5 Replies Latest reply: Dec 22, 2011 11:38 AM by sakonnetweb RSS
    CFmail errors- how to prevent error message from user?
    sakonnetweb Community Member
      Greetings
      I have an app in which the admin user sends notices to Vendors who have signed up to recieve emails when a new bid is posted.
      Even though I have "required="yes" validate="email"" at intial Vendor sign up (I think email validation is better served using Javascript, I've heard anyway) inevitably, contact emails go bad- and there are about 5000 vendors in the system.
      When a user (admin) sends the notices, if there is a mal-formed or dead email address in the DB, it dislays my default error screen even though the send transaction was successful.
      Any advice on how to prevent this?
      Thanks in advance for your help
      sakonnetweb
        • 1. Re: CFmail errors- how to prevent error message from user?
          Dan Bracuk Community Member
          In your cfmail tag, put a special email address in the FailTo attribute.  Then see what mail that address gets after each mailing and update your db accordingly.
          • 2. Re: CFmail errors- how to prevent error message from user?
            ilssac Community Member
            As well as Dan's suggestion.
            You can use the <cftry><cfctach> syntax to provide specific error handling to specific exceptions generated by specifc code.
            I.E. you could wrap the <cfmail...> tag with a <cftry>...</cftry> block and then create a specific <cfcatch...> block that handles the bad email address exception any way you desire.  As Dan sugested I would sugest somehow collecting the bad email address and providing them to somebody that can clean them from the data.
            You could than also have a defalult <cfcatch...> block that would handle any other type of exception and|or rethrow the exception out to your current exception handler.
            Some people don't like the concept of try|catch syntax, but I like it and feel it is a pretty elegant solution for this type of thing.
            • 3. Re: CFmail errors- how to prevent error message from user?
              OK thanks for all the help.
              I think I left out a part. The user can't get into the system to delete- that needs to be done at my level.
              When there's an addendum to send, the user sends out the attached file to all who have viewed the original Bid package. They would like to print the resulting page which shows the list of who the recepients were. When the error page comes up instead, they obviously can't print the list.
              If the only way I can test for bad mail is to use FailTo, that test message would go out to 5000 vendor contacts- is there a way to show the resulting list even though some of the emails were bad?
              IOW can code be used to ignore bad addresses and continue processing the rest?
              Thanks again....
              sakonnetweb
              • 4. Re: CFmail errors- how to prevent error message from user?
                I'm missing something here.  If you have an email address in the correct format, you don't know if it's valid or not until you send mail to it.  If it's valid, nothing happens.  Otherwise, there is an Undeliverable mail reply.
                On the ColdFusion side, all the cfmail tag does it generate a file and put it in the Spool folder.
                So my question is, what is causing your error page to run?
                • 5. Re: CFmail errors- how to prevent error message from user?
                  <cfset thisBidID = session.bid_ID>
                  <cfquery name="list_sendto" datasource="#Request.BaseDSN#">
                  SELECT lc.contact_fname, lc.contact_lname, lc.contact_email,
                  b.ReferenceNumber, b.Title, b.Description,
                  jb.bid_ID, jv.vendor_ID
                  FROM ((junction_bid_ccc jb
                  LEFT
                  JOINjunction_vendor_ccc jv
                  ONjb.cccode_ID = jv.cccategory_ID)
                  LEFT
                  JOINlookup_contact lc
                  ONlc.vendor_new_ID = jv.vendor_ID)
                  LEFT
                  JOINBid b
                  ONb.new_bid_ID = jb.bid_ID
                  WHERE jb.bid_ID = #thisBidID#
                  ANDlc.contact_email <> ''
                  ANDlc.contact_email IS NOT NULL
                  GROUP
                  BY lc.vendor_new_ID, lc.contact_email, lc.contact_lname,
                  lc.contact_fname, b.new_bid_ID, b.ReferenceNumber,
                  b.Title,
                  b.Description, jb.bid_ID, jv.vendor_ID
                  </cfquery>
                  <cfset thisReferenceNumber = list_sendto.ReferenceNumber>
                  <cfset thisTitle = list_sendto.Title>
                  <cfmail query="list_sendto" to="#contact_email#" from="whatever@whatever.com"
                  subject="Bid Notification" server="emailsrv1.cityofnewport.priv"
                  groupcasesensitive="no">
                  <p>You are receiving this message because .... etc.
