6 Replies Latest reply on Dec 15, 2011 2:26 PM by Glitchdog
    Denoiser Problem
      I've never used denoiser before on clips, but I started filtering some of my clips with the denoiser and Premiere CS5 has crashed 18 times (yep I'm counting).  Is there a fix to this or should I avoid this altogether?
        • 1. Re: Denoiser Problem
          joe bloe premiere Level 5
          I never use it but....
          You might try nesting the clips that require 'Denoiser',
          and then only apply only a single iteration of the effect.
          • 2. Re: Denoiser Problem
            Skiibojosh Level 1
            What's a better alternative to denoiser?
            • 3. Re: Denoiser Problem
              Probably... not using noisy video.
              But aside from that, I'd use After Effects for any real problem clips.
              You can find a lot of different tutorials online (some good, others not so much).
              • 4. Re: Denoiser Problem
                Stephen_Spider Level 3
                Obviously it shouldn't crash by applying a filter.
                Post your system specs.
                After applying the effect you can select the clip pull down menu: Audio Options>Render and replace.
                • 5. Re: Denoiser Problem
                  Skiibojosh Level 1
                  Hardware Overview:
                    Model Name:          Mac Pro
                    Model Identifier:          MacPro1,1
                    Processor Name:          Dual-Core Intel Xeon
                    Processor Speed:          2.66 GHz
                    Number Of Processors:          2
                    Total Number Of Cores:          4
                    L2 Cache (per processor):          4 MB
                    Memory:          4 GB
                    Bus Speed:          1.33 GHz
                    Boot ROM Version:          MP11.005D.B00
                  System Version:          Mac OS X 10.6.8 (10K549)
                  Adobe Premiere Pro CS5:
                    Version:          5.0.4
                    Last Modified:          5/4/11 10:11 PM
                    Kind:          Intel
                    64-Bit (Intel):          Yes
                  • 6. Re: Denoiser Problem
                    Glitchdog Level 1
                    The denoiser filter is a known bug. I've reported it to Adobe and think others have too. We had the exact same problem (5.5.2). Many suggested using Audition, which is probably the best alternative, but we wanted to see if we could do it simply in PP. So we ended up using the EQ filter. Very basic, but it took a bit to learn how that particualar filter works. Just need to find the frequency of your noise and dial that out. Might be around 8k. All the best!
