7 Replies Latest reply: Dec 25, 2011 2:46 AM by ryan_khoo RSS
    How come AE cannot interpret Alpha Channel from ProRes4444 ?
    ryan_khoo Community Member
      Hi there,
      I exported a video clip using Final Cut Pro X with alpha channel using the ProRes4444 codec.
      I have tested his alpha channel works & it works in FInal Cut Pro X when I import it back to Final Cut Pro X to test it.
      However, when I bring this file to After Effects CS5, it cannot recognize the alpha channel because the transparent part are all in solid black.
      How do I make AE interpret the ProRes4444 file as transparent with alpha channel ?
        • 1. Re: How come AE cannot interpret Alpha Channel from ProRes4444 ?
          Johnathan A. M. Community Member
          that black part may be the alpha channel, between "active camera" and the preview resolution (full) there is a little checkerboard pattern, click that, and it will show transparancy in the checkerboard, sorry if you've always tried this, but start with the simple solutions first
          • 2. Re: How come AE cannot interpret Alpha Channel from ProRes4444 ?
            Rick Gerard CommunityMVP
            Did you check the file interpretation in After Effects? I've never had a problem with ProRez 4444 files.
            • 3. Re: How come AE cannot interpret Alpha Channel from ProRes4444 ?
              Thanks Rick,
              Q1. But how do I check the file interpretation in AE ?
              Q2. I am using AE CS5. Is it bcos you are using AE CS5.5 that you never have problem with ProRes4444 ?
              • 4. Re: How come AE cannot interpret Alpha Channel from ProRes4444 ?
                Q1. This is part of the basics. Select the file you want to interpret in the Project Panel then either right click or go to the menu File>Interpret Footage>Main or use the keyboard shortcut Alt/Option + Ctrl/Cmnd + G
                Q2. Nope... It's always worked. There were some gamma problems for a while, and a few other bugs here and there with ProRez, but if you're Mac is up to date you should have no problems with the alpha channel.
                • 5. Re: How come AE cannot interpret Alpha Channel from ProRes4444 ?
                  Thanks Rick for your help, I really appreciate it as I am not quite familiar with AE.
                  Q1. I did the steps you taught me & a new screen pop out. But under the "Main Options" tab, the section under Alpha, there are 4 choices (Ignore, Straight-Unmatted, Premutliplied-Matted with color, Invert Alpha). But all these was all greyed out. Any idea why ?
                  Q2. I am using Mac & I just checked my AE CS5 is Version 10.0. I am a student and i bought the Student Edition. Student Edition not allowed to update, right ?
                  • 6. Re: How come AE cannot interpret Alpha Channel from ProRes4444 ?
                    Run the updates. And yes, you can upgrade, update, do anything you want with a student edition.
                    • 7. Re: How come AE cannot interpret Alpha Channel from ProRes4444 ?
                      Yes Rick, the problem solved by updating to Version 10.0.1.
                      I am on Mac. My previous version was ver 10.0.
                      After updating, I re-import the alpha channel files with ProRes4444 & AE can recognize the alpha channel.
                      Thanks again, Rick, you have been great.
                      Merry Xmas to you & everyone here.
                      Cheers
