10 Replies Latest reply on Dec 15, 2011 11:49 AM by Milo G
    Script for removing color definitions
    Milo G Level 1
      I'm trying to create a script that will remove color definitions other than the default plus our corporate colors. I'm thinking some kind of "while" loop to go through the doc's color list, matching it to an array of named colors.
      I see that there is a Color object and methods such as Delete(), but it's not coming together for me.
      Any help would be appreciated.
        • 1. Re: Script for removing color definitions
          Chintu_123 Level 1
          I am posting a small snippet which demonstrates how to traverse the color object in doc and delete it. The following sample iterates over all the color present in the doc until it finds a color named “testcolor” and then deletes it. It works on the active document.
          doc = app.ActiveDoc   //getting the active doc
          col  = doc.FirstColorInDoc   //getting the first color in doc
          while (col.ObjectValid() )  //checking if the color object is valid
              if (col.Name == "testcolor" )  // matching for testcolor
                  col.Delete()  //deleting the color
                  break
          else {
          col = col.NextColorInDoc
          Vikash
          FrameMaker Engineering team
          • 2. Re: Script for removing color definitions
            Milo G Level 1
            Finally able to get back to this project.
            Thanks for this snippet which does work great for removing a single "known" color. What I actually need to do is remove all colors except a specified list.
            I've made an attempt (I'm sill relatively new to JS programming), but it only deletes the first instance instead of iterating through all the color definitions:
            keepColors = new Array ("Black","White","Red","Green","Blue","Cyan","Magenta","Yellow","Dark Grey","Pale Green","Forest Green","Royal Blue","Olive","Salmon","Mauve","Light Salmon","Custom Color");
                if (col.Name in (keepColors))  //color exists
                   break
            else {
            col.Delete()  //delete color
            • 3. Re: Script for removing color definitions
              Chintu_123 Level 1
              You are using "break" in the while loop which will terminate the loop whenever the condition is true. Try the following snippet:
              while( col.ObjectValid() )
                   if (col.Name <not in> (keepColors) )  //Color doesn't exits
                        col2 = col.NextColorInDoc
                        col.Delete()
                        col = col2
                   else{
              Vikash
              Frame Engineering Team
              1 person found this helpful
              • 4. Re: Script for removing color definitions
                Milo G Level 1
                I think I need something more complicated than my solution for "<not in>."
                I tried:
                     if (!(col.Name in keepColors))
                Which successfully eliminated all non-default colors, but it also eliminated the custom colors I designated in keepColors.
                • 5. Re: Script for removing color definitions
                  Ian Proudfoot Adobe Community Professional
                  The problem is that (col.Name in keepColors) does not work on the string value of the array element. It is checking for the element's name which in an array is its index value. The way to do this is to create a for loop to check each value of the array against each color in the document.
                  Ian
                  • 6. Re: Script for removing color definitions
                    Milo G Level 1
                    Okay, I got it to work with the rather sloppy:
                         if (!(col.Name in {"Custom1":"", "Custom2":"", "Custom3":""}))
                    Thankfully we only have three corporate colors so this isn't too ugly. If someone has time, I would like to see a cleaner method of checking against an array (or list) of items as my next project is to clean out variables for which we have tons that are no longer acceptable.
                    Milo
                    • 7. Re: Script for removing color definitions
                      Try this as one way to solve the problem. It adds a new contains() method to the Array class.
                      var doc = app.ActiveDoc,
                          keepColors = ["Black","White","Red","Green","Blue","Cyan","Magenta","Yellow","Dark Grey","Pale Green","Forest Green","Royal Blue","Olive","Salmon","Mauve","Light Salmon","Custom Color"];
                      Array.prototype.contains = function (value) {
                          var i;
                          for (i = 0; i < this.length; i+=1) {
                              if (this[i] === value) {
                                  return true;
                      while(col.ObjectValid()){
                          if (!keepColors.contains(col.Name)) {
                              col2 = col.NextColorInDoc;
                              col.Delete();
                              col = col2;
                          else {
                              col = col.NextColorInDoc;
                      • 8. Re: Script for removing color definitions
                        Milo G Level 1
                        Well that did the trick! Sadly I only have a vague understanding of the code, but I'll happily copy and paste it for now.
                        I did find that I only need to list the custom colors in the array as, understandably, the default colors can't be deleted.
                        Milo
                        • 9. Re: Script for removing color definitions
                          Milo,
                          In JavaScript it is possible to extend the built-in classes. Normally the Array class has no method for testing if it contains an element with a specific value. The new anonymous function simply checks each element in the array and returns true if it matches the value parameter.
                          Aother useful way to extend the Array class would be to add an indexOf() method this could return the index number of a given value, or -1 if the value is not found.
                          Ian
                          • 10. Re: Script for removing color definitions
                            Milo G Level 1
                            Ah, it's starting to make sense. Thanks for taking the time for writing and explaining the code.
                            Milo
