Well, this question has been on for a long time but everyone seems to ignore it, so I'll just give it another shot.
I get this error when trying to copy something.
Most of the time, if i ignore the error I can still find it in the clipboard.
Sometimes I'm lucky and it doesn't happen (using the same document), so this clears that it has no copyright protection.
Yesterday I worked all day on a document with no problems, but today I'm losing a lot of time dealing with the problem and trying to fix it. (hope this clears that I have all software up to date and no plugins missing)
The thing is that I often work on asian character texts and ignoring the error does no good because all I have left in the clipboard is junk data (an example of copied text: ‘¾—zŒõ”“dƒVƒXƒeƒ€‚ÌLCA)
If I try to copy again, sometimes it works (I have to try from 3 up to more than 15 times though), but I will get the error when I try copying the next word.
I really doubt there's an instant solution for this, so all I'm asking is for you to stop ignoring this issue and try to release an update with a fix for this before people start switching to other programs.
Pretty please??
Thank you
P.S.
As you can see, no answer
since 2008
I was having this problem on Acrobat X and I tried everything in this thread and nothing worked and now I finally tried this:
Help Menu -> "Repair Adobe Reader Installation"
And BOOM it's all fixed!!!!! No more stupid copy error!!!!
Ditto - Someone please help
Hej to Your All.
If you have are HP printer, Your problem it were, You shoot only install basic driver's
Same here. Does Adobe even pay attention to these boards? It seems they could at least report that they are investigating
Hello jglamas, smoore0400, and Helgster,
Thank you for your report. Since we haven't been able to reproduce your problem, would you please give us a little more info so that we could narrow down the problem?
1) What's your OS version/language?
2) Is there any language support installed on the OS? (ie. "Install files for East Asian languages", "Install files for complex script and right-to-left languages")
3) What's your Adobe Reader version/language? (Help > About Adobe Reader)
4) Is there any security restriction on the PDF file you are using? (File > Properties > Security)
5) Do you have the fonts used in the PDF file installed on your machine?
6) Does it happen with English text in the same PDF file as well?
7) Is there any other application you have opened during the problem occurs? Please try rebooting your machine, and only launch Adobe Reader/Acrobat to see if the problem persists.
8) Some googling showed me that the similar problem exists with Excel. With that case, Skype add-in in IE and FF was causing the problem. Please see the second post on this link for more detail. Could it be the case for you?
Thank you!
I have this exact problem too. It began after an Adobe Reader X update about a week ago. Disableing the Skype add-in as suggested above fixed the problem.
Well in my case we are runing Adobe 8 ver8.3.1.
On a Citrix box running Windows Server 2003.
I would be more than happy to do a remote session so you can see it yourself.
did someone get respond on that problem?
Our Enterprise Admin guide which helps with Citrix related technology... no longer support Acrobat/Reader 8.
Please give this a try using newer versions. I do know Copy/Paste works as I use it regularily. Though I haven't tried this with Asiant fonts as per original forum post.
David
Hi David,
Out of the thousands of reports you (Adobe) decide to answer you pick this really specific (Citrix) one.
I've been surfing now for hours (again) to resolve this issue and nothings has worked.
Is there a way you can answer the wider range of questions?
The errormessage is "There was an error while copying to the Clipboard. An internal error occurred."
I use Adobe Reader 10.1.7 and Windows 7 (64 bit).
The error-message seems useless as it still copies to the Clipboard.
But getting this message and having to click it away gets really annoying.
I've tried all solutions offered (emptying clipboards in Word & Excel; I have no Skyp-Add-on; etc. etc.) but come up empty as to a permanent solution.
This only started a couple of weeks ago but unfortunately can't tell you when/how exactly.
And it doesn't happen all the time, but very, very often.
I truly hope you can address this issue (for all of us).
Kind regards,
Nanette
Hi NanetteKalisvaart,
I still cannot reproduce this problem on my machine. It would be great if you can answer the following questions (slightly modified from my above post):
Thank you,
Rebecca
Hi Rebecca,
Thanks for trying again.
To try and answer your questions:
1. Windows 7 Dutch
2. 64-bit
3. It happens to files in Dutch and English.
4. I haven't installed any 'strange' language files.
5. Adobe Reader Version 10.1.7
6. No (security restriction).
7. I don't see why not (I didn't install any fonts but it used to work fine like it is now).
8. I don't understand the question. See question 3?
9. As stated the problem is not consistent. The first time around in a document I don't get the message but from the second try on I do.
10. Yes, I have tried uninstall en reinstall. I have not tried the cleaner and will do so tomorrow but don't want to loose all my answers here. (Maybe next time start with this option. 🙂 )
But maybe instead of looking at my particular settings, since it seems to have happend to loads of people, check in the program when this message is displayed. Something is off there. Because although it shows the message, it turns out it is still copied to the Clipboard.
It seems therefore a useless message (as also more people have suggested).
I think you get a clear picture when you read all the messages (also in other threads) about this topic.
Kind regards,
Nanette
Hi Nanette,
Thank you for all the info! Your problem might be slightly different from the original problem jglamas posted, since his copied data are corrupted, whereas you mention your data is just fine.
I'll try to replicate your environment (Windows 7 Dutch 64-bit, Dutch Reader 10.1.7, PDF contains English and Dutch) and try to reproduce the problem. Steps should be:
1. Launch Reader
2. Open a PDF file
3. Highlight some text (how much?)
4. Click Edit > Copy
5. Text is copied onto clipboard
6. Without doing anything in Reader, click Edit > Copy again (for the same text?)
7. Error is thrown
Please let me know if these steps describe what you did exactly.
Also, would you be able to share the PDF file with us, maybe via email?
Thank you,
Rebecca
Hi Rebecca,
I have used the cleaner.
Then I installed Reader again. Only now it's version 11.0.0.
Unfortunately non of these changes (cleaner & newer version) had the desired effect.
I still get the error-message.
As to the steps described above in your reply, now I get the Error-message right away (so no step 6).
Yes, I could share a pdf-file with you, what is the e-mailaddress you wish to have me send it?
FYI, when I look in C:\Users\Nanette\AppData\Local\Adobe is see this
Is there anything in a cache-file maybe that is interfering?
Kind regards,
Nanette
Hi Nanette,
Too bad the cleaner didn't solve the problem
Thank you for sending me the files. I'll try them.
I'm not sure if having old cache files have anything to do with this, but I will try installing Reader 9, and upgrade to 10, then 11. Thank you for the detail!
Rebecca
Hello
I had a chat with Adobe Germany. They told me Adobe Reader doesn't support network installations such as Citrix. http://www.adobe.com/support/programs/customer/gss.html
What does that mean? Adobe doesn't support us because its freeware (or you have a support program/commercial) or because its only made for fat clients (technical)? http://www.adobe.com/products/reader/tech-specs.html
Can a staff member confirm that here? Can't find an exclusion for Citrix.
Did this issue ever get resolved? Anyone has an update on this?
I really wonder how often product teams expect customers will just give up and stop bothering them about problems like this. I appreciate that intermittent problems that are hard to recreate are frustrating for product teams - it's also frustrating for customers who not only have to deal with the issues but are given a laundry list of "solutions". http://www.youtube.com/watch?v=nn2FB1P_Mn8
I too encounter this problem ocassionally. It is very intermittent and very difficult to reproduce at will. Usually, after no more than three or four attempts to copy the exact same text, it works without the nastygram. I don't think I've ever had text that could not be copied if I was not persistent enough.
I am still hoping for a fix to this also. It's very easy for me to reproduce. I just need to hold CTRL and mash C a bunch of times and I will eventually get it within 5 or 10 attempts. There will be stretches where I get it every time.
I find it irritating that Adobe hasn't simply released a patch that suppresses the error message. They don't even need to fix the actual error, because as far as I can tell there is no error... my text is copying and pasting perfectly. I just need to OK this obnoxious dialogue box.
Adobe, just release a simple plugin that kills the dialogue box and you will make 10,000 Acrobat users extremely happy.
Dear Abobe support,
I note that in your replies above you ask for information so you can replicate the problem on your machine (but apparently you can't).
I've been purchasing and using all versions of adobe acrobat since about 2005 I think, and every version of the program has given me the same error, "There was an error while copying to the Clipboard. An internal error occurred.".
If you actually don't know about this problem then that surprises me a little.................
Could you possibly just fix it please?
There is a fix to the copy and paste pdf issue. It occurs because Adobe does hard returns at the end of a line instead of word wraps.
I found the site below that has an elegantly simple fix that I installed and I no longer have the problem. Hopefully Adobe will inocorporate that into their program.
Best to you,
starnet7
This is definitely an Adobe problem. Disabling Skype add-in to IE helps some (when copy is within same line) but copy across line break still produces same message. Copying across hard returns in other programs (e.g., MS Word) does not cause same problem.
..... OK. After restart, this problem does not re-occur, at least on my POS Windows Vista box. Maybe the Skype disable to IE was the cure (even though neither of them were running when error message occurred). So, thanks, I guess.
Message was edited by: paulroyster
This worked for me, and i was having the problem outside the browser.
in windows 7
start-control panel-uninstall programs
uninstall the "Skype Click to Call", this will uninstall addins from ie, firefox, you dont have to uninstall skype.
in ie and firefox you can disable addons but can not uninstall them using ie or firefox interface, when you uninstall Skype Click to Call, it will remove it from all added browsers.
This works me now.
Edit 1:
Unfortunately skype trick does not work.
I recently switched to windows 8 and reliazed that there is no copy error any more.
Edit2:
This error maybe caused by Babylon dictionary which has an Adobe Acrobat or Reader addon which captures the text from pdf documnet when ctrl+right mouse click. This feature is enabled when it is copied to" C:\Program Files (x86)\Adobe\Acrobat 10.0\Acrobat\plug_ins " or "C:\Program Files (x86)\Adobe\Reader 9.0\Reader\plug_ins " directory, so if it is copied such copying error appeared, if not copied it does not appear. Baylon dictionary addin is installed when you install babylon dictionary software, and it is here " C:\Program Files (x86)\Babylon\Babylon-Pro\Utils ", its name is " BabylonRPI.api "
Edit3:06-April-2013
My experience is that Babylon Dictionary was causing this error. With babylon version 10 acrobat does not give that kind of error anymore, on windows 7 x64, but previous version leftover files may cause this error again even if you remove previous versions and install version 10. With a clean install of windows 7 x64 with babylon dictionary version 10 there is no error anymore.
