7 Replies Latest reply on Dec 28, 2011 9:38 AM by Miss Caroline
    Field count
    Miss Caroline Newcomer
      I need to track the number of Yes, No, and Checkbox selections made in a multiple page form. These need to be counted individually and summed for a total count to be displayed on the final page of the document. In other words, Yes was selected 10 times; No was selected 5 times; Checkbox was selected 4 times. 19 total selections were made. Can someone please help me with the javascript syntax to access the fields to insert these figures on the final page? The final form will be a .PDF created using Adobe LiveCycle Designer ES2.
      This is the form hierarchy:
      form1
      Tables_P1
      tblStatP1
      Row1
      Yes
      No
      RadioButtonList1
      Checkbox1
        • 1. Re: Field count
          Kevin Cavallo Champion
          Does each page have its own table (Tables_P2, etc) or is it all one big table?
          • 2. Re: Field count
            Each page has its own table.
            • 3. Re: Field count
              radzmar Rockstar
              You can use a loop to check all check button objects (check box and radio buttons) within your form.
              Here's an example.
              function countChk(vNode) {
                        if (vNode.className === "field") {
                                  if (vNode.ui.oneOfChild.className === "checkButton") {
                                            if (vNode.items.nodes.length > 1) {
                                                      if (vNode.value.oneOfChild.value == 1) {
        nChk++;
                                            } else {
        nYes++;
                                                      } else if (vNode.value.oneOfChild.value == 2) {
        nNo++;
                                                      } else {
        nNone++;
                        for (var i = 0; i < vNode.nodes.length; i++) {
                      countChk(vNode.nodes.item(i));
              var nYes = 0;
              var nNo = 0;
              var nNone = 0;
              var nChk = 0;
              countChk(xfa.form);
              Textfield1.rawValue = nYes + " | " + nNo + " | " + Math.floor(nNone / 2) + " | " + nChk;
              1 person found this helpful
              • 4. Re: Field count
                Okay... I had to redo the format of the entire form for reasons I won't go into.I'm no longer working with tables. The radio buttons, checkboxes, and numeric field are now on the same hierarchy level. This is the code I tried:
                //initialize counts
                var nYes = 0;
                var nNo = 0;
                var nChk = 0;
                var nTotal = 0;
                for (i=1; i<=26; i++)
                           if (("RadioButtonList"+i).rawValue = Yes)
                            nYes++;
                           else if (("RadioButtonList"+i).rawValue = No)
                            nNo++;
                           else if (("CheckBox" + i).rawValue = 1)
                            nChk++;
                nTotal = nYes + nNo + nChk;
                this.rawValue = nTotal;
                I'm getting nothing.
                • 5. Re: Field count
                  radzmar Rockstar
                  Your script will not work, as you cannot use a variable in JavaScript to resolve a node.
                  Use the resolveNode method to use variables in the expression.
                  Also, to campare a value you have to use "===" or "==" instead of "=".
                  //initialize counts
                  var nYes = 0;
                  var nNo = 0;
                  var nChk = 0;
                  var nTotal = 0;
                  for (i=1; i<27; i++)
                             if (xfa.resolveNode("RadioButtonList[" + i + "]").rawValue === "Yes")
                              nYes++;
                             else if (("RadioButtonList[" + i + "]").rawValue === "No")
                              nNo++;
                             else if (("CheckBox[" + i + "]").rawValue === 1)
                              nChk++;
                  Did you test the script I posted before? It will look for all checkButton objects in the whole form, no matter if in tables or subforms.
                  • 6. Re: Field count
                    I did test your code and the form froze up and shut down LiveCycle. I copy and pasted your edits to my code and still nothing. There must be something small I'm missing. I probably won't get a chance to look at this again until Tuesday. I hope you'll be available to help me then. Thank you SO much!
                    Tuesday:
                    Okay, I have this code working except for the nChk portion. Since it's a check box, do I need to do something different with the comparison code?
                    var nYes = 0;
                    var nNo = 0;
                    var nChk = 0;
                       if(xfa.resolveNode("Page1.RadioButtonList"+i).rawValue === "Yes")
                        nYes++;
                       if(xfa.resolveNode("Page1.RadioButtonList"+i).rawValue === "No")
                        nNo++;
                       if(xfa.resolveNode("Page1.CheckBox"+i).rawValue === "1")
                        nChk++;
                    this.rawValue = nYes + nNo + nChk;
                    • 7. Re: Field count
                      The correct result is below. The only thing I was doing wrong in my code was putting the 1 in parenthesis. Thanks, Radzmar, for your help!
                      var nYes = 0;
                      var nNo = 0;
                      var nChk = 0;
                        nYes++;
                        nNo++;
                      if (xfa.resolveNode("Page1.CheckBox"+i).rawValue === 1)
                        nChk++;
