1. Re: [JS] Menu Added via Scripting Moves
John Hawkinson Dec 16, 2011 9:13 AM (in response to Dan Rodney)Dan, I haven't gone and tested this in your example, so this is speculative but:
subMenu1 = app.scriptMenuActions.item(menuItem1T);
if( subMenu1 == null ) {
subMenu2 = app.scriptMenuActions.add(menuItem1T);
}This isn't really advisable. In CS5 and later, if you don't check .isValid, you can have problems (I think).
But also, in JavaScript, in general, you should not write
if (varname == null)
because it is usually sufficient to simply write
if (varname)
or
if (!varname)
and you should also never use the == operator when you can use the === operator, because it coerces to truthiness. So you should rather instead use
if (varname===null)
if you truly needed to check for null as opposed to undefined or zero.
Perhaps more significnatly, shouldn't you be setting submenu1 inside that if, rather than submenu2?
2. Re: [JS] Menu Added via Scripting Moves
Dan Rodney Dec 16, 2011 9:53 AM (in response to John Hawkinson)- .isValid doesn't seem to fix the issue of the submenu moving. It also doesn't work back in CS3. I'd like one set of code (if possible) that will work in CS3 and later. Although if I need two sets of code I can deal with that, as long as I know what would make it work in each version. The submenu is still moving and that's the real issue.
- Switching from == to === doesn't fix the issue of the submenu moving (although the == was working even if the error detection isn't as thruthful).
- Thanks for the eagle eye on the typo of submenu1 instead of 2, but that also doesn't fix it.
Taking into account your suggestions though, here's a slight update on the code, but the submenu still moves on relaunch. Otherwise it works, it's just that the submenu moves. Any more thoughts?
#targetengine "myTestMenu" var myFolder = Folder(app.activeScript.path); myFolder = myFolder.parent + '/Scripts Panel/'; var menuItem1Handler = function( /*onInvoke*/ ){ app.doScript(File(myFolder + 'MyTest1.jsx')); }; var menuItem2Handler = function( /*onInvoke*/ ){ app.doScript(File(myFolder + 'MyTest2.jsx')); }; menuInstaller() function menuInstaller() { var menuItem1T = "My Menu Item 1", menuItem2T = "My Menu Item 2", menuT = "MyTestMenu", subT = "Sub Menu", subs = app.menus.item("$ID/Main").submenus, sma, mnu; var refItem = app.menus.item("$ID/Main").submenus.item("$ID/&Layout"); subMenu1 = app.scriptMenuActions.item(menuItem1T); if( subMenu1 === null ) { subMenu1 = app.scriptMenuActions.add(menuItem1T); } subMenu2 = app.scriptMenuActions.item(menuItem2T); if( subMenu2 === null) { subMenu2 = app.scriptMenuActions.add(menuItem2T); } subMenu2.eventListeners.add("onInvoke", menuItem2Handler); mnu = subs.item(menuT); if( mnu === null ) { mnu = subs.add(menuT, LocationOptions.after, refItem); } mnu.menuItems.add(subMenu1); mnu.menuSeparators.add(); subsSubs = app.menus.item( '$ID/Main' ).submenus.item( menuT ).submenus; mnuSubMenu = subsSubs.item( subT ); if( mnuSubMenu === null) { mnuSubMenu = subsSubs.add( subT); } mnu.menuItems.add(subMenu2); };
3. Re: [JS] Menu Added via Scripting Moves
Dan Rodney Dec 16, 2011 9:59 AM (in response to Dan Rodney)Here's another variation without the ===null. But the same thing happens on relaunch. The submenu moves up.
I've read over http://www.indiscripts.com/post/2010/02/how-to-create-your-own-indesign-menus but I don't see any advice there either to help on this issue. There has to be some small thing I'm missing!
#targetengine "myTestMenu" var myFolder = Folder(app.activeScript.path); myFolder = myFolder.parent + '/Scripts Panel/'; var menuItem1Handler = function( /*onInvoke*/ ){ app.doScript(File(myFolder + 'MyTest1.jsx')); }; var menuItem2Handler = function( /*onInvoke*/ ){ app.doScript(File(myFolder + 'MyTest2.jsx')); }; menuInstaller() function menuInstaller() { var menuItem1T = "My Menu Item 1", menuItem2T = "My Menu Item 2", menuT = "MyTestMenu", subT = "Sub Menu", subs = app.menus.item("$ID/Main").submenus, sma, mnu; var refItem = app.menus.item("$ID/Main").submenus.item("$ID/&Layout"); subMenu1 = app.scriptMenuActions.item(menuItem1T); if( subMenu1 ) { subMenu1 = app.scriptMenuActions.add(menuItem1T); } subMenu2 = app.scriptMenuActions.item(menuItem2T); if( subMenu2) { subMenu2 = app.scriptMenuActions.add(menuItem2T); } subMenu2.eventListeners.add("onInvoke", menuItem2Handler); mnu = subs.item(menuT); if( mnu ) { mnu = subs.add(menuT, LocationOptions.after, refItem); } mnu.menuItems.add(subMenu1); mnu.menuSeparators.add(); subsSubs = app.menus.item( '$ID/Main' ).submenus.item( menuT ).submenus; mnuSubMenu = subsSubs.item( subT ); if( mnuSubMenu ) { mnuSubMenu = subsSubs.add( subT); } mnu.menuItems.add(subMenu2); };
4. Re: [JS] Menu Added via Scripting Moves
John Hawkinson Dec 16, 2011 10:03 AM (in response to Dan Rodney)If I run your script twice in a single session, I get errors.
It also looks like it's not designed to work from the ESTK (depending on app.activeScript.path), which suggest you're not debugging this very efficiently...
This error is undoubtedly due to your script not accounting for menu items that may already exist, and that's the case across a restart of InDesign -- menus persist.
You might want to add some $.writeln()s that run as it is looking for existing menus and reference points and whatnot.
Good luck!
5. Re: [JS] Menu Added via Scripting Moves
Dan Rodney Dec 16, 2011 9:45 PM (in response to John Hawkinson)OK, so the file reference didn't work from ESTK. Here's a new version that does things a bit differently. Running this from ESTK I no longer get any errors.
As far as I can tell, the problems are related to testing for existing menu items, because they are being created again. But I still don't know how to properly test for them and only add them if needed. I feel like I'm so close, but yet so far away! Any help is greatly appreciated.
#targetengine "myTestMenu" installMenu(); function installMenu() { // SET THE FILES THAT ARE TRIGGERED BY MENU ITEMS menuActionOneHandler = function( /*onInvoke*/ ){ app.doScript( File(myFolder + 'File-One.jsx') ); }; menuActionTwoHandler = function( /*onInvoke*/ ){ app.doScript( File(myFolder + 'File-Two.jsx') ); }; // SET THE TEXT TO APPEAR IN MENUS var menuTextOne = 'My Menu Item 1' ; var menuTextTwo = 'My Menu Item 2' ; var menuTitleMain = 'My Test Menu' ; var menuTitleSubMenu = 'Sub Menu' ; //CREATE MENU windowMenu = app.menus.item( '$ID/Main' ).submenus.item( '$ID/&Window' ); myMainMenu = app.menus.item( '$ID/Main' ).submenus.item( menuTitleMain) if( !myMainMenu.isValid ) { var myMainMenu = app.menus.item( '$ID/Main' ).submenus.add( menuTitleMain, LocationOptions.after , windowMenu) } // SET GENERAL VARIABLES try { myFolder = app.activeScript; } catch(e) { myFolder = File(e.fileName); // we are running from the ESTK } myFolder = myFolder.parent.parent + '/' ; //this file is in the "startup scripts" subfolder //CREATE MENU ITEMS menuActionOne = myMainMenu.submenus.item( menuTextOne ); if( menuActionOne == null ) { menuActionOne = app.scriptMenuActions.add( menuTextOne ); } menuActionOne.eventListeners.add( 'onInvoke', menuActionOneHandler ); myMainMenu.menuItems.add( menuActionOne ); myMainMenu.menuSeparators.add(); //CREATE SUB MENU try { var mySubMenu = myMainMenu.submenus.item( menuTitleSubMenu ); mySubMenu.title; } catch (e) { var mySubMenu = myMainMenu.submenus.add( menuTitleSubMenu ); } //END OF SUB MENU menuActionTwo = myMainMenu.submenus.item( menuTextTwo ); if( menuActionTwo == null ) { menuActionTwo = app.scriptMenuActions.add( menuTextTwo ); } menuActionTwo.eventListeners.add( 'onInvoke', menuActionTwoHandler ); myMainMenu.menuItems.add( menuActionTwo ); return true; } // end of installMenu()
6. Re: [JS] Menu Added via Scripting Moves
John Hawkinson Dec 16, 2011 9:54 PM (in response to Dan Rodney)As far as I can tell, the problems are related to testing for existing menu items, because they are being created again. But I still don't know how to properly test for them and only add them if needed. I feel like I'm so close, but yet so far away! Any help is greatly appreciated.
So, you're saying that .submenus.item("whatever").isValid and menus.item("whatever").isValid do not correctly tell you whether the menus exist? They should!
7. Re: [JS] Menu Added via Scripting Moves
கற்பனை (Imagine) Dec 16, 2011 10:49 PM (in response to John Hawkinson)Hi Dan,
Add the piece of code in before adding the menus to the main menu.
try {
app.menus.item("$ID/Main").submenus.item(menuTitleMain).remove();
}catch(e){}
I Hope this helps to you..
8. Re: [JS] Menu Added via Scripting Moves
John Hawkinson Dec 16, 2011 10:52 PM (in response to கற்பனை (Imagine))Imagine:
try { app.menus.item("$ID/Main").submenus.item(menuTitleMain).remove();
But that's wrong! It means you'll reset the menu item every time. Among other things, that means if your user assigns a KBSC, it will be lost.
9. Re: [JS] Menu Added via Scripting Moves
கற்பனை (Imagine) Dec 16, 2011 11:11 PM (in response to John Hawkinson)is it possible to assaign a KBSC for our Created Menus?
10. Re: [JS] Menu Added via Scripting Moves
John Hawkinson Dec 16, 2011 11:12 PM (in response to கற்பனை (Imagine))Well, for menu items, yes. They appear in the Scripts area.
11. Re: [JS] Menu Added via Scripting Moves
கற்பனை (Imagine) Dec 16, 2011 11:22 PM (in response to John Hawkinson)Hey Dan it has few side effect with my code, try John suggested. Thanks John.
12. Re: [JS] Menu Added via Scripting Moves
Harbs. Dec 17, 2011 12:50 PM (in response to John Hawkinson)[I removed my nonsensical post. See my response below...]
Harbs
13. Re: [JS] Menu Added via Scripting Moves
Marc Autret Dec 17, 2011 10:11 AM (in response to Dan Rodney)Hi Dan,
There would be much to say about your code (variable scope, etc.) but the two most important, I think, are:
— Custom menus and submenus are application-persistent while script menu actions are (usually) session-persistent
— In the specific case where an action directly relies on a script file, you don't need to deal w/ session-persistence and you can directly address the script file (no need of app.doScript() stuff and so on).
Here is a possible approach (provided that the featured script files are located in the parent folder of the Startup scripts folder):
#targetengine "DanRodneyMenu" // ===================================== // This script is a 'startup script', it runs each time ID starts // and shouldn't be rerun during the session. We don't really need // it to be session-persistent. However we use a #targetengine to // save a 'done' flag which prevents the script from being rerun. // ===================================== (function(/*obj|undefined*/HOST) // ------------------------------------- // Install and/or update the menu/submenu // and connect the menu actions { // --- // HOST can be your framework container, if needed (default: $.global) // --- HOST || (HOST=$.global); // --- // Prevent the current (startup) script from being uselessly rerun // --- if( HOST[$.engineName] ) { alert( "This script is automatically executed at startup. You shouldn't run it manually." ); return; } // --- HOST[$.engineName] = true; // --- // Settings and constants // --- var MENU_NAME = "My Test Menu", FEATURES = [ { caption: "My Menu Item 1", fileName: 'File-One.jsx', subName: "" }, { caption: "My Menu Item 2", fileName: 'File-Two.jsx', subName: "My Sub Menu" } ], LO_END = LocationOptions.atEnd, INDESIGN_ROOT_MENU = app.menus.item( '$ID/Main' ), FEATURE_LOCATION_PATH = (function() { var f; try{ f=app.activeScript; } catch(_){ f=File(_.fileName); } return f.parent.parent + '/'; })(); // --- // (Re)set the actions // Note: checks also whether script files are available // --- var t, f, i = FEATURES.length; while( i-- ) { t = FEATURES[i]; if( (f=File(FEATURE_LOCATION_PATH + t.fileName)).exists ) { // The script file exists => create the corresponding action // and directly attach the event listener to the file // (no need to use app.doScript(...) here) // --- (t.action = app.scriptMenuActions.add( t.caption )). addEventListener('onInvoke', f); } else { // The script file does not exist => remove that feature // --- FEATURES.splice(i,1); } } // --- // Create/reset the custom menu container *if necessary* // Note: menus/submenus are application-persistent // --- var mnu = INDESIGN_ROOT_MENU.submenus.itemByName( MENU_NAME ); if( !mnu.isValid ) { // Our custom menu hasn't been created yet // --- if( !FEATURES.length ) return; mnu = INDESIGN_ROOT_MENU.submenus.add( MENU_NAME, LocationOptions.after, INDESIGN_ROOT_MENU.submenus.item( '$ID/&Window' ) ); } else { // Our custom menu already exists, but we must clear // any sub element in order to rebuild a fresh structure // --- mnu.menuElements.everyItem().remove(); // If FEATURES is empty, remove the menu itself // --- if( !FEATURES.length ){ mnu.remove(); return; } } // --- // Now, let's fill mnu with respect to FEATURES' order // (Possible submenus are specified in .subName and created on the fly) // --- var s, n = FEATURES.length, subs = {}, sub = null; for( i=0 ; i < n ; ++i ) { t = FEATURES[i]; // Target the desired submenu // --- sub = (s=t.subName) ? ( subs[s] || (subs[s]=mnu.submenus.add( s, LO_END )) ) : mnu; // Connect the related action // --- sub.menuItems.add( t.action ); } })();
Marc
14. Re: [JS] Menu Added via Scripting Moves
Harbs. Dec 17, 2011 12:47 PM (in response to Harbs.)1 person found this helpfulNote to self: Don't respond to the forum before your brain is engaged...
Ignore what I wrote above. It made no sense on a lot of levels...
The issue at hand is caused by the following:
Submenus do not go away until you remove them. When restart InDesign, the submenu still exists, so you are creating the meni tems below it.
You need to create the submneu first and specify LocationOptions. Something like this:
function menuInstaller() { var menuItem1T = "My Menu Item 1", menuItem2T = "My Menu Item 2", menuT = "MyTestMenu", subT = "Sub Menu", subs = app.menus.item("$ID/Main").submenus, sma, mnu; var refItem = app.menus.item("$ID/Main").submenus.item("$ID/&Layout"); subMenu1 = app.scriptMenuActions.item(menuItem1T); if( subMenu1 == null ) { subMenu1 = app.scriptMenuActions.add(menuItem1T); } subMenu1.eventListeners.add("onInvoke", menuItem1Handler); subMenu2 = app.scriptMenuActions.item(menuItem2T); if( subMenu2 == null ) { subMenu2 = app.scriptMenuActions.add(menuItem2T); } subMenu2.eventListeners.add("onInvoke", menuItem2Handler); mnu = subs.item(menuT); if( mnu == null ) { mnu = subs.add(menuT, LocationOptions.after, refItem); } subsSubs = app.menus.item( '$ID/Main' ).submenus.item( menuT ).submenus; mnuSubMenu = subsSubs.item( subT ); if( mnuSubMenu == null ) { mnuSubMenu = subsSubs.add( subT); } mnu.menuItems.add(subMenu1,LocationOptions.BEFORE,mnuSubMenu); mnu.menuSeparators.add(LocationOptions.BEFORE,mnuSubMenu); mnu.menuItems.add(subMenu2,LocationOptions.AFTER,mnuSubMenu); };
Harbs
15. Re: [JS] Menu Added via Scripting Moves
Dan Rodney Dec 17, 2011 9:45 PM (in response to Harbs.)1 person found this helpfulThank you all so much for your replies, and thank you Harbs for making it finally work!
Just to make sure this can serve as a resource for others in the future, below is a final (working) menu based on Harb's code. I also added 2 submenu items just to be complete.
Thanks again everyone. I'm so glad you could help get this working!
Dan
#targetengine "HarbsTestMenu" menuInstaller(); function menuInstaller() { // SET THE FILES THAT ARE TRIGGERED BY MENU ITEMS menuItem1Handler = function( /*onInvoke*/ ){ app.doScript( File(myFolder + 'File-One.jsx') ); }; menuItem2Handler = function( /*onInvoke*/ ){ app.doScript( File(myFolder + 'File-Two.jsx') ); }; subMenuItem1Handler = function( /*onInvoke*/ ){ app.doScript( File(myFolder + 'File-Three.jsx') ); }; subMenuItem2Handler = function( /*onInvoke*/ ){ app.doScript( File(myFolder + 'File-Four.jsx') ); }; // SET GENERAL VARIABLES try { myFolder = app.activeScript; } catch(e) { myFolder = File(e.fileName); // we are running from the ESTK } myFolder = myFolder.parent.parent + '/' ; //this file is in the "startup scripts" subfolder var menuItem1T = "My Menu Item 1", menuItem2T = "My Menu Item 2", subMenuItem1T = "My SubMenu Item 1", subMenuItem2T = "My SubMenu Item 2", menuT = "HarbsTestMenu", subT = "Sub Menu", subs = app.menus.item("$ID/Main").submenus, mnu; var refItem = app.menus.item("$ID/Main").submenus.item("$ID/&Layout"); // CREATE MENU ITEMS subMenu1 = app.scriptMenuActions.item(menuItem1T); if( subMenu1 == null ) { subMenu1 = app.scriptMenuActions.add(menuItem1T); } subMenu1.eventListeners.add("onInvoke", menuItem1Handler); subMenu2 = app.scriptMenuActions.item(menuItem2T); if( subMenu2 == null ) { subMenu2 = app.scriptMenuActions.add(menuItem2T); } subMenu2.eventListeners.add("onInvoke", menuItem2Handler); subSubMenu1 = app.scriptMenuActions.item(subMenuItem1T); if( subSubMenu1 == null ) { subSubMenu1 = app.scriptMenuActions.add(subMenuItem1T); } subSubMenu1.eventListeners.add("onInvoke", subMenuItem1Handler); subSubMenu2 = app.scriptMenuActions.item(subMenuItem2T); if( subSubMenu2 == null ) { subSubMenu2 = app.scriptMenuActions.add(subMenuItem2T); } subSubMenu2.eventListeners.add("onInvoke", subMenuItem2Handler); mnu = subs.item(menuT); if( mnu == null ) { mnu = subs.add(menuT, LocationOptions.after, refItem); } subsSubs = app.menus.item( '$ID/Main' ).submenus.item( menuT ).submenus; mnuSubMenu = subsSubs.item( subT ); if( mnuSubMenu == null ) { mnuSubMenu = subsSubs.add( subT); } mnu.menuItems.add(subMenu1,LocationOptions.BEFORE,mnuSubMenu); mnu.menuSeparators.add(LocationOptions.BEFORE,mnuSubMenu); mnu.menuItems.add(subMenu2,LocationOptions.AFTER,mnuSubMenu); mnuSubMenu.menuItems.add(subSubMenu1,LocationOptions.AFTER,mnuSubMenu); mnuSubMenu.menuItems.add(subSubMenu2,LocationOptions.AFTER,mnuSubMenu); };
16. Re: [JS] Menu Added via Scripting Moves
Marc Autret Dec 18, 2011 6:10 AM (in response to Dan Rodney)Great.
I infer that my code did not work for you (although I don't know why).
OK, considering the final "Correct Answer," I just would like to point out that your event handlers (
menuItem1Handler,
menuItem2Handler...)
are all unnecessary. You can directly supply a script File as second argument in the eventListeners.add() method. In addition, your code does not check whether the corresponding files actually exist, so it does not accordingly update the menu items if some feature is missing.@+
Marc -
17. Re: [JS] Menu Added via Scripting Moves
Harbs. Dec 18, 2011 6:35 AM (in response to Marc Autret)Hi Marc,
I wouldn't infer any such thing. Looking at your code, it probably works fine.
Chances are, my code was probably easier to read...
18. Re: [JS] Menu Added via Scripting Moves
Marc Autret Dec 18, 2011 7:13 AM (in response to Harbs.)1 person found this helpfulHarbs. wrote:
Well, in this area, I think "all is relative" but I'm not going to argue this specific point.
Now, let's suppose that someone wants to use your menu loader in another project having a different number of menu items and submenus. Say he wants to obtain the following hierarchy:
MyMenu
MyFeature1
MyFeature2MySubmenuA
MyFeatureA1
MyFeatureA2
MyFeatureA3
MySubmenuB
MyFeatureB1
MyFeatureB2
etc.
Do you see how many changes he needs to do in your code?
In the solution I suggest, he only has to update the FEATURES array this way:
FEATURES = [
{ caption: "MyFeature1", fileName: "File-One.jsx", subName: "" },{ caption: "MyFeature2", fileName: "File-Two.jsx", subName: "" },
{ caption: "MyFeatureA1", fileName: "File-A-One.jsx", subName: "MySubmenuA" },
{ caption: "MyFeatureA2", fileName: "File-A-Two.jsx", subName: "MySubmenuA" },
{ caption: "MyFeatureA3", fileName: "File-A-Three.jsx", subName: "MySubmenuA" },
{ caption: "MyFeatureB1", fileName: "File-B-One.jsx", subName: "MySubmenuB" },
{ caption: "MyFeatureB2", fileName: "File-B-Two.jsx", subName: "MySubmenuB" }
Is this less readable?
Marc
19. Re: [JS] Menu Added via Scripting Moves
Dan Rodney Dec 18, 2011 7:35 AM (in response to Marc Autret)Marc, I did try your code. It worked at first, but once I edited it, the menu disappeared. I likely made a mistake which caused that. Now that you've explained a bit more of how to create a menu hierarchy with it, I'll try it again. It does sound like the best solution!
I wish I could mark two answers as correct, because I think both are valid answers. It was hard for me to decide which to say is "correct" and I hope I didn't offend you Marc. I only went with Harbs because it it's easier to read and understand the entire code (although, as you say, updating the main part of yours is easier to read and edit).
20. Re: [JS] Menu Added via Scripting Moves
Harbs. Dec 18, 2011 7:37 AM (in response to Marc Autret)Like you said, it's relative. I personally find your code a pleasure to read, but my natural style is a bit different.
It really depends on your background.
If you have a strong OOP background, your code is pure poetry!
If you don't have an OOP background, it takes a lot of mental overhead to follow how the code is supposed to work.
Harbs
21. Re: [JS] Menu Added via Scripting Moves
Dan Rodney Dec 18, 2011 7:40 AM (in response to Dan Rodney)Marc. Is it possible to insert menu dividers in your example? And if so, how?
22. Re: [JS] Menu Added via Scripting Moves
Harbs. Dec 18, 2011 7:41 AM (in response to Marc Autret)When I answer questions, I try to stick as closely to the coding style of the OP as I can, to help answer the question at hand. (It helps clarify the answer in few words -- and I don't enjoy excessive writing...)
Chances are I'm not going to change anyone's coding style in a single forum post...
23. Re: [JS] Menu Added via Scripting Moves
John Hawkinson Dec 18, 2011 7:41 AM (in response to Marc Autret)Hey, Marc: I'm going to be sort of blunt. Your code is hard for most people to read because it uses Javascript idioms they are entirely unfamiliar with, which don't make a lot of sense to people not really familiar with the language. And that's what most people here are. Let's take a walk through it:
The comment itself is confusing. Actually, it's even confusing to me.
Tbe || idiom is confusing. Most people don't know what it means offhand.
alert( "This script is automatically executed at startup. You shouldn't run it manually." );Well, this isn't confusing, but I think it's bad. One of the important things to do is to test what happens when the menus already exist, and that's easiest to do by rerunning the script.
All caps for a function-local variable? Even using all caps for a globally scoped variable (Crockford) is confusing, but for a function-scope variable? That confuses me!
FEATURES = [
{ caption: "My Menu Item 1", fileName: 'File-One.jsx', subName: "" },Use of Objects is justified here, but they are probably confusing.
Anonymous functions...definitely confusing! I'm also not sure what the point of this function heere is. Why not execute the code directly
on the next line?
catch(_){ f=File(_.fileName); }Variables named "_"? Confusing!
And this is why anonymous functions are confusing! Not much to be done about it, but why use one where you don't need to. It's not like we're polluting the global namespace here.
while( i-- )
Use of a while loop is a totally legitimate style choice, but I think it's typically less readable than a for loop. YMMV, of course!
t = FEATURES[i];
I'm horribly guilty of this, but single-letter variable names are not the most readable.
addEventListener('onInvoke', f);More parentheses imply more mental gymnastics to understand. Breaking this into two lines,
with t.action=addEventListener... would help readability.
var s,
subs = {},
sub = null;Wait, a mid-function var block? Gasp! What's up with that? Crockford's right on this. One var statement and all at the top.
I am not sure why we're initializing sub to null -- what's wrong with the good old undefined? This probably doesn't qualify as confusing.
Caching FEATURES.length in n is good for performance, but it probably doesn't matter here, and makes it more confusing to read. Not by much, but let's say half a confusion point. I would also say that "++i" is harder to read than "i++", maybe to the tune of 0.1 confusion-points, but maybe that's just me. YMMV Extremely.
mnu;The ternary conditional operator, ?:, is pretty much always hard to read. And it's worse with short-circuit or-ing, ||, or three close-parens in rapid succession. Of course ?: tends to promote extra () as it almost always becomes ()?(): so...
})();And then it's worth re-emphasizing, basically nobody understands the anonymous function paradigm .
So there we have it, that's why I think your code is confusing to most readers.
(On the other hand Dan's final code ignores my recommendation and still has those abysmal ==null tests in there. What's up with that? )
24. Re: [JS] Menu Added via Scripting Moves
Harbs. Dec 18, 2011 7:50 AM (in response to Dan Rodney)That's odd. John's post seems to exist, but doesn't show up...
25. Re: [JS] Menu Added via Scripting Moves
Harbs. Dec 18, 2011 7:51 AM (in response to Harbs.)That seemed to do it... Weird...
26. Re: [JS] Menu Added via Scripting Moves
John Hawkinson Dec 18, 2011 8:11 AM (in response to Harbs.)That's odd. John's post seems to exist, but doesn't show up...
It's worse than that. Cache corruption.
Viewing from adobe-vm-wa06.sgvm2hosted.jiveland.com
I see my post but not your replies. Dumping cookies and reloading
fixes it, because I get another server.
I'll start a thread in Forum Comments.
27. Re: [JS] Menu Added via Scripting Moves
Marc Autret Dec 18, 2011 8:17 AM (in response to John Hawkinson)OK guys. Once again I admit my coding style has many faults and I really do not claim it is better than any other. It's just my way. I use it because I understand it better, I make it more easily evolve and I identify more easily the internal logic. But it's only because I used to do like that, and what is right for someone may definitely be wrong for someone else.
Anyway, my point is not about style. I'm just talking about factorization and reusability. Let down my code in itself, just consider the approach I suggest. What I mean is that the response considered correct has some issues and can be improved clearing useless event handlers, adding file checking, removing global vars and, why not, supporting reusability.
Marc
28. Re: [JS] Menu Added via Scripting Moves
Marc Autret Dec 18, 2011 8:58 AM (in response to Dan Rodney)Dan Rodney wrote:
You mean menuSeparators, right?
I slightly expanded the code to support the following syntax:
FEATURES = [ { caption: "My Menu Item 1", fileName: 'File-One.jsx', subName: "" }, { separator: true, subName: "" }, { caption: "My Menu Item 2", fileName: 'File-Two.jsx', subName: "My Sub Menu" }, { separator: true, subName: "My Sub Menu" }, { caption: "My Menu Item 3", fileName: 'File-Three.jsx', subName: "My Sub Menu" } ]
Also, I removed the #targetengine stuf and the HOST argument. As John said, this is uselessly complicated for such a project. Note that this startup script does not need to run in a persistent engine.
Here is a possible implementation:
// MenuLoader // (#targetengine is not required) (function() // ------------------------------------- // Install and/or update the menu/submenu and connect // the corresponding menu actions if script files are available { // Settings and constants // --- var MENU_NAME = "My Test Menu", FEATURES = [ { caption: "My Menu Item 1", fileName: "File-One.jsx", subName: "" }, { separator: true, subName: "" }, { caption: "My Menu Item 2", fileName: "File-Two.jsx", subName: "My Sub Menu" }, { separator: true, subName: "My Sub Menu" }, { caption: "My Menu Item 3", fileName: "File-Three.jsx", subName: "My Sub Menu" } ], LO_END = LocationOptions.atEnd, INDESIGN_ROOT_MENU = app.menus.item( '$ID/Main' ), FEATURE_LOCATION_PATH = (function() { var f; try{ f=app.activeScript; } catch(_){ f=File(_.fileName); } return f.parent.parent + '/'; })(); // (Re)set the actions // Note: checks also whether script files are available // --- var t, f, i = FEATURES.length; while( i-- ) { t = FEATURES[i]; if( t.separator ) continue; if( (f=File(FEATURE_LOCATION_PATH + t.fileName)).exists ) { // The script file exists => create the corresponding action // and directly attach the event listener to the file // (no need to use app.doScript(...) here) // --- (t.action = app.scriptMenuActions.add( t.caption )). addEventListener('onInvoke', f); } else { // The script file does not exist => remove that feature // --- FEATURES.splice(i,1); } } // --- // Create/reset the custom menu container *if necessary* // Note: menus/submenus are application-persistent // --- var mnu = INDESIGN_ROOT_MENU.submenus.itemByName( MENU_NAME ); if( !mnu.isValid ) { // Our custom menu hasn't been created yet // --- if( !FEATURES.length ) return; mnu = INDESIGN_ROOT_MENU.submenus.add( MENU_NAME, LocationOptions.after, INDESIGN_ROOT_MENU.submenus.item( '$ID/&Window' ) ); } else { // Our custom menu already exists, but we must clear // any sub element in order to rebuild a fresh structure // --- mnu.menuElements.everyItem().remove(); // If FEATURES is empty, remove the menu itself // --- if( !FEATURES.length ){ mnu.remove(); return; } } // --- // Now, let's fill mnu with respect to FEATURES' order // (Possible submenus are specified in .subName and created on the fly) // --- var s, n = FEATURES.length, subs = {}, sub = null; for( i=0 ; i < n ; ++i ) { t = FEATURES[i]; // Target the desired submenu // --- sub = (s=t.subName) ? ( subs[s] || (subs[s]=mnu.submenus.add( s, LO_END )) ) : mnu; // Connect the related action OR create a separator // --- if( t.separator ) sub.menuSeparators.add( LO_END); else sub.menuItems.add( t.action, LO_END ); } })();
Marc
29. Re: [JS] Menu Added via Scripting Moves
Dan Rodney Dec 18, 2011 10:09 AM (in response to Marc Autret)Wow, this has been quite a discussion! First let me thank everyone. This has all helped tremendously. We now have two ways to make working menus. I don't think I've every such a complete roundup of menu creation code anywhere else on the web. This is such a cool ability and so little is said about it. I must say that the scripting documenation often doesn't help "me" to be able to program new features from scratch. There can be little syntax issues or things that need to be done that the documentation doesn't convey to me, and this forum is so important because there are so few InDesign scriptors out there.
Thanks Marc for posting your finished example with menuSeparators. It's certainly easy to edit the parts of the menu in your script.
Please keep in mind that the original code was not even my style of writing. It was based on the blog post of Marijan Tompa (tomaxxi). I had to start with that to learn menu creation because it was the most complete menu setup code I could find, and reading the documentation wasn't helping me with submenus.
John, as for the ==null tests, they work in CS3 and later. If I switch to isValid that only works in CS5 (from what I understand). What cross-version compatible code do you think is better?
30. Re: [JS] Menu Added via Scripting Moves
Marc Autret Dec 18, 2011 10:50 AM (in response to Dan Rodney)About isValid missing in CS3, you could try sth like this:
// Declare isValid() at the beginning of the current scope/script // --- var isValid = ( parseFloat(app.version) >= 6 ) ? function(o) { return o.isValid; } : function(o) { var r = false; try { ('id' in o && o.id) || ('index' in o && o.index); r = true; } catch(_){} return r; };
Then replace myObj.isValid by isValid(myObj) in the entire code.
Marc
31. Re: [JS] Menu Added via Scripting Moves
Harbs. Dec 18, 2011 11:13 AM (in response to Marc Autret)null works perfectly well for menu actions. I'm not sure why we're making a deal of this...
FWIW, here's the IsValid function that I use:
IsValid = function (obj){ try{ if(!obj){return false} if(kAppVersion>=6){ return obj.isValid; } var test = obj.parent; return true; } catch(err){return false;} }
kAppVersion is a constant I have defined like so:
kAppVersion = parseFloat(app.version);
(Every valid object in InDesign has a parent.)
Harbs
( P.S. The test variable name is extraneous, but it makes it obvious what it's doing...) -
32. Re: [JS] Menu Added via Scripting Moves
John Hawkinson Dec 18, 2011 11:20 AM (in response to Dan Rodney)John, as for the ==null tests, they work in CS3 and later. If I switch to isValid that only works in CS5 (from what I understand). What cross-version compatible code do you think is better?
Oh, I wasn't referring to .isValid! I didn't mean that at all. I meant what I said in post #1, after I mentioned it. Replace if (var==null) with if (!var). === is almost always better than ==, because truthiness of == causes confusion and problems. But in ifs, you might as well use the implicit truthiness and not test explicitly, and write for clarity. (Someone is going to say this argument is defective ).
By the way, there's some sample Adobe script that creates menus. Maybe it's hidden in the Bridge SDK or something. I can't remember, something to do with some font. I haven't looked at the code though, so who knows. I suspect it is rather different than any of the examples so far...
Marc's absolutely right, your code should not be using global variables! What a nightmare those are. Remember anything in a function without an explicit 'var' on it somewhere is global. "Oops." That's what happens when you design a language in 10 days (Javascript).
33. Re: [JS] Menu Added via Scripting Moves
Harbs. Dec 18, 2011 11:38 AM (in response to John Hawkinson)John Hawkinson wrote:
Is this what you're talking about? It's distributed in the InDesign SDK...
XHTMLExportMenuItem.install = function() { if(app.name == "Adobe InDesign") { // set up our script preferences var currDOMVersion = app.scriptPreferences.version; if (currDOMVersion != XHTMLExportMenuItem.requiredDOMVersion) app.scriptPreferences.version = XHTMLExportMenuItem.requiredDOMVersion; // determine and store the path from were we load our scripts from XHTMLExportMenuItem.storeScriptsFolderPath(); // load XHTMLExporter for the strings var xhtmlExporterScript = XHTMLExportMenuItem.loadScript('XHTMLExport.jsxbin'); if ( !xhtmlExporterScript.exists ) { xhtmlExporterScript = XHTMLExportMenuItem.loadScript('XHTMLExport.jsx'); } assert( xhtmlExporterScript.exists, "XHTMLExport.jsx* missing; load failed" ) ; if ( xhtmlExporterScript.exists ) { var cacheCurrent = Folder.current ; try { Folder.current = XHTMLExportMenuItem.scriptsFolder ; app.doScript( xhtmlExporterScript ) ; } finally { Folder.current = cacheCurrent ; } if ($.locale != 'en_US') { // try to load localized strings var localizationScript = XHTMLExportMenuItem.loadScript('Resources/XHTMLStrings-' + $.locale + '.jsxbin'); if ( !localizationScript.exists ) { localizationScript = XHTMLExportMenuItem.loadScript('Resources/XHTMLStrings-' + $.locale + '.jsx'); } assert( localizationScript.exists, 'Resources/XHTMLStrings-' + $.locale + '.jsx* missing; load failed' ) ; if ( localizationScript.exists ) { var cacheCurrent = Folder.current ; try { Folder.current = Folder( XHTMLExportMenuItem.scriptsFolder + '/Resources' ) ; app.doScript( localizationScript ) ; } finally { Folder.current = cacheCurrent ; } } } // menu action for the File:Export for menu var actionname = localize(xhtmlExportStrings.FORDREAMWEAVERACTIONNAME); var action = app.scriptMenuActions.item(actionname); if(action == null) { // first launch: // we need to create the menu action var action = app.scriptMenuActions.add(actionname); action.area = app.translateKeyString('$ID/KBSCE File menu: ExportForSubMenu'); action.checked = false; action.enabled = true; } // install event listeners for our action action.addEventListener("onInvoke", XHTMLExportMenuItem.exportSelectedItems); action.addEventListener("beforeDisplay", XHTMLExportMenuItem.enableDisable); action.addEventListener("afterInvoke", XHTMLExportMenuItem.cleanup); // install the menu item var exportForMenu = app.menus.item(app.translateKeyString('$ID/Main')).submenus.item(app.translateKeyString('$ID/&File')).submenus.item(app.translateKeyString('$ID/ExportForSubMenu')) ; exportForMenu.menuItems.add(action); // store the action in a class variable XHTMLExportMenuItem.action = action; } if(currDOMVersion != XHTMLExportMenuItem.requiredDOMVersion) app.scriptPreferences.version = currDOMVersion; } }
Harbs
34. Re: [JS] Menu Added via Scripting Moves
Because—I totally agree with John— using ==null is both a bad practice and semantically irrelevant.
Marc
35. Re: [JS] Menu Added via Scripting Moves
Harbs. Dec 18, 2011 11:48 AM (in response to John Hawkinson)John Hawkinson wrote:
In my opinion, discussions about == vs. === vs implicit resolutions is kind of silly. I have no issue using ==. Just make sure you understand what it means.
Personally, I only use === when I really need it. That way it's clear what I'm testing for... When I'm testing for bull or boolean values, I usually skip the "==" altogether.
I don't take everything Crawford says as if it's the bible. They're only his opinions after all...
Harbs
36. Re: [JS] Menu Added via Scripting Moves
John Hawkinson Dec 18, 2011 11:49 AM (in response to Harbs.)Is this what you're talking about? It's distributed in the InDesign SDK...
*cry*
No. Normally I'd say you should include the filename when you make such references, but in this case... please don't.
There's some script that adds a toplevel menu for a Font. I guess I am just not excited enough (afraid?) to go looking for it. Especially after that snippet you posted. -
37. Re: [JS] Menu Added via Scripting Moves
Tell that to Jonathan Brown who designed it in the first place!
(See the code I pasted above.)
38. Re: [JS] Menu Added via Scripting Moves
John Hawkinson Dec 18, 2011 11:52 AM (in response to Harbs.)In my opinion, discussions about == vs. === vs implicit resolutions is kind of silly. I have no issue using ==. Just make sure you understand what it means.
The problem is that it is often fairly subtle "when you really need it," and you don't notice until you've been bitten by it.
Everyone is pretty much always better off with ===.
Crockford.
And yes, his opinions are actually increasingly problematic. I can't even use JSLint anymore, he's added so many inappropriate checks that really boil down to style. The jslint_com yahoo group is kind of unpleasant. Oh well.
39. Re: [JS] Menu Added via Scripting Moves
Harbs. Dec 18, 2011 11:53 AM (in response to John Hawkinson)(I love making grown men cry...)
The snippet I posted above was written by Jonathan Brown. It's pretty obvious where it came from (HTML export).
The font snippet is in the InDesign Scripting Guide pdf.
