Hi
I am trying to save the results from my quiz on localhost in captivate 5, I have followed adobe's instruction which can be found at the following link:
http://blogs.adobe.com/captivate/2010/08/reporting-the-quiz-results-to-a-local-server.html
The quiz seems to connect to the InternalServerReporting.php file without any problems but no new files or folders are getting created. I am publishing my quizzes to my C:\ drive and the InternalServerReporting.php file is stored in the root of localhost.
Any help with what might be stopping the script storing the results would be greatly appreciated.
Hi simonmcm,
Though you have mentioned that you have referred to the adobe's instruction but it would be really helpful if you can check the following things to ensure that the set up is proper.
1. Check whether the WAMP server is running or not.
2. Place the InternalServerReporting.php file inside the root folder i.e. [InstallDirectory]/wamp/www/
Check that the php script which you have placed in the root is accessible from the web browser.
i.e. type http://localhost/InternalServerReporting.php in your web browser and check that the file is accessible.
3. Check your write permission to the folder where you have placed the InternalServerReporting.php.
4. While configuring the Internal Server in Adobe Captivate ,enter the server address as you have typed in step2 in the "Configure the Internal Server" section.
4. If all the above are working properly for you then please let us know what is the "Status Message" you are getting when you are trying to post the result.
5. Finally in which Operating System you are facing this issue.
Subhransu
Hello Subhransu,
Please i need help urgently. I currently use captivate 5 on a mac OS and I want to record my quiz results on my local server. I currently use xampp rather than wamp but I finding it hard to setup the local server. I am currently following the steps you stated below and when I post results from the quiz, it tells me posted successfully but i do not see any captivate results folder in my root folder (htdocs in xampp). please could you help me on how i can overcome this problem..please it is really urgent. I need your help. Thanks. Below is the following i get on my web browser when i try to run the file:
Warning: mkdir() [function.mkdir]: Permission denied in /Applications/XAMPP/xamppfiles/htdocs/trainlocal/internalServerReporting.php on line 35
Warning: mkdir() [function.mkdir]: Permission denied in /Applications/XAMPP/xamppfiles/htdocs/trainlocal/internalServerReporting.php on line 37
Warning: mkdir() [function.mkdir]: Permission denied in /Applications/XAMPP/xamppfiles/htdocs/trainlocal/internalServerReporting.php on line 39
Warning: mkdir() [function.mkdir]: Permission denied in /Applications/XAMPP/xamppfiles/htdocs/trainlocal/internalServerReporting.php on line 41
Warning: fopen(./CaptivateResults////////) [function.fopen]: failed to open stream: No such file or directory in /Applications/XAMPP/xamppfiles/htdocs/trainlocal/internalServerReporting.php on line 43
Warning: fwrite() expects parameter 1 to be resource, boolean given in /Applications/XAMPP/xamppfiles/htdocs/trainlocal/internalServerReporting.php on line 44
Warning: fclose() expects parameter 1 to be resource, boolean given in /Applications/XAMPP/xamppfiles/htdocs/trainlocal/internalServerReporting.php on line 45
Also, please do you know how the results can be configured to be in a database please?
did you solve the problem?
I know how to do if you could not.
Regards.
So, is there a solution one would share?
