Is it possible to get SEARCH results in a similar way as how the google search produce from my help file using robohelp 9?
Not using the built in search. You can use a third party tool ZoomSearch. See my site for information.
But in Robohelp Help file it searches same as it does in google search. Is that also implemented using the third party tool ZoomSearch?
Sorry but I don't understand what you are asking. You are saying RoboHelp searches the same as Google but the whole point of the question was that the search is different. I am assuming you want the results to look something like the search on my site and appear in the topic pane.
Sorry for being unclear, I want a search similar to that which appears on Adobe Community Help Window. Is it possible to get it through RoboHelp 9. If Yes how? If not what should i do to get in similar way?
Yes! I want it in similar way as it is in your site http://www.grainge.org. What should i do for it?
Use ZoomSearch. The article on my site explains how to integrate it with RoboHelp.
Can i know difference between a single project with a single search and a single project with search options?
A single search means the user can search say the whole help only.
Search options means you have set up a number of searches so that they can search the whole help OR a limited area. You could set up any number of different areas.
Where should i store the downloaded Zoomsearch tool?
It is a program that you install.
I have downloaded working set up (1.3mb) for a single project with a single search.and stored in C:\. What should I do next?
I think you need to talk to one of your developers or IT to get some assistance. The instructions for making ZoomSearch work with RoboHelp are on my site but the level of questions you are asking suggests you need some local support.
Please do not start a new thread when it is related to this thread.
Rushinissa posted
I have a doubt in Step 3 Setting Up Zoom search.
To perform this step should I need to download Zoom search from www.wrensoft.com? Please help as I need to create my project and give demo tomorrow..Please
Of course you must download and install ZoomSearch from www.wrensoft.com.
Thanks!!!
When I am performing "Start Indexing now" I am getting "Template file has different Charset error".
I got it
I am really sorry I think I am annoying you a lot. I have a question how to integrate zoom search in PDF?
You don't have to ask if you can ask a question. I was just rather surprised that anyone would ask if they had to download an application to be able to use it.
Go ahead but please do check the article on my site first.
Thanks!! I have checked the article in your website. It says plugins are available to also search PDF and DOC files. They are easy to set up and work well. I use them on a company intranet and they work very well but they are outside the scope of this topic.
You have to download those plugins from Wrensoft. I found it was much easier to download All Plugins.
http://www.wrensoft.com/zoom/plugins.html
I integrated zoom search with RoboHelp 9 and showed the demo to all my managers. Everyone liked it. Thanks:)
Glad to hear it all went well. Please mark the first answer as being correct as it saves others wading through the thread.
I went through your site and got the solution. Thanks.
