Locked
Issues with Trial Version 4.6
Dec 20, 2011 Dec 20, 2011
Hi....
When i am using the flash builder 4.6 trial version i am getting the following problem
I am trying to exeicute TourdeFlex example related to SQL Database Usage i am getting this error in Flash Builder .Please help
DescriptionResourcePathLocationType
Unable to locate specified base class 'spark.components.WindowedApplication' for component class 'views.DtabaseExampleHomeView'.DtabaseExampleHomeView.mxml/DtabaseExample/src/viewsUnknownFlex Problem
756
Does the trial version provide full functionality or it only provides limited features?
Contributor ,
Dec 21, 2011 Dec 21, 2011
Trial version is Premium - will revert back to Standard if Standard license is used after Trial is finished.
If that's an actual copy/paste of the error message it looks like the example has a typo.
'views.DtabaseExampleHomeView'. probably shoul dbe 'views.DatabaseExampleHomeView'.
maybe check to see if the src  path /DtabaseExample/src/views exists?
Dec 30, 2011 Dec 30, 2011
1)unable to populate database values at  speak  List in flash Builder4.6  The fallowing code is used
<fx:Script>
  <![CDATA[
   import mx.collections.ArrayCollection;
   private function getIteamCategory():void {
   avar sqlConnection:SQLConnection = new SQLConnection();
  var resultSet:SQLResult = null ;
  var dataList:ArrayCollection = new ArrayCollection();
  sqlConnection.open(File.applicationStorageDirectory.resolvePath("IDatabase.db"));
  var stmt:SQLStatement = new SQLStatement();
  stmt.sqlConnection = sqlConnection;
   stmt.text="SELECT  item_category FROM Menu_Table where item_id  between 1 and 99";
  stmt.execute();
  data_list.dataProvider=new ArrayCollection(stmt.getResult().data);
   sqlConnection.close();
  return dataList;
        protected function datalist _creationCompleteHandler (event:FlexEvent):void  //executed when the List completes loading
            getIteamCategory ();
  <b/fx:Script>
<s:List id="datalist" x="10" y="10" left="0" right="0" top="0" bottom="0" width="1004"
        height="500"
        creationComplete="datalist _creationCompleteHandler(event)" enabled="true">
    <s:itemRenderer>
        <fx:Component>
            <s:MobileItemRenderer label = "{data. item_category }"/>  // The Application is a mobile app
        </fx:Component>
    </s:itemRenderer>
</s:List>
Please suggest, I also included mx.swc file in the build path. Also seeing following several error message, pasting two of them
1120: Access of undefined property ContainerBorderSkin.
1172: Definition mx.skins.spark:ButtonSkin could not be found.          NewIndianCurryHous
Thanks in advance.
