I have a problem with a Help system that seems familiar with a number of other discussions on this forum, but I haven't found anything directly relatable to it.
I have a WebHelp system generated using RH8. The Help has window-level context sensitivity. The Help system is deployed on a secure (HTTPS) server. When launching the Help from IE8, everything works as expected. However, launching the Help from Firefox (3, 8, or 9), the default topic appears and the Help is fully navicable except the contents for the navigation pane will not appear. The frame and the buttons (Contents, Index, Search) appear, but the content is missing. I can enter an Index term to search, but search doesn't return anything.
When I access the compiled Help system locally (not from a Web server), the navigation pane works correctly within Firefox.
My best guess after scouring a number of discussions, threads, and forums, is that it would appear that there is some issue with the Javascript affecting the context sensitivity and the left-frame functionality when deployed on a secure server using Firefox. However, I haven't come across anything that has worked as a solution.
Any other avenues to explore?
See if Item 57 at http://www.grainge.org/pages/snippets/snippets.htm helps.
Thanks, Peter. I'm having our implementation specialist check the security settings on the webserver.
Still not sure why the Help would appear and function correctly (both context-sensitivity and javascript) in IE but not in Firefox.
One other thing to note: When I hover over the navigation buttons above the left-frame in Firefox, there's a little pop-up that appears in the lower-left of the frame with the text javascript:void(0); for all three buttons. My guess is that this is pointing to a Javascript error as the root cause of the problem.
