1 Reply Latest reply: Dec 14, 2011 7:50 AM by Curt Y RSS
    labeling in full screen viewing mode
    Greg from Holland Community Member
      Hi there,
      Is it possible to
      a- label a photo when in full viewing modus without going out of full screen viewing modus?
      b- see if a photo is labeled in full screen viewing modus?
      c- get adobe to make this possible if it isnt possible yet?
      Sorry if it has asked before!
      Kind regards,
      Gregor
        • 1. Re: labeling in full screen viewing mode
          Curt Y Community Member
          To add a keyword you need the keyword panel visable, which as you know is not possible in fulll screen mode.
          You have a couple of options.  THe first is to re-arrange the screen so you have a full screen image by dragging the borders of the preview.  Then drag borders of the keywords panel to the side to be a long strip.  If I was to do this I would drag the content folder borders to be a long strip on the left side.
          Depending on monitor size and print orientation the picture rarely takes up 100% of the screen.  Use the gray borders to your advantage and still get max or nearly max size to the image.
          Once this is done open Windows/Workspace/new workspace and save with special name.  You can then change between this workspace and a more common view with a click as I believe it is added as a heading in toolbar right side.
          Hope this helps.
