1 2 Previous Next 58 Replies Latest reply on Oct 30, 2012 4:45 PM by Sunil Davé Branched from an earlier discussion.
    Crash with ADL using Flash Builder 4.6
    kabalweg Level 1
      I have this same issue but I'm using Flash Builder 4.6 with AIR 3.1. I tried overlaying Flex SDK 4.6 with AIR SDK 3.1 that I downloaded and I still get the this error. Do you know any fix you can suggest?
      Thanks. Any help is greatly appreciated.
      kabalweg
        • 1. Re: adl.exe has stopped working message
          chris.campbell Adobe Employee
          Hi Kabalweg,
          I'll give FB 4.6 a try and see if I can reproduce this.  Could you generate a crash dump for adl.exe and send it to me at ccampbel@adobe.com?
          Chris
          • 2. Re: adl.exe has stopped working message
            Just to follow up, I uninstalled 4.5, and installed 4.6 on Windows 7.  I created a new sample project with the 4.6 sdk (which already includes AIR 3.1) and I was able to build, run, and debug the project without crashing.  Do you have anything in your project that I should add into mine to reproduce this?
            Chris
            • 3. Re: adl.exe has stopped working message
              kabalweg Level 1
              I don't think so, no. I just created also a simple with nothing really in it. BTW, here's the crash log: http://forums.adobe.com/message/4057851#4057851
              Thanks...
              • 5. Re: adl.exe has stopped working message
                Thanks for the heads up.  I've tried it on a couple of machines so far without any luck.  Would you mind sending me a crash dump (.dmp file) so I can symbolicate and look at the call stack?  You can email me at ccampbel@adobe.com.
                Chris
                • 6. Re: adl.exe has stopped working message
                  kabalweg Level 1
                  I sent an email to you with the crash log as attachment.
                  Thanks...
                  • 7. Re: adl.exe has stopped working message
                    Kishan M V Adobe Employee
                    Can you please clear the temp folder and uninstall and install Flash Builder and change the current workspace. Do not overlay AIR 3.1 SDK and check if this is still reproducible?
                    Kishan
                    • 8. Re: adl.exe has stopped working message
                      kabalweg Level 1
                      I just did all of this to no avail. I still get the same ADL crash.
                      kabalweg.
                      • 9. Re: adl.exe has stopped working message
                        Could you try opening up a command prompt and seeing if you can use ADL via the command line?
                        Using the AIR debug launcher (ADL)
                        Chris
                        • 10. Re: adl.exe has stopped working message
                          kabalweg Level 1
                          I did that already but still the same error. It's only the ADL that's crashing because I can run applications through the browser and mobile device.
                          kabalweg
                          • 11. Re: adl.exe has stopped working message
                            So, you crash even if you do a "adl -help" at the command line?  If so, would you mind downloading the AIR sdk and just extract it to a folder (without bothering to do a flex overlay) and try the command line again?  If 3.1 crashes, can you try 2.7?
                            Adobe AIR SDK Latest
                            Adobe AIR SDK 2.7
                            Chris
                            • 12. Re: adl.exe has stopped working message
                              kabalweg Level 1
                              Running "adl -help" works, but running the command below results to a crash.
                              “C:\Program Files (x86)\Adobe\Adobe Flash Builder 4.6\sdks\4.6.0 (AIR 3.1)\bin\adl.exe” -runtime “C:\Program Files (x86)\Adobe\Adobe Flash Builder 4.6\sdks\4.6.0 (AIR 3.1)\runtimes\air\win” -profile mobileDevice -screensize 320×460:320×480 -XscreenDPI 163 -XversionPlatform IOS “C:\Users\myPC\Adobe Flash Builder 4.6\MobileLab\bin-debug\MobileLab-app.xml” “C:\Users\myPC\Adobe Flash Builder 4.6\MobileLab\bin-debug”
                              kabalweg
                              • 13. Re: adl.exe has stopped working message
                                Thanks for the update.  I'll research more.  Would you mind zipping up your MobileLab project and emailing it to me at ccampbel@adobe.com?
                                Chris
                                • 14. Re: adl.exe has stopped working message
                                  kabalweg Level 1
                                  Not at all. I sent the project to your email.
                                  kabalweg
                                  • 15. Re: adl.exe has stopped working message
                                    Thanks!  I'll take a look.  I heard back from one of our ADL experts and they suggested:
                                    I would normally try this. First, cd to the app.xml dir. Then run this much simpler command:
                                    “C:\Program Files (x86)\Adobe\Adobe Flash Builder 4.6\sdks\4.6.0 (AIR 3.1)\bin\adl.exe”  -profile mobileDevice -screensize 320×460:320×480 MobileLab-app.xml
                                    If this works, then add more options to the command line to see where it breaks.
                                    Chris
                                    • 16. Re: adl.exe has stopped working message
                                      Branched this discussion to a new topic.
                                      • 17. Re: adl.exe has stopped working message
                                        I was able to run your app using the default 4.6.0 sdk provided by Flash Builder 4.6 using the following ADL command line:
                                        "C:\Program Files (x86)\Adobe\Adobe Flash Builder 4.6\sdks\4.6.0\bin\adl.exe" -profile mobileDevice -screensize 320X460:320X480 -XscreenDPI 163 -XversionPlatform IOS MobileTest-app.xml
                                        It also worked fine for me using Flash Builder 4.6 itself, and setting the mobile configuration to an Applie iPhone 4.
                                        Chris
                                        • 18. Re: adl.exe has stopped working message
                                          I saw your message in the other thread that the simple command line causes a crash.  Are you sure you're using the default 4.6.0 sdk provided with the Flash Builder 4.6 install?  I noticed in your previous command line that you referenced "4.6.0 (AIR 3.1)" which looks like a custom directory.
                                          • 19. Re: adl.exe has stopped working message
                                            kabalweg Level 1
                                            Yes, I'm using the default 4.6.0 SDK now. I uninstall the Flash Builder 4.6 (and the 4.6.0 (AIR 3.1) in it) according to the suggestion of your co-worker in the other thread, and install a new one, hence, the 4.6.0.
                                            kabalweg
                                            • 20. Re: adl.exe has stopped working message
                                              Well, I'm stumped.  Unfortunately, the crash log you sent last week didn't contain any AIR related code in the call stack.  You might want to try creating a new, temporary, user account and seeing if the crash occurs there too.  Have you tried this on any other system?
                                              Chris
                                              • 21. Re: Crash with ADL using Flash Builder 4.6
                                                lucasmaj99
                                                Same, here. Exactly like kabalweb is describing. Was there ever a solution to this issues?
                                                • 22. Re: Crash with ADL using Flash Builder 4.6
                                                  We haven't been able to reproduce the crash.  Lucas, can you generate a crash dump for us and send it to ccampbel@adobe.com?
                                                  Chris
                                                  • 24. Re: Crash with ADL using Flash Builder 4.6
                                                    lucasmaj99 Level 1
                                                    Adam Lehman already joined in per Holly's blog, but no solution on the horizon yet.
                                                    • 25. Re: Crash with ADL using Flash Builder 4.6
                                                      Zaeiou
                                                      A few days upgraded to Flash Builder 4.6 with Lion, but now I am getting a crash. This is caused by running a simple default project (as shown) created by File/New/Flex Project. I properly uninstalled 4.5 prior to installing 4.6. I have also updated to latest versions of AIR and all Lion updates. I have a MacBook 2.3 gHz Intel Core i7.
                                                      <?xml version="1.0" encoding="utf-8"?>
                                                      <s:WindowedApplication xmlns:fx="http://ns.adobe.com/mxml/2009"
        xmlns:s="library://ns.adobe.com/flex/spark"
        xmlns:mx="library://ns.adobe.com/flex/mx">
                                                        <fx:Declarations>
                                                        <!-- Place non-visual elements (e.g., services, value objects) here -->
                                                        </fx:Declarations>
                                                      </s:WindowedApplication>
                                                      Here is the Lion crash report:
                                                      Process:         adl [258]
                                                      Path:            /Applications/Adobe Flash Builder 4.6/*/adl
                                                      Identifier:      adl
                                                      Version:         ??? (???)
                                                      Code Type:       X86 (Native)
                                                      Parent Process:  Adobe Flash Builder 4.6 [188]
                                                      Date/Time:       2011-12-14 21:33:53.102 -0600
                                                      OS Version:      Mac OS X 10.7.2 (11C74)
                                                      Report Version:  9
                                                      Interval Since Last Report:          2131 sec
                                                      Crashes Since Last Report:           10
                                                      Per-App Crashes Since Last Report:   10
                                                      Anonymous UUID:                      F166F2BF-69B6-4755-8575-4ED8168C66B9
                                                      Crashed Thread:  0  Dispatch queue: com.apple.main-thread
                                                      Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
                                                      Exception Codes: KERN_INVALID_ADDRESS at 0x00000000c0000020
                                                      VM Regions Near 0xc0000020:
                                                          Stack                  00000000bf800000-00000000c0000000 [ 8192K] rw-/rwx SM=COW
                                                          CG shared images       00000000c0003000-00000000c000b000 [   32K] r--/r-- SM=SHM
                                                      Application Specific Information:
                                                      objc_msgSend() selector name: backingScaleFactor
                                                      objc[258]: garbage collection is OFF
                                                      Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
                                                      0   libobjc.A.dylib                         0x929c5e87 objc_msgSend_fpret + 23
                                                      1   com.apple.AppKit                        0x90a4527a -[NSWindow _setFrame:updateBorderViewSize:] + 1223
                                                      2   com.apple.AppKit                        0x90a44915 -[NSWindow _oldPlaceWindow:] + 630
                                                      3   com.apple.AppKit                        0x909ee514 -[NSWindow _setFrameCommon:display:stashSize:] + 1657
                                                      4   com.apple.AppKit                        0x909ede96 -[NSWindow setFrame:display:] + 71
                                                      5   com.adobe.AIR                           0x01574a68 0x1000000 + 5720680
                                                      6   com.adobe.AIR                           0x016c594c 0x1000000 + 7100748
                                                      7   com.adobe.AIR                           0x0168661b 0x1000000 + 6841883
                                                      8   com.adobe.AIR                           0x01841106 0x1000000 + 8655110
                                                      9   com.adobe.AIR                           0x01842c59 0x1000000 + 8662105
                                                      10  com.adobe.AIR                           0x01846d57 0x1000000 + 8678743
                                                      11  com.adobe.AIR                           0x01872ead 0x1000000 + 8859309
                                                      12  com.adobe.AIR                           0x018df0bc 0x1000000 + 9302204
                                                      13  com.adobe.AIR                           0x015636c8 0x1000000 + 5650120
                                                      14  com.adobe.AIR                           0x01564d05 0x1000000 + 5655813
                                                      15  com.adobe.AIR                           0x01861b09 0x1000000 + 8788745
                                                      16  com.adobe.AIR                           0x0194576c FREGetObjectAsInt32 + 176322
                                                      17  com.apple.CoreFoundation                0x930ba091 -[NSObject performSelector:withObject:] + 65
                                                      18  com.apple.Foundation                    0x94b78f64 __NSThreadPerformPerform + 503
                                                      19  com.apple.CoreFoundation                0x9303184f __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 15
                                                      20  com.apple.CoreFoundation                0x93031206 __CFRunLoopDoSources0 + 246
                                                      21  com.apple.CoreFoundation                0x9305b0d8 __CFRunLoopRun + 1112
                                                      22  com.apple.CoreFoundation                0x9305a8ec CFRunLoopRunSpecific + 332
                                                      23  com.apple.CoreFoundation                0x9305a798 CFRunLoopRunInMode + 120
                                                      24  com.apple.HIToolbox                     0x9008ea7f RunCurrentEventLoopInMode + 318
                                                      25  com.apple.HIToolbox                     0x90095d9b ReceiveNextEventCommon + 381
                                                      26  com.apple.HIToolbox                     0x90095c0a BlockUntilNextEventMatchingListInMode + 88
                                                      27  com.apple.AppKit                        0x908ea040 _DPSNextEvent + 678
                                                      28  com.apple.AppKit                        0x908e98ab -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 113
                                                      29  com.apple.AppKit                        0x908e5c22 -[NSApplication run] + 911
                                                      30  com.adobe.AIR                           0x0100886a 0x1000000 + 34922
                                                      31  com.adobe.AIR                           0x010089cb 0x1000000 + 35275
                                                      32  com.apple.CoreFoundation                0x930ba091 -[NSObject performSelector:withObject:] + 65
                                                      33  adl                                     0x00002fa3 RuntimeMain(char const*, int) + 333
                                                      34  adl                                     0x000028ba start + 54
                                                      Thread 1:: Dispatch queue: com.apple.libdispatch-manager
                                                      0   libsystem_kernel.dylib                  0x9bc4a90a kevent + 10
                                                      1   libdispatch.dylib                       0x97071c58 _dispatch_mgr_invoke + 969
                                                      2   libdispatch.dylib                       0x970706a7 _dispatch_mgr_thread + 53
                                                      Thread 2:
                                                      0   libsystem_kernel.dylib                  0x9bc4a02e __workq_kernreturn + 10
                                                      1   libsystem_c.dylib                       0x9b50accf _pthread_wqthread + 773
                                                      2   libsystem_c.dylib                       0x9b50c6fe start_wqthread + 30
                                                      Thread 3:
                                                      Thread 4:
                                                      0   libsystem_kernel.dylib                  0x9bc4983e __psynch_cvwait + 10
                                                      1   libsystem_c.dylib                       0x9b50ce21 _pthread_cond_wait + 827
                                                      2   libsystem_c.dylib                       0x9b4bd42c pthread_cond_wait$UNIX2003 + 71
                                                      3   com.adobe.AIR                           0x016ecc99 0x1000000 + 7261337
                                                      4   com.adobe.AIR                           0x0152b120 0x1000000 + 5419296
                                                      5   com.adobe.AIR                           0x016ecd69 0x1000000 + 7261545
                                                      6   com.adobe.AIR                           0x016ecde3 0x1000000 + 7261667
                                                      7   com.adobe.AIR                           0x016ece7e 0x1000000 + 7261822
                                                      8   libsystem_c.dylib                       0x9b508ed9 _pthread_start + 335
                                                      9   libsystem_c.dylib                       0x9b50c6de thread_start + 34
                                                      Thread 5:
                                                      Thread 6:
                                                      Thread 7:
                                                      Thread 8:
                                                      1   libsystem_c.dylib                       0x9b50ce78 _pthread_cond_wait + 914
                                                      2   libsystem_c.dylib                       0x9b50cf7b pthread_cond_timedwait_relative_np + 47
                                                      3   com.adobe.AIR                           0x016ecb79 0x1000000 + 7261049
                                                      4   com.adobe.AIR                           0x0157e071 0x1000000 + 5759089
                                                      5   com.adobe.AIR                           0x0157e08e 0x1000000 + 5759118
                                                      6   com.adobe.AIR                           0x016ecd69 0x1000000 + 7261545
                                                      7   com.adobe.AIR                           0x016ecde3 0x1000000 + 7261667
                                                      8   com.adobe.AIR                           0x016ece7e 0x1000000 + 7261822
                                                      9   libsystem_c.dylib                       0x9b508ed9 _pthread_start + 335
                                                      10  libsystem_c.dylib                       0x9b50c6de thread_start + 34
                                                      Thread 9:
                                                      2   libsystem_c.dylib                       0x9b4bd3e0 pthread_cond_timedwait$UNIX2003 + 70
                                                      3   com.adobe.AIR                           0x016eccc5 0x1000000 + 7261381
                                                      4   com.adobe.AIR                           0x0172c48a 0x1000000 + 7521418
                                                      Thread 10:
                                                      Thread 11:
                                                      3   com.adobe.AIR                           0x01567248 0x1000000 + 5665352
                                                      4   com.adobe.AIR                           0x01564eb6 0x1000000 + 5656246
                                                      5   com.adobe.AIR                           0x015657ee 0x1000000 + 5658606
                                                      6   com.adobe.AIR                           0x0156581b 0x1000000 + 5658651
                                                      7   com.adobe.AIR                           0x016ecd69 0x1000000 + 7261545
                                                      8   com.adobe.AIR                           0x016ecde3 0x1000000 + 7261667
                                                      9   com.adobe.AIR                           0x016ece7e 0x1000000 + 7261822
                                                      10  libsystem_c.dylib                       0x9b508ed9 _pthread_start + 335
                                                      11  libsystem_c.dylib                       0x9b50c6de thread_start + 34
                                                      Thread 0 crashed with X86 Thread State (32-bit):
                                                        eax: 0x00155920  ebx: 0x00545a50  ecx: 0x9130490c  edx: 0xc0000000
                                                        edi: 0x001552b0  esi: 0x90a44dc1  ebp: 0xbfffda88  esp: 0xbfffda18
                                                         ss: 0x00000023  efl: 0x00010202  eip: 0x929c5e87   cs: 0x0000001b
                                                         ds: 0x00000023   es: 0x00000023   fs: 0x00000000   gs: 0x0000000f
                                                        cr2: 0xc0000020
                                                      Logical CPU: 2
                                                      Binary Images:
                                                          0x1000 -     0x6ff7 +adl (??? - ???) <4A9D2BEF-8A3D-77D9-29A5-DB5B7B4C50DC> /Applications/Adobe Flash Builder 4.6/*/adl
                                                        0x200000 -   0x2adff7  libcrypto.0.9.7.dylib (0.9.7 - compatibility 0.9.7) <7B6DB792-C9E5-3772-8734-8D0052757B8C> /usr/lib/libcrypto.0.9.7.dylib
                                                        0x7e0000 -   0x7eafff  com.apple.IOFWDVComponents (2.0.7 - 2.0.7) <811CF4D6-15B2-3EDA-B026-5E4B28C0F742> /System/Library/Components/IOFWDVComponents.component/Contents/MacOS/IOFWDVComponents
                                                        0x7f5000 -   0x7f9ffb  com.apple.audio.AudioIPCPlugIn (1.2.1 - 1.2.1) <B8333059-00BE-33A6-AEC0-0C8F285E6E07> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/C ontents/MacOS/AudioIPCPlugIn
                                                      0x1000000 -  0x21effc7 +com.adobe.AIR (??? - 3.1.0.4880) <98C235AB-2609-7063-F7C1-025C658A3AA0> /Applications/Adobe Flash Builder 4.6/*/Adobe AIR.framework/Versions/1.0/Adobe AIR
                                                      0x2555000 -  0x258eff3  com.apple.QuickTimeFireWireDV.component (7.7.1 - 2306) <5347333C-9175-39FF-AFEC-BF24BB6701D7> /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireD V
                                                      0x2599000 -  0x25c1fff  com.apple.QuickTimeIIDCDigitizer (7.7.1 - 2306) <6F887F4E-2D83-3415-9342-7EA8600E1349> /System/Library/QuickTime/QuickTimeIIDCDigitizer.component/Contents/MacOS/QuickTimeIIDCDi gitizer
                                                      0x25c9000 -  0x25cfffb  com.apple.audio.AppleHDAHALPlugIn (2.1.3 - 2.1.3f7) <C2DD672D-46CE-34BB-8456-129C65DDE583> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
                                                      0x2700000 -  0x274eff7  com.apple.QuickTimeUSBVDCDigitizer (2.7.1 - 2.7.1) <1D79F9C3-E0F4-33AE-A390-38DD884DEA28> /System/Library/QuickTime/QuickTimeUSBVDCDigitizer.component/Contents/MacOS/QuickTimeUSBV DCDigitizer
                                                      0x2758000 -  0x2785ff8  GLRendererFloat (??? - ???) <1264885F-1492-3591-BFB1-B671A7B08A29> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFl oat
                                                      0x3b00000 -  0x3c6dffc  GLEngine (??? - ???) <C49CCDEA-F23E-30CD-9BCD-FC09C9D07CF4> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
                                                      0x3e46000 -  0x3f3dffb  libGLProgrammability.dylib (??? - ???) <8E592FEB-B6A8-3BFF-828B-B37B05D4D574> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
                                                      0x6500000 -  0x67a0fe7  com.apple.ATIRadeonX3000GLDriver (7.14.5 - 7.1.4) <BA35443F-847C-344D-80C1-B9EC528B89C9> /System/Library/Extensions/ATIRadeonX3000GLDriver.bundle/Contents/MacOS/ATIRadeonX3000GLD river
                                                      0xa800000 -  0xab96fff  com.apple.driver.AppleIntelHD3000GraphicsGLDriver (7.14.5 - 7.1.4) <3085DB78-3E8E-3570-B235-3ED8F1E712B3> /System/Library/Extensions/AppleIntelHD3000GraphicsGLDriver.bundle/Contents/MacOS/AppleIn telHD3000GraphicsGLDriver
                                                      0x8feab000 - 0x8fedd9c7  dyld (195.5 - ???) <134323A7-49DC-3A9D-ACFD-32FAD0FD6BA2> /usr/lib/dyld
                                                      0x90005000 - 0x9000cffd  com.apple.NetFS (4.0 - 4.0) <D0D59145-D211-3E7C-9062-35A2833FA99B> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
                                                      0x90013000 - 0x9003bff0  com.apple.CoreServicesInternal (113.8 - 113.8) <9930695C-1C48-329F-93FD-5AEEE2EF942C> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
                                                      0x9003c000 - 0x9008bffb  com.apple.AppleVAFramework (5.0.14 - 5.0.14) <71C9D388-E607-3DB4-9FD3-FC918EB4A835> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
                                                      0x9008c000 - 0x903ccffb  com.apple.HIToolbox (1.8 - ???) <DFED9BD0-E142-397B-BE16-16EBCF3CE1EB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                                                      0x903f6000 - 0x9040bfff  com.apple.speech.synthesis.framework (4.0.74 - 4.0.74) <92AADDB0-BADF-3B00-8941-B8390EDC931B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
                                                      0x9040f000 - 0x90418ffb  com.apple.DisplayServicesFW (2.5.2 - 317) <DF4FCE9C-A4EE-3590-B079-495AC83836EA> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
                                                      0x90419000 - 0x9041cff7  libcompiler_rt.dylib (6.0.0 - compatibility 1.0.0) <7F6C14CC-0169-3F1B-B89C-372F67F1F3B5> /usr/lib/system/libcompiler_rt.dylib
                                                      0x90422000 - 0x906a7fe3  com.apple.QuickTime (7.7.1 - 2306) <F8C64DC4-3FE4-3A06-B10B-59E7F3BA6FDD> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
                                                      0x906df000 - 0x906efff7  libCRFSuite.dylib (??? - ???) <CE616EF3-756A-355A-95AD-3472A876BEB9> /usr/lib/libCRFSuite.dylib
                                                      0x90760000 - 0x907c2ffb  com.apple.datadetectorscore (3.0 - 179.4) <12EF80E0-35CC-30A7-942F-2F9E87C4C98C> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
                                                      0x907c3000 - 0x9081fff3  com.apple.Symbolication (1.2 - 83.1) <E651A2F1-CC13-3DDD-9B0A-09180014966B> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
                                                      0x90820000 - 0x9088ffff  com.apple.Heimdal (2.1 - 2.0) <DE626683-DF32-341B-8997-AE63309590C7> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
                                                      0x90896000 - 0x908dfff7  libGLU.dylib (??? - ???) <AEA2AD9A-EEDD-39B8-9B28-4C7C1BACB594> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
                                                      0x908e0000 - 0x9136effe  com.apple.AppKit (6.7.2 - 1138.23) <ADFA8D70-601E-3B5C-96FD-F45F52055CC8> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                                                      0x9137a000 - 0x9137dffd  libCoreVMClient.dylib (??? - ???) <2D135537-F9A6-33B1-9B01-6ECE7E929C00> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
                                                      0x915a8000 - 0x922f8fff  com.apple.QuickTimeComponents.component (7.7.1 - 2306) <B397F658-057A-3D84-ABC7-84AA6256DB88> /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponent s
                                                      0x922f9000 - 0x9230eff7  com.apple.ImageCapture (7.0 - 7.0) <116BC0CA-428E-396F-85DF-52793034D2A0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
                                                      0x9230f000 - 0x92420ff7  libJP2.dylib (??? - ???) <35D120D4-3304-3A02-9259-EB933E74E63A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJP2.dylib
                                                      0x92421000 - 0x9244eff7  com.apple.securityinterface (5.0 - 55004) <93C0285A-A266-3F21-82C9-434CBD3FA712> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
                                                      0x9244f000 - 0x92809ffb  com.apple.SceneKit (2.1 - 125.1) <7BFC0028-18AC-3B49-8DDC-CB7A7359D4F7> /System/Library/PrivateFrameworks/SceneKit.framework/Versions/A/SceneKit
                                                      0x9280a000 - 0x929beff3  libicucore.A.dylib (46.1.0 - compatibility 1.0.0) <6AD14A51-AEA8-3732-B07B-DEA37577E13A> /usr/lib/libicucore.A.dylib
                                                      0x929bf000 - 0x92a95a5b  libobjc.A.dylib (228.0.0 - compatibility 1.0.0) <A0EDB351-4B9D-3AA2-9D1A-0C22204FCCD3> /usr/lib/libobjc.A.dylib
                                                      0x92a96000 - 0x92ae6fff  libFontRegistry.dylib (??? - ???) <81E03B82-1F31-3702-97DC-BE20298E326F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
                                                      0x92b1c000 - 0x92b35fff  libPng.dylib (??? - ???) <A83B66DC-302C-3A4C-8107-0E5560708024> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
                                                      0x92eac000 - 0x92f27ffb  com.apple.ApplicationServices.ATS (317.5.0 - ???) <D5AC5C21-CE1E-333D-94F7-F0F534FD4DC7> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
                                                      0x92f88000 - 0x92fb6ff7  com.apple.DictionaryServices (1.2.1 - 158.2) <DA16A8B2-F359-345A-BAF7-8E6A5A0741A1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
                                                      0x92fb7000 - 0x9301cff7  libvDSP.dylib (325.4.0 - compatibility 1.0.0) <4B4B32D2-4F66-3B0D-BD61-FA8429FF8507> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
                                                      0x93020000 - 0x931f6fe3  com.apple.CoreFoundation (6.7.1 - 635.15) <AC9F6462-6315-3D89-8075-D048DB4DBF7E> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                                                      0x931f7000 - 0x93216fff  com.apple.RemoteViewServices (1.2 - 39) <C7B638D2-2F8B-3A45-916A-73103FADC822> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
                                                      0x93217000 - 0x93519fff  com.apple.CoreServices.CarbonCore (960.18 - 960.18) <8094724D-591D-3CC2-81DE-4E3029624E11> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                                                      0x9351a000 - 0x93543ffe  com.apple.opencl (1.50.63 - 1.50.63) <C4EC60D6-9A7C-3CE9-AA80-2F81D9BB4465> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
                                                      0x939ed000 - 0x93a2eff7  com.apple.CoreMedia (1.0 - 705.42) <B45070F1-4097-3BAD-AA7C-0F7AFD6EAC27> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
                                                      0x93a3a000 - 0x940e3eeb  com.apple.CoreGraphics (1.600.0 - ???) <322FC806-0B9F-3A58-8C88-D477E32A50F8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
                                                      0x940e4000 - 0x94135ff3  com.apple.CoreMediaIO (210.0 - 3180) <79AA7CA8-FC39-375D-9485-855D302DF7AA> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
                                                      0x94136000 - 0x941caff7  com.apple.LaunchServices (480.21 - 480.21) <E3621817-B627-3EEC-A7F9-0D45583B7FE8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
                                                      0x941cb000 - 0x941cffff  com.apple.CommonPanels (1.2.5 - 94) <3A988595-DE53-34ED-9367-C9A737E2AF38> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
                                                      0x9426c000 - 0x9426effb  libRadiance.dylib (??? - ???) <4721057E-5A1F-3083-911B-200ED1CE7678> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
                                                      0x9427a000 - 0x94297fff  libresolv.9.dylib (46.0.0 - compatibility 1.0.0) <95AE43ED-6C52-3B39-89B6-54C81C62F1FF> /usr/lib/libresolv.9.dylib
                                                      0x94298000 - 0x94298fff  com.apple.quartzframework (1.5 - 1.5) <EF66BF08-620E-3D11-87D4-35D0B0CD1F6D> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
                                                      0x94299000 - 0x94359fff  com.apple.CoreServices.OSServices (478.29 - 478.29) <EAAAAC1B-2599-3875-9068-DF7E6B5760A8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
                                                      0x94380000 - 0x943a2ff1  com.apple.PerformanceAnalysis (1.10 - 10) <45B10D4C-9B3B-37A6-982D-687A6F9EEA28> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
                                                      0x943a3000 - 0x943a3fff  com.apple.Carbon (153 - 153) <6FF98F0F-2CDE-3888-A304-4ED447D24CE3> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                                                      0x943a4000 - 0x943acff3  liblaunch.dylib (392.18.0 - compatibility 1.0.0) <CD470A1E-0147-3CB1-B44D-0B61F9061826> /usr/lib/system/liblaunch.dylib
                                                      0x943ad000 - 0x94417ff3  com.apple.CoreSymbolication (2.1 - 66) <B11C9057-1611-36A5-81F6-2C97A7047321> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
                                                      0x94440000 - 0x94440fff  libdnsinfo.dylib (395.6.0 - compatibility 1.0.0) <959E5139-EB23-3529-8881-2BCB5724D1A9> /usr/lib/system/libdnsinfo.dylib
                                                      0x94556000 - 0x9456aff7  com.apple.CFOpenDirectory (10.7 - 144) <665CDF77-F0C9-3AFF-8CF8-64257268B7DD> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
                                                      0x9456b000 - 0x945bcff9  com.apple.ScalableUserInterface (1.0 - 1) <C3FA7E40-0213-3ABC-A006-2CB00B6A7EAB> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterfa ce.framework/Versions/A/ScalableUserInterface
                                                      0x94609000 - 0x94a7eff7  FaceCoreLight (1.4.7 - compatibility 1.0.0) <312D0F58-B8E7-3F61-8A83-30C95F2EBEAA> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
                                                      0x94a7f000 - 0x94b23fff  com.apple.QD (3.12 - ???) <68CBE425-43BA-3E6D-8668-A4A67396E20D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
                                                      0x94b24000 - 0x94e2eff3  com.apple.Foundation (6.7.1 - 833.20) <B5092554-485A-3A7D-904B-B04B1EE5C50C> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                                                      0x94e31000 - 0x94e4bfff  com.apple.Kerberos (1.0 - 1) <D7920A1C-FEC4-3460-8DD0-D02491578CBB> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
                                                      0x95005000 - 0x9502dff7  libxslt.1.dylib (3.24.0 - compatibility 3.0.0) <FCAC685A-724F-3FE7-8416-146108DF75FB> /usr/lib/libxslt.1.dylib
                                                      0x9508c000 - 0x9516fff7  libcrypto.0.9.8.dylib (44.0.0 - compatibility 0.9.8) <BD913D3B-388D-33AE-AA5E-4810C743C28F> /usr/lib/libcrypto.0.9.8.dylib
                                                      0x95170000 - 0x951acfff  libcups.2.dylib (2.9.0 - compatibility 2.0.0) <AA56493C-D7C6-3D4F-8DC8-855405AFF57B> /usr/lib/libcups.2.dylib
                                                      0x951ad000 - 0x951c0ffb  com.apple.MultitouchSupport.framework (220.62.1 - 220.62.1) <3D94520B-C976-370F-AF56-278002BCF11D> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
                                                      0x951c1000 - 0x951ccfff  libkxld.dylib (??? - ???) <088640F2-429D-3368-AEDA-3C308C4EB80C> /usr/lib/system/libkxld.dylib
                                                      0x951cd000 - 0x9532ffff  com.apple.QTKit (7.7.1 - 2306) <5A7E5ED0-C4DC-3CEC-ABE0-24899134ACE1> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
                                                      0x95330000 - 0x95331ff0  libunc.dylib (24.0.0 - compatibility 1.0.0) <BCD277D0-4271-3E96-A4A2-85669DBEE2E2> /usr/lib/system/libunc.dylib
                                                      0x95f87000 - 0x95f8affc  libpam.2.dylib (3.0.0 - compatibility 3.0.0) <6FFDBD60-5EC6-3EFA-996B-EE030443C16C> /usr/lib/libpam.2.dylib
                                                      0x95f8b000 - 0x95fc1ff7  com.apple.AE (527.7 - 527.7) <7BAFBF18-3997-3656-9823-FD3B455056A4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
                                                      0x95fc2000 - 0x960b2ff1  libiconv.2.dylib (7.0.0 - compatibility 7.0.0) <9E5F86A3-8405-3774-9E0C-3A074273C96D> /usr/lib/libiconv.2.dylib
                                                      0x96487000 - 0x96487fff  com.apple.audio.units.AudioUnit (1.7.1 - 1.7.1) <2E71E880-25D1-3210-8D26-21EC47ED810C> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
                                                      0x96488000 - 0x96489ff5  libremovefile.dylib (21.0.0 - compatibility 1.0.0) <9A1E12B7-F822-3544-8E1D-A6DC81E1F2E6> /usr/lib/system/libremovefile.dylib
                                                      0x96507000 - 0x96557ff9  com.apple.QuickLookFramework (3.1 - 500.1) <28CB604E-2426-3491-BF16-2CDFD4C392B0> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
                                                      0x96558000 - 0x96565fff  libGL.dylib (??? - ???) <30E6DED6-0213-3A3B-B2B3-310E33301CCB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
                                                      0x9657a000 - 0x965c8ff3  com.apple.ImageCaptureCore (3.0.1 - 3.0.1) <DB40F137-4519-339B-81DC-7375B2FE8FD2> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
                                                      0x965c9000 - 0x965e6ff3  com.apple.openscripting (1.3.3 - ???) <31A51238-0CA1-38C7-9F0E-8A6676EE3241> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
                                                      0x96dbe000 - 0x96dc7fff  libc++abi.dylib (14.0.0 - compatibility 1.0.0) <FEB5330E-AD5D-37A0-8AB2-0820F311A2C8> /usr/lib/libc++abi.dylib
                                                      0x96dd4000 - 0x96dd5ff7  libsystem_sandbox.dylib (??? - ???) <BC0A04E9-4F28-3BC8-AA7B-63C3451E9212> /usr/lib/system/libsystem_sandbox.dylib
                                                      0x96dd6000 - 0x96ddaffd  IOSurface (??? - ???) <97E875C2-9F1A-3FBA-B80C-594892A02621> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
                                                      0x96f0a000 - 0x96f62fff  com.apple.HIServices (1.10 - ???) <76B50B43-6CFD-3067-A085-11420FD4FAA6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                                                      0x96f63000 - 0x96fa1fff  libRIP.A.dylib (600.0.0 - compatibility 64.0.0) <0AE59D4F-FFA7-3539-8B86-AD8993894AA0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
                                                      0x96fa2000 - 0x9702cffb  com.apple.SearchKit (1.4.0 - 1.4.0) <CF074082-64AB-3A1F-831E-582DF1667827> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
                                                      0x9706f000 - 0x9707dfff  libdispatch.dylib (187.7.0 - compatibility 1.0.0) <B50C62AD-0B5B-34C3-A491-ECFD72ED505E> /usr/lib/system/libdispatch.dylib
                                                      0x970af000 - 0x9714aff3  com.apple.ink.framework (1.3.2 - 110) <9F6F37F9-999E-30C5-93D0-E48D4B5E20CD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
                                                      0x9714b000 - 0x97181fff  com.apple.DebugSymbols (2.1 - 85) <0F996A4A-16A7-3C90-8037-0E2958D1FB16> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
                                                      0x97182000 - 0x9718afff  com.apple.DiskArbitration (2.4.1 - 2.4.1) <28D5D8B5-14E8-3DA1-9085-B9BC96835ACF> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
                                                      0x97254000 - 0x9732bffb  com.apple.avfoundation (2.0 - 180.30) <6788562E-A9A8-3898-A0F4-66D9BBAE3430> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
                                                      0x9732c000 - 0x9733afff  libz.1.dylib (1.2.5 - compatibility 1.0.0) <E73A4025-835C-3F73-9853-B08606E892DB> /usr/lib/libz.1.dylib
                                                      0x97389000 - 0x973f0fff  libc++.1.dylib (19.0.0 - compatibility 1.0.0) <3AFF3CE8-14AE-300F-8F63-8B7FB9D4DA96> /usr/lib/libc++.1.dylib
                                                      0x973f1000 - 0x973f2fff  libsystem_blocks.dylib (53.0.0 - compatibility 1.0.0) <B04592B1-0924-3422-82FF-976B339DF567> /usr/lib/system/libsystem_blocks.dylib
                                                      0x973f3000 - 0x97a6efe5  com.apple.CoreAUC (6.11.04 - 6.11.04) <B06D52C9-9F59-3EF2-B2BA-11E93C573572> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
                                                      0x97a6f000 - 0x97a73ff3  libsystem_network.dylib (??? - ???) <62EBADDA-FC72-3275-AAB3-5EDD949FEFAF> /usr/lib/system/libsystem_network.dylib
                                                      0x97a74000 - 0x97b94fec  com.apple.vImage (5.1 - 5.1) <008B989F-F080-398E-ACB1-FBF5BA107D6D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
                                                      0x97b95000 - 0x97cf6ffb  com.apple.QuartzCore (1.7 - 270.0) <0916DA83-6400-3FEA-BC53-5F4BA4D126EC> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                                                      0x97db5000 - 0x97e9dfff  libxml2.2.dylib (10.3.0 - compatibility 10.0.0) <ED3F5E83-8C76-3D46-B2FF-0D5BDF8970C5> /usr/lib/libxml2.2.dylib
                                                      0x97fb6000 - 0x980e2ff9  com.apple.CFNetwork (520.2.5 - 520.2.5) <02193949-50A8-3CBC-9920-5FCDB8EBE17A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
                                                      0x980e3000 - 0x980e4fff  liblangid.dylib (??? - ???) <C8C204E9-1785-3785-BBD7-22D59493B98B> /usr/lib/liblangid.dylib
                                                      0x980e5000 - 0x98114ff7  libsystem_info.dylib (??? - ???) <B86A363D-6EA2-3A69-A6CB-18B7F98FC61A> /usr/lib/system/libsystem_info.dylib
                                                      0x98115000 - 0x98267fff  com.apple.audio.toolbox.AudioToolbox (1.7.1 - 1.7.1) <7646E131-08EE-3D72-ADA2-4A61C562B36E> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                                                      0x98268000 - 0x98377ffb  com.apple.DesktopServices (1.6.1 - 1.6.1) <9F02752A-617B-3AC7-BCA1-F040C105EDDE> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
                                                      0x98388000 - 0x983c6fff  com.apple.NavigationServices (3.6 - 192) <CB7AE807-9292-3EBA-A5F5-D7DCEE28A5B7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.fram ework/Versions/A/NavigationServices
                                                      0x98408000 - 0x9842dff9  libJPEG.dylib (??? - ???) <743578F6-8C0C-39CC-9F15-3A01E1616EAE> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
                                                      0x98474000 - 0x98479ffd  libGFXShared.dylib (??? - ???) <820D744C-C641-3918-A72A-AC2E5276BCB6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
                                                      0x9847a000 - 0x984a4ff0  libpcre.0.dylib (1.1.0 - compatibility 1.0.0) <5CAA1478-97E0-31EA-8F50-BF09D665DD84> /usr/lib/libpcre.0.dylib
                                                      0x984cf000 - 0x988d1ff6  libLAPACK.dylib (??? - ???) <00BE0221-8564-3F87-9F6B-8A910CF2F141> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
                                                      0x98916000 - 0x98bc8ff7  com.apple.security (7.0 - 55010) <BE0350C5-5221-3BFF-B674-646AB1BA0F2E> /System/Library/Frameworks/Security.framework/Versions/A/Security
                                                      0x98bfd000 - 0x98c00fff  com.apple.AppleSystemInfo (1.0 - 1) <D2F60873-ECB1-30A8-A02E-E772F969116E> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
                                                      0x98c16000 - 0x98c32ff5  com.apple.GenerationalStorage (1.0 - 125) <F1D67293-9192-367D-AE74-2732B23E7E77> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
                                                      0x98c33000 - 0x98c33fff  com.apple.Cocoa (6.6 - ???) <650273EF-1ABC-334E-B745-B75AF028F9F4> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
                                                      0x98c34000 - 0x98c3dff3  com.apple.CommonAuth (2.1 - 2.0) <D49B41B1-A5DD-366A-8C30-49E9B875AA13> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
                                                      0x98c3e000 - 0x98cd5ff3  com.apple.securityfoundation (5.0 - 55005) <F5A98CC2-11C6-34F3-8F72-75B642627630> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
                                                      0x98cd6000 - 0x98dceff7  libFontParser.dylib (??? - ???) <83E7E71E-D217-3DEE-B288-F5BAE7E118C5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
                                                      0x98dcf000 - 0x98dcffff  com.apple.vecLib (3.7 - vecLib 3.7) <8CCF99BF-A4B7-3C01-9219-B83D2AE5F82A> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
                                                      0x98df6000 - 0x991e9feb  com.apple.VideoToolbox (1.0 - 705.42) <3F12F8A3-ED41-3EAD-A887-B7805353122C> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
                                                      0x991ea000 - 0x9952cfff  com.apple.MediaToolbox (1.0 - 705.42) <5AEFD5BE-6FA3-38F8-966A-B0AB56C472B8> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
                                                      0x9952d000 - 0x99534fff  com.apple.agl (3.1.4 - AGL-3.1.4) <CCCE2A89-026B-3185-ABEA-68D268353164> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
                                                      0x99540000 - 0x99542ff7  libdyld.dylib (195.5.0 - compatibility 1.0.0) <637660EA-8D12-3B79-B644-041FEADC9C33> /usr/lib/system/libdyld.dylib
                                                      0x998ec000 - 0x99979fe7  libvMisc.dylib (325.4.0 - compatibility 1.0.0) <F2A8BBA3-6431-3CED-8CD3-0953410B6F96> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
                                                      0x9997a000 - 0x999f6ffd  com.apple.PDFKit (2.6.1 - 2.6.1) <7BC3186B-80B7-3E68-AFDD-2734164BCCFB> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
                                                      0x99b2b000 - 0x99bebff3  com.apple.ColorSync (4.7.0 - 4.7.0) <A39EA668-D042-377F-BC81-26748CD57ADC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
                                                      0x99c3a000 - 0x99c48fff  com.apple.opengl (1.7.5 - 1.7.5) <81166D23-DE8E-3938-AAD3-29B1FA5E446E> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                                                      0x99c49000 - 0x99cabff3  libstdc++.6.dylib (52.0.0 - compatibility 7.0.0) <266CE9B3-526A-3C41-BA58-7AE66A3B15FD> /usr/lib/libstdc++.6.dylib
                                                      0x99cac000 - 0x99cd7fff  com.apple.GSS (2.1 - 2.0) <05A0171B-76EA-3E4C-8A36-65D1A978AF4B> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
                                                      0x99d36000 - 0x99fa9fff  com.apple.CoreImage (7.82 - 1.0.1) <6C99F458-E83A-3538-9B71-2C8BD0C9DCD5> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework /Versions/A/CoreImage
                                                      0x99faa000 - 0x9a080ff6  com.apple.QuickLookUIFramework (3.1 - 500.1) <4E259D94-6081-32D7-AD60-565E57B11EBA> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
                                                      0x9a081000 - 0x9a087ffd  com.apple.CommerceCore (1.0 - 17) <71641C17-1CA7-3AC9-974E-AAC9EB641035> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
                                                      0x9a088000 - 0x9a09effe  libxpc.dylib (77.17.0 - compatibility 1.0.0) <E01E0074-0830-3F20-8703-EA7722BFD358> /usr/lib/system/libxpc.dylib
                                                      0x9a09f000 - 0x9a0a0fff  libDiagnosticMessagesClient.dylib (??? - ???) <DB3889C2-2FC2-3087-A2A2-4C319455E35C> /usr/lib/libDiagnosticMessagesClient.dylib
                                                      0x9a0a1000 - 0x9a0a7ffb  com.apple.print.framework.Print (7.1 - 247.1) <5D7ADC17-D8EF-3958-9C0C-AA45B7717FBA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
                                                      0x9a0b1000 - 0x9a0d4fff  com.apple.CoreVideo (1.7 - 70.1) <3520F013-DF91-364E-88CF-ED252A7BD0AE> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                                                      0x9a0d5000 - 0x9a0dcff5  libsystem_dnssd.dylib (??? - ???) <B3217FA8-A7D6-3C90-ABFC-2E54AEF33547> /usr/lib/system/libsystem_dnssd.dylib
                                                      0x9a0dd000 - 0x9a13affb  com.apple.htmlrendering (76 - 1.1.4) <743C2943-40BC-36FB-A45C-3421A394F081> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework /Versions/A/HTMLRendering
                                                      0x9a1a8000 - 0x9a1b9fff  libbsm.0.dylib (??? - ???) <54ACF696-87C6-3652-808A-17BE7275C230> /usr/lib/libbsm.0.dylib
                                                      0x9a1ba000 - 0x9a1e0ffb  com.apple.quartzfilters (1.7.0 - 1.7.0) <9C8F1F3D-D570-3F5C-9B31-5B5B82161CDE> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
                                                      0x9a1e7000 - 0x9a227ff7  libauto.dylib (??? - ???) <984C81BE-FA1C-3228-8F7E-2965E7E5EB85> /usr/lib/libauto.dylib
                                                      0x9a328000 - 0x9a330ff5  libcopyfile.dylib (85.1.0 - compatibility 1.0.0) <A1BFC320-616A-30AA-A41E-29D7904FC4C7> /usr/lib/system/libcopyfile.dylib
                                                      0x9a331000 - 0x9a339ff3  libunwind.dylib (30.0.0 - compatibility 1.0.0) <E8DA8CEC-12D6-3C8D-B2E2-5D567C8F3CB5> /usr/lib/system/libunwind.dylib
                                                      0x9a33a000 - 0x9a559ff7  com.apple.imageKit (2.1.1 - 1.0) <9AF0A882-BEAD-3AEC-8A72-497A7C3C2358> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
                                                      0x9a652000 - 0x9a669ff8  com.apple.CoreMediaAuthoring (2.0 - 889) <49B55753-BD7E-3889-BA60-15294DA49CB7> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthor ing
                                                      0x9a66a000 - 0x9a675ffc  com.apple.NetAuth (1.0 - 3.0) <C07853C0-AF32-3633-9CEF-2480860C12C5> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
                                                      0x9b0a8000 - 0x9b0a8fff  com.apple.Accelerate (1.7 - Accelerate 1.7) <4192CE7A-BCE0-3D3C-AAF7-6F1B3C607386> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
                                                      0x9b0a9000 - 0x9b0aaffd  com.apple.MonitorPanelFramework (1.4.0 - 1.4.0) <45AC1CB9-2A81-3FEA-9BA4-E9BBA2582A28> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
                                                      0x9b0ab000 - 0x9b0acfff  com.apple.TrustEvaluationAgent (2.0 - 1) <4BB39578-2F5E-3A50-AD59-9C0AB99472EB> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
                                                      0x9b0ad000 - 0x9b0adffe  libkeymgr.dylib (23.0.0 - compatibility 1.0.0) <7F0E8EE2-9E8F-366F-9988-E2F119DB9A82> /usr/lib/system/libkeymgr.dylib
                                                      0x9b0ae000 - 0x9b1bdff7  libsqlite3.dylib (9.6.0 - compatibility 9.0.0) <90D36793-04A5-3BFF-BE83-EEEDCBEDC756> /usr/lib/libsqlite3.dylib
                                                      0x9b1be000 - 0x9b407ff7  com.apple.JavaScriptCore (7534.52 - 7534.52.7) <19E4C699-A9BA-3FCB-90CC-02C8F0607165> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
                                                      0x9b408000 - 0x9b495ff7  com.apple.CoreText (220.11.0 - ???) <4F98D709-75AC-35F0-AD88-8F2C4BD744C0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
                                                      0x9b4aa000 - 0x9b4abffd  libCVMSPluginSupport.dylib (??? - ???) <96F2F2F4-E7A9-36C8-B1CF-D58AA3DB2B44> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
                                                      0x9b4ac000 - 0x9b577fff  libsystem_c.dylib (763.12.0 - compatibility 1.0.0) <1B0A12B3-DAFA-31E2-8F82-E98D620E4D72> /usr/lib/system/libsystem_c.dylib
                                                      0x9b578000 - 0x9b5d1ffb  com.apple.coreui (1.2.1 - 164.1) <890E0BE9-3360-3B56-BE46-5A2421875A40> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
                                                      0x9b5d4000 - 0x9b65bfff  com.apple.print.framework.PrintCore (7.1 - 366.1) <BD9120A6-BFB0-3796-A903-05F627F696DF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
                                                      0x9b6c5000 - 0x9b6e7ffe  com.apple.framework.familycontrols (3.0 - 300) <F87D87EF-553A-3165-9C9A-6E117C537FE9> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
                                                      0x9b6e8000 - 0x9b72ffff  com.apple.SystemConfiguration (1.11.1 - 1.11) <CA6CE2B6-DC18-31FF-9668-70BB2FD8D7BB> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
                                                      0x9b730000 - 0x9b734ffa  libcache.dylib (47.0.0 - compatibility 1.0.0) <98A82BC5-0DD9-3212-9CAE-35A77278EEB6> /usr/lib/system/libcache.dylib
                                                      0x9b9a8000 - 0x9b9afff7  libsystem_notify.dylib (80.1.0 - compatibility 1.0.0) <47DB9E1B-A7D1-3818-A747-382B2C5D9E1B> /usr/lib/system/libsystem_notify.dylib
                                                      0x9baf7000 - 0x9baf8ff7  libquarantine.dylib (36.0.0 - compatibility 1.0.0) <70782AEC-8933-3EB4-91CA-E44C0E768C90> /usr/lib/system/libquarantine.dylib
                                                      0x9baf9000 - 0x9bb03ff2  com.apple.audio.SoundManager (3.9.4 - 3.9.4) <D23C4761-6492-3974-B4D2-495082B8B7A6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/V ersions/A/CarbonSound
                                                      0x9bb59000 - 0x9bb95ffd  libGLImage.dylib (??? - ???) <8251242B-E04E-3467-BD0F-834578B18AC0> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
                                                      0x9bc31000 - 0x9bc4fff7  libsystem_kernel.dylib (1699.22.73 - compatibility 1.0.0) <D32C2E9C-8184-3FAF-8694-99FC619FC71B> /usr/lib/system/libsystem_kernel.dylib
                                                      0x9bc58000 - 0x9bc9bffd  libcommonCrypto.dylib (55010.0.0 - compatibility 1.0.0) <4BA1F5F1-F0A2-3FEB-BB62-F514DCBB3725> /usr/lib/system/libcommonCrypto.dylib
                                                      0x9bc9c000 - 0x9bc9eff9  com.apple.securityhi (4.0 - 1) <BD367302-73C3-32F4-8080-E389AE89E434> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
                                                      0x9bc9f000 - 0x9bcaaff3  libCSync.A.dylib (600.0.0 - compatibility 64.0.0) <11726E50-E6FC-3AB0-8750-DDDCCF2B8534> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
                                                      0x9bcab000 - 0x9bd0cffb  com.apple.audio.CoreAudio (4.0.1 - 4.0.1) <089D78E0-46A6-38DB-9545-7F35CC815939> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                                                      0x9bd21000 - 0x9bd21fff  com.apple.Accelerate.vecLib (3.7 - vecLib 3.7) <22997C20-BEB7-301D-86C5-5BFB3B06D212> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
                                                      0x9bd22000 - 0x9bd97fff  com.apple.Metadata (10.7.0 - 627.20) <1E7C8194-8CE4-3103-A3D1-8913238AF923> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
                                                      0x9bde5000 - 0x9bde9fff  libGIF.dylib (??? - ???) <06E85451-F51C-31C4-B5A6-180819BD9738> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
                                                      0x9bdea000 - 0x9c2c6ff6  libBLAS.dylib (??? - ???) <134ABFC6-F29E-3DC5-8E57-E13CB6EF7B41> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
                                                      0x9c2c7000 - 0x9c2d7fff  com.apple.LangAnalysis (1.7.0 - 1.7.0) <6D6F0C9D-2EEA-3578-AF3D-E2A09BCECAF3> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
                                                      0x9c329000 - 0x9c38dfff  com.apple.framework.IOKit (2.0 - ???) <D14460ED-2B6C-375D-B3A4-B8C82E922666> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                                                      0x9c38e000 - 0x9c38eff0  com.apple.ApplicationServices (41 - 41) <BED33E1D-C95C-3654-9A3A-0CB3607F9F10> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
                                                      0x9c3c9000 - 0x9c441ff2  com.apple.CorePDF (3.0 - 3.0) <A0EC8F60-A622-347E-979A-F71939C45E5F> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
                                                      0x9c444000 - 0x9c62dff7  com.apple.CoreData (104 - 358.12) <F8AD7990-2C30-31A4-8E78-FA8DD5CF03CC> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
                                                      0x9c63c000 - 0x9c865ffb  com.apple.QuartzComposer (5.0 - 236) <7BD138F0-C748-3013-98C0-4D5F5E10B9AB> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
                                                      0x9c866000 - 0x9c894fe7  libSystem.B.dylib (159.1.0 - compatibility 1.0.0) <07D9A827-9567-34C2-9022-AF4BF975C9A7> /usr/lib/libSystem.B.dylib
                                                      0x9c8ad000 - 0x9c97cfff  com.apple.ImageIO.framework (3.1.1 - 3.1.1) <8B8A3DD3-BB3D-33FC-A714-81E1B883B155> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
                                                      0x9c97d000 - 0x9c97dff2  com.apple.CoreServices (53 - 53) <7CB7AA95-D5A7-366A-BB8A-035AA9E582F8> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
                                                      0x9c9a8000 - 0x9c9adff7  libmacho.dylib (800.0.0 - compatibility 1.0.0) <56A34E97-518E-307E-8218-C5D43A33EE34> /usr/lib/system/libmacho.dylib
                                                      0x9caee000 - 0x9cb3eff4  libTIFF.dylib (??? - ???) <E86EA22A-82C0-3E77-9EAF-739F385790D9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
                                                      0x9cb3f000 - 0x9cb4affb  com.apple.speech.recognition.framework (4.0.19 - 4.0.19) <17C11291-5B27-3BE2-8614-7A806745EE8A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
                                                      0x9cb4b000 - 0x9cb4fff7  com.apple.OpenDirectory (10.7 - 146) <3D3D30CE-6D82-3681-AA98-4E3AEFFA4229> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
                                                      0x9cb53000 - 0x9cb56ffb  com.apple.help (1.3.2 - 42) <DDCEBA10-5CDE-3ED2-A52F-5CD5A0632CA2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
                                                      0x9cb57000 - 0x9cb5aff7  libmathCommon.A.dylib (2026.0.0 - compatibility 1.0.0) <69357047-7BE0-3360-A36D-000F55E39336> /usr/lib/system/libmathCommon.A.dylib
                                                      External Modification Summary:
                                                        Calls made by other processes targeting this process:
                                                          task_for_pid: 2
                                                          thread_create: 0
                                                          thread_set_state: 0
                                                        Calls made by this process:
                                                          task_for_pid: 0
                                                          thread_create: 0
                                                          thread_set_state: 0
                                                        Calls made by all processes on this machine:
                                                          task_for_pid: 451
                                                          thread_create: 0
                                                          thread_set_state: 0
                                                      VM Region Summary:
                                                      ReadOnly portion of Libraries: Total=203.9M resident=110.1M(54%) swapped_out_or_unallocated=93.8M(46%)
                                                      Writable regions: Total=140.2M written=8800K(6%) resident=10.7M(8%) swapped_out=0K(0%) unallocated=129.5M(92%)
                                                      REGION TYPE                      VIRTUAL
                                                      ATS (font support)                 31.8M
                                                      ATS (font support) (reserved)         4K        reserved VM address space (unallocated)
                                                      CG shared images                    168K
                                                      CoreGraphics                          8K
                                                      CoreServices                       1676K
                                                      IOKit                               168K
                                                      MALLOC                             71.1M
                                                      MALLOC guard page                    32K
                                                      Memory tag=240                     6528K
                                                      Memory tag=242                       12K
                                                      Memory tag=243                        4K
                                                      Memory tag=249                      156K
                                                      Stack                              69.6M
                                                      VM_ALLOCATE                        16.1M
                                                      __CI_BITMAP                          80K
                                                      __DATA                             11.9M
                                                      __DATA/__OBJC                       200K
                                                      __IMAGE                            1256K
                                                      __IMPORT                              4K
                                                      __LINKEDIT                         45.0M
                                                      __OBJC                             2344K
                                                      __OBJC/__DATA                         4K
                                                      __PAGEZERO                            4K
                                                      __TEXT                            158.9M
                                                      __UNICODE                           544K
                                                      mapped file                        90.4M
                                                      shared memory                       308K
                                                      shared pmap                        7292K
                                                      TOTAL                             515.1M
                                                      TOTAL, minus reserved VM space    515.1M
                                                      Model: MacBookPro8,2, BootROM MBP81.0047.B24, 4 processors, Intel Core i7, 2.3 GHz, 4 GB, SMC 1.69f3
                                                      Graphics: AMD Radeon HD 6750M, AMD Radeon HD 6750M, PCIe, 1024 MB
                                                      Graphics: Intel HD Graphics 3000, Intel HD Graphics 3000, Built-In, 384 MB
                                                      Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1333 MHz, 0x80CE, 0x4D34373142353737334448302D4348392020
                                                      Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1333 MHz, 0x80CE, 0x4D34373142353737334448302D4348392020
                                                      AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xD6), Broadcom BCM43xx 1.0 (5.100.98.75.18)
                                                      Bluetooth: Version 4.0.1f4, 2 service, 18 devices, 1 incoming serial ports
                                                      Network Service: Wi-Fi, AirPort, en1
                                                      Serial ATA Device: Hitachi HTS725050A9A362, 500.11 GB
                                                      Serial ATA Device: HL-DT-ST DVDRW  GS31N
                                                      USB Device: hub_device, 0x0424  (SMSC), 0x2513, 0xfa100000 / 3
                                                      USB Device: Apple Internal Keyboard / Trackpad, apple_vendor_id, 0x0252, 0xfa120000 / 5
                                                      USB Device: BRCM2070 Hub, 0x0a5c  (Broadcom Corp.), 0x4500, 0xfa110000 / 4
                                                      USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x821a, 0xfa113000 / 8
                                                      USB Device: FaceTime HD Camera (Built-in), apple_vendor_id, 0x8509, 0xfa200000 / 2
                                                      USB Device: hub_device, 0x0424  (SMSC), 0x2513, 0xfd100000 / 2
                                                      USB Device: IR Receiver, apple_vendor_id, 0x8242, 0xfd110000 / 3
                                                      • 26. Re: Crash with ADL using Flash Builder 4.6
                                                        I think I asked this earlier but I didn't see a response.  Is anyone crashing ADL against the AIR 2.7 SDK?
                                                        Chris
                                                        • 27. Re: Crash with ADL using Flash Builder 4.6
                                                          Zaelou,
                                                          I suspect you might be running into a known issue with late model Apple computers running 10.7.2. Can you try a couple of workarounds to see if this solves your crash?
                                                          • Open System Preferences, select Energy Saver and disable Automatic graphics switching (or use a third party GPU switcher, such as gfxCardStatus and enable the Nvidia GPU)
                                                          • Before launching your AIR based application, launch either Google Chrome or Mozilla Firefox.
                                                          We apologize for the inconvenience and hope to have this resolved soon.
                                                          Chris
                                                          • 28. Re: Crash with ADL using Flash Builder 4.6
                                                            lucasmaj99 Level 1
                                                            Any work arounds for Win7?
                                                            • 29. Re: Crash with ADL using Flash Builder 4.6
                                                              Zaeiou Level 1
                                                              Chris,
                                                              Yes. I have confirmed that disabling Automatic Graphics Switching does eliminate the crash on Lion 10.7.2.
                                                              BTW, the crash occurs both in the FB4.6 IDE, and also with an installed .air app.
                                                              Thank you,
                                                              Zaeiou
                                                              • 30. Re: Crash with ADL using Flash Builder 4.6
        kabalweg Level 1
        Hi All,
        I was able to get around this error on Windows 7. What I did was login as different user that's on a different domain and it runs fine.
        Problem is, this user is not the main one that I use when developing. And so I have to switch back and forth the user just to be able to develop in Flash Builder 4.6 - just not a good way to be productive.
        Joel
        • 31. Re: Crash with ADL using Flash Builder 4.6
        lucasmaj99 Level 1
        Yes, same here. Logged in as brand new "test" user and no crash. So ... what would be a perm solution?
        • 32. Re: Crash with ADL using Flash Builder 4.6
        Ok, thanks for the feedback that the new user account is working properly.  It sounds like something exists on your regular accounts that is causing a conflict.
        Could you try temporarily removing the following folder and seeing if that makes a difference?
        C:\Users\UserName\AppData\Roaming\Adobe\AIR\CRLCache
        Chris
        • 33. Re: Crash with ADL using Flash Builder 4.6
        archemedia Level 4
        Thanks Chris, that solved it for me!
        Any idea when this will be fixed?
        Dany
        • 34. Re: Crash with ADL using Flash Builder 4.6
        lucasmaj99 Level 1
        Sorry, behavior did not change. Still crashing.
        • 35. Re: Crash with ADL using Flash Builder 4.6
        Naresh_Reddy Level 1
        Re:Crash with ADL using latest SDK - 4.6 with AIR Version - 3.1
        I am using Flash Builder - 4.0 with upgraded version of 4.6 SDK from 4.1/4.5.1.
        When I am trying to debugging my code Adobe AIR Debug Launcher has stopped working with following ERROR Details:
        If I Use Adobe 4.6 SDK ADL is getting crashed following is the Error Message.
        Any solution for this issue would be appriciated .
        Problem signature:
        Problem Event Name:                        APPCRASH
        Application Name:                             adl.exe
        Application Version:                           3.1.0.4880
        Application Timestamp:                    4eb7612e
        Fault Module Name:                          Adobe AIR.dll
        Fault Module Version:                        3.1.0.4880
        Fault Module Timestamp:                 4eb75fb9
        Exception Code:                                  c0000005
        Exception Offset:                                00183969
        OS Version:                                          6.1.7600.2.0.0.274.10
        Locale ID:                                             1033
        Additional Information 1:                  0a9e
        Additional Information 2:                  0a9e372d3b4ad19135b953a78882e789
        Additional Information 3:                  0a9e
        Additional Information 4:                  0a9e372d3b4ad19135b953a78882e789
        Read our privacy statement online:
        http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
        If the online privacy statement is not available, please read our privacy statement offline:
        C:\Windows\system32\en-US\erofflps.txt
        Naresh Reddy.
        • 36. Re: Crash with ADL using Flash Builder 4.6
        bmilesp Level 1
        same issue happens for me on windows Vista. Clearing the AIR cache as suggested did not work. Any new ideas?
        • 37. Re: Crash with ADL using Flash Builder 4.6
        Officeissue and bmilesp,
        Does this crash still occur if you create a new, temporary, user account and try building from there?  I've been unable to reproduce the issue and am hoping we can figure out what's different between the accounts.
        Chris
        • 38. Re: Crash with ADL using Flash Builder 4.6
        Hey Chris
        I downloaded 4.6 SDK from Adobe site using my Original Account.Do you want me to create temporary account to get this 4.6 SDK ?
        I didn't try that way, anyhow i'll create one temporary account to get 4.6 SDK and i'll proceed from there onwards.I'll let you know the result.
        Naresh Reddy.
        • 39. Re: Crash with ADL using Flash Builder 4.6
        Hi Naresh,
        I'm sorry I wasn't clear in my previous post.  I should have said a new, temporary, windows account.  Other devs in this thread have stated that doing this allowed ADL to run without crashing.  Just wanted to figure out if it helps you too.
        Chris
        1 2 Previous Next
