I'm only a very basic Robohelp user. I simply import a Word document and generate help files.
Until now, each page from the Word document appeared where the project is saved as a separate HTML file. Now they are not and it doesn't seem to be generating these files at all, or if it is, I can't find them.
Can anybody help?
Please see the Before You Post sticky topic and start all threads with the version of RoboHelp that you are using.
Also see the Where Should I Post topic. I will move this thread to the correct forum on the assumption you are using RoboHelp HTML.
I am also assuming you are using RoboHelp 9 where you have to tick the Pagination check box for each style that you want RoboHelp to use for creating new topics. Thus if you want topics to be created at each Heading 1 style, you would tick that check box against Heading 1. The check box is found in the Word Conversion settings. See http://www.grainge.org/pages/authoring/importing/importing_rh9.htm on my site.
