat-millis>
                             <user-agent-settings>
                                  <user-agent match-on="MSIE" kickstart-bytes="2048" max-streaming-connections-per-session="3" />
                                  <user-agent match-on="Firefox" kickstart-bytes="2048" max-streaming-connections-per-session="3" />
                              </user-agent-settings>
                        </properties>
                    <channel-definition id="my-http" class="mx.messaging.channels.HTTPChannel">
                        <endpoint url="http://{server.name}:{server.port}/{context.root}/messagebroker/http" class="flex.messaging.endpoints.HTTPEndpoint"/>
                    <channel-definition id="my-secure-http" class="mx.messaging.channels.SecureHTTPChannel">
                        <endpoint url="https://{server.name}:{server.port}/{context.root}/messagebroker/httpsecure" class="flex.messaging.endpoints.SecureHTTPEndpoint"/>
                        <properties>
                        </properties>
                </channels>
                <logging>
                    <target class="flex.messaging.log.ConsoleTarget" level="Error">
                        <properties>
                            <prefix>[BlazeDS] </prefix>
                            <includeDate>false</includeDate>
                            <includeTime>false</includeTime>
                            <includeLevel>false</includeLevel>
                            <includeCategory>false</includeCategory>
                        </properties>
                        <filters>
                            <pattern>Endpoint.*</pattern>
                            <pattern>Service.*</pattern>
                            <pattern>Configuration</pattern>
                            <pattern>Message.General</pattern>
                        </filters>
                    </target>
                </logging>
                <system>
                    <redeploy>
                        <enabled>false</enabled>
                        <watch-interval>20</watch-interval>
                        <watch-file>{context.root}/WEB-INF/flex/services-config.xml</watch-file>
                        <watch-file>{context.root}/WEB-INF/flex/proxy-config.xml</watch-file>
                        <watch-file>{context.root}/WEB-INF/flex/remoting-config.xml</watch-file>
                        <watch-file>{context.root}/WEB-INF/flex/messaging-config.xml</watch-file>
                        <watch-file>{context.root}/WEB-INF/flex/data-management-config.xml</watch-file>
                        <touch-file>{context.root}/WEB-INF/web.xml</touch-file>
                    </redeploy>
                </system>
            </services-config>
            Client code in .as
            var consumer:Consumer;
            consumer = new Consumer();
            consumer.destination = destination;
            consumer.addEventListener(MessageEvent.MESSAGE, onMsg);
            consumer.addEventListener(MessageAckEvent.ACKNOWLEDGE, acknowledgeHandler);
            consumer.addEventListener(MessageFaultEvent.FAULT, messageFaultHandler);
            consumer.channelSet = streamingChannelSet;
            mxml
            <mx:ChannelSet id="streamingChannelSet">
            <mx:StreamingAMFChannel url="{parentApplication.endPointRoot + '/spring/messagebroker/streamingamf'}"/>
            </mx:ChannelSet>
            Also i create destinations in java this way:
            MessageDestination destination = (MessageDestination)service
                                .createDestination(destinationName);
            destination.setSource(destinationName);
            ConfigMap accessConfig = new ConfigMap();
            accessConfig.addProperty("use-mappings", "true");
            accessConfig.addProperty("method-access-level", "remote");
            ConfigMap serviceAdapterConfig = new ConfigMap();
            serviceAdapterConfig.addProperty("access", accessConfig);
            destination.addChannel("my-streaming-amf");
            destination.addChannel("my-polling-amf");
            destination.addChannel("my-amf");
            destination.getServerSettings().setDurable(true);
            destination.setAdapter(
               new PublisherServiceAdapter(wellId, paramName)
            destination.start();
            private class PublisherServiceAdapter extends ServiceAdapter {
                    private String wellId;
                    private String paramName;
                    public PublisherServiceAdapter(String wellId, String paramName) {
                        super();
                        this.setId(UUIDUtils.createUUID());
                        this.wellId = wellId;
                        this.paramName = paramName;
                    @Override
                    public Object invoke(Message message) {
                        MessageService msgService = (MessageService)getDestination().getService();
                        msgService.pushMessageToClients(message, true);
                        msgService.sendPushMessageFromPeer(message, true);
                        return null;
                    @Override
                    public boolean handlesSubscriptions()
                        return true;
                    @Override
                    @SuppressWarnings("unchecked")
                    public Object manage(CommandMessage commandMessage){
                        if (commandMessage.getOperation() == CommandMessage.SUBSCRIBE_OPERATION) {
                            AcknowledgeMessage ackMessage = new AcknowledgeMessage();
                            Map<String, Object> paramData;// = wellOperdata.get(paramName);
                            if(wellsOperData.get(wellId) != null &&
                                    (paramData = (Map<String, Object>)wellsOperData.get(wellId).get(paramName)) != null){
                                Map<String, Object> sendData = new HashMap<String, Object>();
                                sendData.putAll(paramData);
                                sendData.put("wellId", wellId);
                                sendData.put("paramName", paramName);
                                ackMessage.setBody(sendData);
                            return ackMessage;
                        else
                            return null;
            • 3. Re: Session Timeout when using StreamingAMFChannel
              Consider setting heartbeatinterval on the channelset in order to keep the session alive.
              Rohit
